Handle Nut 手柄螺母
Handle Sleeve 手轮套管
Hard Seal Butterfly Valves 金属密封碟阀
High Temperature Pressure Power Station Gate Valves 高温高压电站闸阀
High Temperature Pressure Power Station Globe Valves 高温高压电站截止阀
Hoop 卡箍
Hayne's alloy 钴铬钨合金
High tem perature steel 高温钢
Hand-operated valves 手动阀
Hydraulic relay valves 液压继动阀
Hex Hut 手轮螺帽
Hydraulic Hand Gun 手动液压加注枪
Identification Plate 铭牌Integral Seat 整体阀座
Indicator 指示环Indicator Plug 指示塞
ISO flange dimensions ISO 法兰尺寸ISO bolt circle ISO 螺栓外径
Inside theread 内螺纹
Inspection And Test 检验和试验
Lifting Eye Bolt 吊眼螺栓
Lower Stem 下部阀杆
Lower Bearing 下部轴承
Lower Bushing 下部衬套
Liner 衬垫
lug style 吊耳式(蝶阀)
Locking Device 锁定装置
Lift Check Valves 升降式止回阀
Lining Ball Valves 衬里球阀
Lining Butterfly Valves 衬里碟阀
Lining Check Valves 衬里止回阀
Lining Cock 衬里二通
Lining Globe Valves 衬里截止阀
Lining T-Cock Valves 衬里三通旋塞阀
Liquid Indicator 液位计
LPG Pipe Fitting 液化气管件
Low tem perature steel 低温钢
Limit valves 限位阀
Lining Cock 衬里二通
Line Shaft 中轴
metric bolt hole threads 公制螺栓孔螺纹
Magnetic Co-operate Globe Valves 磁耦合截止阀
Magnetism Forle Pumps 磁力泵
Mut 螺母
Material chemical analysis and mechanical capacity 材料化学成份和机械性能
Materials for main parts 主要零件材料
Mechanical capacity 机械性能
Max. Discharging Capacity 最大排水量
Max. Operating Temperature 最高工作温度
Max. Allowable Temperature 最高允许温度
Max. Allowable Pressure 最高允许压力
Model 型号
Manual Oil Pumps Valves 手摇油泵(阀)
Meter Needle Type Globe Valves 仪表针形截止阀
Muffle check valve 消声止回阀
Non-Rising Stem 暗杆N.P.T.=美国标准锥管螺纹
Name Plate 铭牌Name of parts 零件名称
Nominal Pressure 公称压力
Nylon 尼龙塑料
NPT and Screwed bonnet 内螺纹和带螺纹阀盖
Non Rising Stem Single 暗杆楔式单闸板闸阀
Outside Screw and Yoke 外螺纹及支架O-Ring O 型环(密封圈)
Outside theread 外螺纹
Oxidant 氧化性介质
Oblique Stop Valves 直流式截止阀
Packing Gland 填料盖Packing 填料
Plug Seat Ring 插销阀座垫圈Plug Disc 插销阀瓣
Piston Rod Plug 活塞杆塞Piston Rod Plug Pin 活塞杆塞销钉
Piston-Disc 活塞瓣Piston Ring 活塞垫圈
Piston Ring Collar 活塞垫圈轴套pump discharge or elbows 泵的排泄口或
弯头处
Plug 插销PACKING SET 填料组合
Polytetrafluoroethylene 聚四氟乙烯
Pure aluminum 纯铝
Pure cupper 纯铜
Parallel Slide Valves 浆液阀
Pintle valve 针形阀
Piping Centrifugal Pumps 管道离心泵
Plunger valves 柱塞阀
Pressure valve 压力(増压)阀
Piping Pumps 管道泵
Piping Safety Valves 管道安全阀
Plunger Globe Valves 柱塞截止阀
Restrictor Valves 过流阀(或节流阀)
Pressure-Temperature Benchmark 压力-温度基准
PHYSICAL SIZE 尺寸大小
Quick Draining Valves 快速排污阀
Renewable Seat and Disc 可更换阀座和阀瓣Rubber flange 橡胶法兰
Reductant 还原性介质
Rising stem 明杆
Rubbeer graphite board 橡胶石墨板
Reducing valve 减压阀
Relief valve 安全泄压阀
Rapid closing stop valve 紧急关闭阀
Retainer 压环
Rocker 摇臂
Swing Nut 转轮螺母
Spring Shim 弹簧片
Split Yoke Bolt Nut 开口支架螺栓螺母
Stuffing Box Nut 填料箱螺母
Swing Bolt 转轮螺栓
Split Yoke Bolt 开口支架螺栓
Stuffing Box Bolt 填料箱螺栓
Seat Ring 阀座垫圈
Stuffing Box Gasket 填料箱垫圈
Stem 阀杆
Stem Collar 阀杆轴套
Set Bushing 固定螺丝
Stuffing Box 填料箱
Solid Wedge 实心楔板
Stem Collar 阀杆轴套
Seat Disc Nut 阀座阀瓣螺母
Swivel Nut 旋转螺母
Screw-in Bonnet 外螺纹阀盖
235 solder 235 焊接
Seat Disc 阀座阀瓣
Semi-Plug Disc 半插销阀瓣
Semi-Plug Seat Ring 半插销座垫圈
Spring Actuated 弹簧传动
Set Bushing 固定螺丝
Side Plug 侧面塞子
Stop Pin Retainer 止推销定位器
steam valves 蒸汽阀门
Safety Nut 安全螺母
Stem Seal 阀杆密封
Switch Box 转换开关盒
Stem Kit 阀杆组件
Seat 阀座
Stem Nut 阀杆螺母
Stem 阀杆
Stem Washer 阀杆垫圈
Stem Packing 阀杆填料
Swing Check Valves 旋启式止回阀
Screw 螺栓
Sealing 密封件
Stem 阀杆
Stem Mut 阀杆螺母
Stem seal 填料
Seat testing pressure 压力气密封试验压力
Socket 卡套
Spring steel 弹簧钢
Stainless acid-resisting steel 不锈耐酸钢
Stainless and Graphite 不锈钢/石墨
Stainless steel 不锈钢
Steel Casting iron 碳素钢铸件
Shell Test Pressure 壳体试验压力
