引用第1楼hypurestboy于2008-04-02 09:46发表的 :
楼主还需要什么文献 说一下
谢谢楼上的,另外还要:
A.Wojtanowicz.Minimum-Cost Casing Design for Vertical and Directional Wells[J].SPE 14499, 1985:P71-85
J.A.Issa. and D.S.Crowford. An Improved Design Equation for Tubular Collapse[J]. SPE 26317, 1993
R.M.Hackney. A New Approach to Casing Design for Salt Formations[J]. SPE/IADC 13431, 1985
P.D.Pattillo. An Evaluation of Concentric Casing for Nonuniform Load Applications. SPE 29232, 1985
M.J.Jellison and J.N.Brock. The Impaet of Compression Forces on Casing String Designs and Conneetors[J].SPE 47790, 2000
