地质行业的需求
Slide 122 in the Mobil slide show 'Quest for Energy'. The number of geologists employed in 1997 was approximately 46,000
地质的竞争少点,因为干地质的少
Slide 121 in the Mobil slide show 'Quest for Energy'. Because of the lower competitiveness in geoscience jobs, there are fewer geology majors (48%) employed outside their initial discipline when compared to chemists (60%), physicists (79%) and biologists (82%).
地质的,化学的,生物的竞争的情况
Slide 120 in the Mobil slide show 'Quest for Energy'. Students graduating with degrees in geology have a much better opportunity to be employed in geology than the other basic sciences of physics, chemistry and biology. There are only 1.9 Bachelor of Science degrees awarded in geology for every geologist employed. This ratio is much more competitive than for chemists with 2.5 BS degrees/job, physicists with 4.7 BS degrees for every job, and biologists with 5.6 BS degrees per job.
