ProppantThe Effect of Proppant Distribution and Un-Propped Fracture Conductivity on Well Performance in Unconventional Gas Reservoirs SPE 119368-MS 2009
Quantifying Proppant Transport for Complex Fractures in Unconventional Formations SPE 119300-MS 2009
Proppant Transport of Fracturing Gels is Influenced by Proppant Type SPE 118717-MS 2009 Controlling Proppant Flowback to Maintain Fracture Conductivity and Minimize Workovers: Lessons Learned from 1,500 Fracturing Treatments SPE 112461-MS 2008 Prediction of Proppant Transport from Rheological Data SPE 115298-MS 2008 Comparative Study of Flowback Analysis Using Polymer Concentrations and Fracturing-Fluid Tracer Methods: A Field Study SPE 101614-PA 2008
Proppant Placement During Tight Gas Shale Stimulation: Literature Review And Speculation ARMA 08-355 2008
Proppant Placement Using Reverse-Hybrid Fracs SPE 99580-PA 2007
Using Field Results to Guide Proppant Selection in the Pinedale Anticline SPE 108991-MS 2007
Experimental and Numerical Investigation of Proppant Placement in Hydraulic Fractures SPE 107927-MS 2007
Behavior of Proppants Under Cyclic Stress SPE 106365-MS 2007
Prediction of Long-Term Proppant Flowback in Weak Rocks SPE 106264-MS 2007
Remediation of Proppant Flowback—Laboratory and Field Studies SPE 106108-MS 2007
Extrapolation of Laboratory Proppant Placement Behavior to the Field in Slickwater Fracturing Applications SPE 106089-MS 2007
Experimental Study on Additives Systems Used for Proppant Flowback Control in a Hydraulic Fracturing Treatment SPE 106358-MS 2006
Large-Scale Laboratory Investigation of the Effects of Proppant and Fracturing-Fluid Properties on Transport SPE 98005-MS 2006
Remediation of Production Loss Due to Proppant Flowback in Existing Wellbores SPE 102629-MS 2006
Transport of Proppant in Hydraulic Fractures SPE 103167-MS 2006
Improved Understanding of Proppant Transport Yields New Insight to the Design and Placement of Fracturing Treatments SPE 102758-MS 2006 Statistical Study of the Crush Resistance Measurement for Ceramic Proppants SPE 102645-MS 2006
Measurement of Proppant Transport of Frac Fluids SPE 95287-MS 2005
Innovative Proppant Flow-Back Control Yields 100% Success in Permian Basin SPE 84577-MS 2003
Water-Fracs: We Do Need Proppant After All SPE 102227-MS 2006
The Quest for Improved Proppant Placement: Investigation of the Effects of Proppant Slurry Component Properties on Transport SPE 95675-MS 2005
Proppant Distribution and Flowback in Off-Balance Hydraulic Fractures SPE 89889-PA 2005
A Mechanical Methodology of Improved Proppant Transport in Low-Viscosity Fluids: Application of a Fiber-Assisted Transport Technique in East Texas SPE 91434-MS 2004
Avoiding Proppant Flowback in Tight-Gas Completions with Improved Fracture Design SPE 84310-MS 2003
Effective Proppant Flowback Control Following Hydraulic Fracturing Treatments in Shallow Reservoirs SPE 84312-MS 2003
Reliable Proppant Flowback Control for Low-Stress, Low-Temperature Reservoirs SPE 83469-MS 2003
Proppants: Is Bigger Better or Is Placement The Key? SPE 72381-MS 2001
Layered Modulus Effects on Fracture Propagation, Proppant Placement, and Fracture Modeling SPE 71654-MS 2001
Enhanced 2D Proppant-Transport Simulation: The Key To Understanding Proppant Flowback and Post-Frac Productivity SPE 69211-PA 2001
Computer Simulations of Proppant Transport in a Hydraulic Fracture SPE 69212-PA 2001
Frac Fluid New Frac Fluid Provides Excellent Proppant Transport and High Conductivity SPE 119380-MS 2009
A New Correlation for Relating the Physical Properties of Fracturing Slurries to the Minimum Flow Velocity Required for Transport SPE 106312-MS 2007
[ 此贴被canterwood在2009-04-26 16:48重新编辑 ]
