排驱半径是油井流动达到拟稳态以后,能够向井提供的流动区域的面积折算成圆形的半径,而水平井井底半径仅是一孔之见。至于水平井还是直井,排驱半径和井底半径并无特殊的地方,仅是井的供给面积的形状上,直井因是以点为中心向四周扩散,一般为圆形,而水平井因是以线(水平井段)为中心向四周扩散,一般为椭圆形。
Expulsion radius is well to be steady state flow after wells to provide liquidity to the size of the area converted into radius of the circle, while the bottom horizontal radius of only a Criminal Suit. As for the horizontal or vertical wells, displacement radius and bottom radius of no special place, only the shape of the area of supply wells, the vertical well because the center is a point spread to the surrounding, usually circular, and horizontal wells because it is to line (horizontal well) as the center spread to the surrounding, usually oval.
