  • 3080阅读
  • 7回复
【NOTE】A brief  record of fault [复制链接]
离线笑韵
4043
11582
878
只看楼主 倒序阅读 使用道具 0楼 发表于: 2008-05-08 | 石油求职招聘就上: 阿果石油英才网
fault
fault, in geology, fracture in the earth's crust in which the rock on one side of the fracture has measurable movement in relation to the rock on the other side. Faults on other planets and satellites of the solar system also have been recognized. Evidence of faults are found either at the surface (fault surface) or underground (fault plane). Faults are most evident in outcrops of sedimentary formations where they conspicuously offset previously continuous strata.
Movement along a fault plane may be vertical, horizontal, or oblique in direction, or it may consist in the rotation of one or both of the fault blocks, with most movements associated with mountain building and plate tectonics.
The two classes of faults include the dip-slip (倾向滑动断层)(up and down movement), which is further divided into normal and thrust (reverse) faults(正断层和逆断层); and strike-slip(走滑断层) (movement parallel to the fault plane). The San Andreas fault of California is of this type.
In dip-slip faults the term “hanging wall(上盘)” is used for the side that lies vertically above the other, called the “footwall(下盘).”
A fault in which the hanging wall moves down and the footwall is stationary is called a normal fault. Normal faults are formed by tensional, or pull-apart, forces.
A fault in which the hanging wall is the upthrown side is called a thrust fault because the hanging wall appears to have been pushed up over the footwall. Such faults are formed by compressional forces that push rock together and are by far the most common of the dip-slip faults.
All types of faults have been recognized on the ocean floor: normal faults occur in the rift valleys(裂谷) associated with mid ocean ridges(洋中脊) spreading at slow rates; strike-slip faults appear between the offset portions of mid-ocean ridges; and thrust faults occur at subducting plate(俯冲板块) boundaries.
Active faults, though they may not move for decades, can move many feet in a matter of seconds, producing an earthquake. The largest earthquakes occur along thrust faults. Some faults creep from a half inch to as much as 4 in. (1 to 10 cm) per year. Fault movements are measured using laser and other devices. Faults create interpretation problems for geologists by altering the relations of strata (see stratification), such as making the same rock layer offset in two vertical cross sections of a formation or making layers disappear altogether. Faults are often seen on the surface as topographical features, including offset streams(断移河), linear lakes(线性湖?), and fault scarps(断层崖).
note: about Linear Lakes:http://www.unearthedoutdoors.net/lakes/75015
[ 此贴被笑韵在2008-05-08 17:02重新编辑 ]
坐看云起 财富 +50 版块管理 2008-05-08
久违了的
离线笑韵
4043
11582
878
只看该作者 1楼 发表于: 2008-05-08 | 石油求职招聘就上: 阿果石油英才网
subseismic fault
Within any faulted reservoir, there are large numbers of faults that are below the resolution of seismic surveys. Some of these faults are encountered in wells, but most of them remain undetected. Such subseismic faults can significantly influence the flow of hydrocarbons during production. The size distribution of subseismic faults can be predicted by extrapolating the size distribution measured at the seismic scale down to the subseismic scale. However, the positions and orientations of the subseismic faults are more difficult to determine.
Remark: subseismic fault,对应的中文含义未找到!理解为地震难以识别(分辨)的断层!
Fault orientation variations 或者orientations of the subseismic faults 之中的orientation 感觉应该理解为产状,未知可否!石油大典上译为“断层取向”,但是这个词并不是专业词汇,只是直译而已!
久违了的
离线笑韵
4043
11582
878
只看该作者 2楼 发表于: 2008-11-02 | 石油求职招聘就上: 阿果石油英才网
Re:【NOTE】A brief  record of fault
断层带的结构
dz=damage zone 诱导裂缝带
fr=fault rock 断层岩
frag= fragmented zone破碎带(碎裂带)
hr=host rock 原岩
gouge zone 断层泥
fault core =断层核部??
from:Grain size distribution and thickness of breccia and gouge zones from thin (<1 m) strike-slip fault cores in limestone
from:Effects of damage-zone thickness on fault displacement
http://134.76.163.148:8080/dspace/bitstream/gledocs-149/1/Gudmundsson%2BGeyer.pdf
from:宋胜浩 从断裂带内部结构剖析油气沿断层运移规律,大庆石油学院学报 >> 2006年30卷3期
from:付晓飞 方德庆 从断裂带内部结构出发评价断层垂向封闭性的方法 地球科学:中国地质大学学报 >> 2005年30卷3期 >>
[ 此贴被笑韵在2008-12-17 22:16重新编辑 ]
久违了的
离线笑韵
4043
11582
878
只看该作者 3楼 发表于: 2008-11-03 | 石油求职招聘就上: 阿果石油英才网
Deformation bands
Deformation bands (Aydin 1978) are one kind of frictional deformation structures in the uppermost Earth&acute;s crust. Deformation bands, which were first described by Aydin (1978), may be defined as tabular structures of finite width resulting from strain localization commonly found in sand and porous sandstone. Three end members cases of these structures are distinguished: (1) deformation bands with clear shear offset, which have been termed deformation band faults (Mollema & Antonellini, 1996), (2) compaction bands that refer to tabular bands of localized porosity reduction that lack shear offset, which have been termed compaction bands and (3) tabular bands of localized increase in porosity that lack a macroscopic shear offset, which have been termed dilatation bands (Du Bernard, Eichhübl & Aydin, 2002). According to the degree of grain fragmentation and clay content, deformation band faults are further divided into three groups (Antonellini, Aydin & Pollard, 1994): (a) with little or no cataclasis, (b) with cataclasis and (c) with clay smearing.
变形带(变形包括体变和形变)deformation bands,这一概念是Aydin1978年首先提出的,是指砂岩或孔隙性砂岩地层中因局部发生应变而产生的一种板状构造。变形带构造可以分为三类:(1)具有明显剪切位移的,称之为形变带断层 (Mollema & Antonellini, 1996), (2) 发生局部孔隙减少且没有剪切位移的,称之为压实带 (3) 发生孔隙增大且没有宏观剪切位移的,称之为膨胀带(Du Bernard, Eichhübl & Aydin, 2002). 根据颗粒破碎程度和粘土含量,形变带断层又进一步划分为(Antonellini, Aydin & Pollard, 1994): (a)略微或没发生碎裂的, (b) 发生碎裂的 (c) 发生泥岩涂抹的.
Deformation band faults (for recent reviews, see Mair, Main & Elphick, 2000; Main et al. 2001) are typically about 1 mm wide, roughly planar deformation structures that show shear deformation in the range of millimetres to a few centimetres. The slip-to fault-length ratios are low compared to ordinary faults with slip surfaces in dense lithologies (Fossen & Hesthammer, 1997). Single cataclastic deformation band faults accommodate deformation across the entire band width by collapse or increase of porosity, grain fracturing, grain size reduction and cataclastic flow that lacks a discrete discontinuity surface. In high-porosity rocks under low stresses, grain fracturing may be absent and deformation is accommodated also by grain rotation, grain sliding and porosity reduction. Deformation band faults are solely the result of a displacement gradient (over a narrow tabular zone), in contrast to faults with slip surface which must include a displacement discontinuity.
Generally, deformation band faults may occur alone, but usually they group multiple, sub-parallel, closely spaced zones. The formation of zones of deformation band faults each of which have limited slip, is explained by repeatedly shifts of deformation to form new bands in order to accommodate bulk strain. The zones of deformation band faults are thought to grow by addition of new deformation band faults, side by side, thus the thickness of the zone depends on the number and spacing of individual deformation band faults.
Theoretical diagram demonstrating the difference between “ordinary” faults and deformation band faults. (a) Faults usually form discrete slip surfaces in fully cemented rocks. Once a slip surface is formed, subsequent strain is focused on this surface because of strain localisation mechanisms of this kind of deformation. (b) Deformation band faults are typical for deformation in porous or even completely uncemented granular material, where strain is accommodated by the formation of slightly undulating deformation surfaces. Porosity reduction, grain rotation and grain fracturing result in an overall strain hardening type of deformation.
The shifting of deformation is thought to be due to strain hardening via increased grain friction in the bands during grain breaking and porosity reduction processes. There are two models explaining the sequential groth of zones of deformation band faults. In the model of Aydin & Johnson (1978) the strain hardening mechanisms result in a sequential growth of deformation band faults with deformation widths of few millimetres into zones of deformation band faults with deformation widths of up to several tens of centimetres and finally into zones of deformation band faults with a slip surface on either side with offset of up to several tens of meters. Shipton & Cowie (2001) expand this classical model and mention that small slip-surfaces may already nucleate at a relatively early stage in the evolution of a zone of deformation band faults. With increasing strain the slip-surfaces propagate and link within a growing zone of deformation band faults. In the Shipton & Cowie (2003) model, both types of faults grow contemporaneously and interdependently from each other, controlled by the transition from strain hardening to strain softening and strain localisation.
Case study
Tectonic evolution studies of the Himalayan mainly focus on the Tertiary deformation and kinematics resulting from the Indo-Asian collision. Due to the magnitude and intensity of Himalayan tectonics in the rocks that comprise the Himalayan orogen, any pre-existing, older structures deformed by pre-Himalayan events are obscured or only partly preserved. As a result, pre-Himalayan deformation episodes are poorly documented and mainly inferred from lithostratigraphic anomalies such as tectonic unconformities; reports on pre-Himalayan structural field data are extremely rare. In recent years, increasing interest has been focused on possible pre-Himalayan deformation structures and their attendant influence on the Tertiary kinematic evolution of the Himalayas. We investigate deformation band faults in quartzites of the Lower Devonian Muth Formation (Pin Valley, NW Himalaya). The purpose of this investigation is to constrain the orientations, kinematics and microstructural characteristics of these deformation band faults. Based upon a clear separation of these structures from later faults in the same formation that have clearly different orientations as well as deformation mechanism a pre-Himalayan age for the deformation bands can concluded.
Geological map of the Pin Valley modified after Fuchs (1982). (b) Stereo plots (equal area projections; lower hemisphere; contours at 3-times and 5-times the random distribution) of deformation band faults (filled circles) and zones of deformation band faults (filled triangles) in the Muth Formation, at locations 1 to 3, southeast of Mikkim. Deformation band faults have been rotated to account for Eocene folding. Faults have been rotated to account for Eocene folding.
http://www.ig.tuwien.ac.at/Research/Research_deformation_bands.htm
[ 此贴被笑韵在2009-03-01 10:44重新编辑 ]
久违了的
离线笑韵
4043
11582
878
只看该作者 4楼 发表于: 2008-12-17 | 石油求职招聘就上: 阿果石油英才网
久违了的
离线笑韵
4043
11582
878
只看该作者 5楼 发表于: 2009-02-23 | 石油求职招聘就上: 阿果石油英才网
detachement
  以一个相对低的岩石强度和高剪应变为特征的软弱层为滑脱面,其上盘岩石从下盘滑脱而形成的构造。滑脱面常由不同规模的一条断层或一个断层系(脆性或韧性)组成,一般顺层发育,如地层或岩系分界面、不整合面或地层中岩性显著差异的分隔面等。该面分割了上下不同应变特征和力学性质的岩片。滑移距离很大的上部岩片组成了外来构造岩片。滑脱作用可以发生在盖层各岩系之间、盖层与基底之间,上、下地壳之间、地壳与上地幔之间以及岩石圈与软流圈之间。岩石圈中多级分层及滑脱构造的发现是构造地质学认识上的重大突破。
  根据变形过程中的应力状态可将滑脱构造分为两类:①伸展型滑脱构造,即拆离构造,是指在伸展(拉伸)作用下沿层间近水平或低角度的正断层滑移的构造。它将块体划分为上拆离盘和下拆离盘。上拆离盘是由叠瓦状铲式(上陡下缓)正断层系或多米诺正断层系组成的脆性变形域;下拆离盘往往由糜棱岩带组成、具面理及线理构造的塑性变形域(见图美国西部科迪勒拉第三纪伸展型滑脱断裂系)。②压缩型滑脱构造,在挤压作用下沿层间近水平或低角度的冲断层而滑移的构造。欧洲侏罗山式褶皱及加拿大落基山前陆的冲断褶皱带都是沉积盖层沿基底表面滑脱所成的典型构造。底部的滑脱带在地壳深部表现为韧性滑脱剪切带及糜棱岩带,有时伴随中、高压变质带。压缩型滑脱构造的上部岩片发育一系列叠瓦状的铲式冲断层,自上而下褶皱轴面及劈理面常表现为由陡立、倾斜向水平呈递进演变的规律。
http://www.china001.com/show_hdr.php?xname=PPDDMV0&dname=MUJ7H41&xpos=35
久违了的
离线笑韵
4043
11582
878
只看该作者 6楼 发表于: 2009-03-19 | 石油求职招聘就上: 阿果石油英才网
Welcome to web-based teaching resources in structural geology in the School of Earth Sciences of the University of Leeds. In addition to resources created here you can also find links to other sites. Use the below icons to select topics.
Rob Butler, Martin Casey, Geoff Lloyd, Andrew McCaig
http://www.see.leeds.ac.uk/structure/learnstructure/index.htm
久违了的
离线lxsh
2678
15621
只看该作者 7楼 发表于: 2016-06-22 | 石油求职招聘就上: 阿果石油英才网
砂好了,要好好学习
苍海游龙
