  • 902阅读
  • 1回复
spe69637-MS一篇 [复制链接]
离线holyabc
182
265
只看楼主 倒序阅读 使用道具 0楼 发表于: 2010-03-26 | 石油求职招聘就上: 阿果石油英才网
— 本帖被 笑韵 从 油藏工程 移动到本区(2010-03-26) —
我这里有一篇spe的文章,请分享
Paper Number  69637-MS
DOI  What's this? 10.2118/69637-MS
Title Oil Displacement by Water in Vuggy Fractured Porous Media
Authors J. Cruz-Hernandez, R. Islas-Juarez, C. Perez-Rosales, S. Rivas-Gomez, A. Pineda-Munoz, J.A. Gonzalez-Guevara, Mexican Petroleum Institute
Source SPE Latin American and Caribbean Petroleum Engineering Conference, 25-28 March 2001, Buenos Aires, Argentina
Copyright Copyright 2001, Society of Petroleum Engineers Inc.
Language English
Preview Abstract
In this paper experimental results obtained for the oil displacement by water within a two-dimensional vuggy fractured porous cell are presented. The experiments were carried out with an acrylic cell, where fractures were represented by channels of 1.6 mm wide, 1.2 mm deep and 19 cm long, whereas the vugs were represented by cylinders of 1 cm diameter and 1.2 mm deep.
The experimental procedure is as follows: the cell, saturated 100% with oil was placed horizontally and at time t=0 water was injected at a constant rate. Photographs were taken to follow the water front in the cell; then, the area corresponding to oil and water was measured. In this way the water saturation in the cell was determined. This water saturation is equal to the oil recovery, considering oil and water as incompressible fluids.
Based on the experimental results, a theoretical model was developed. This model considers that the porous space is constituted by two regions: one that can conduct fluids, called flow region and a stagnant region that interchange matter with the flow region through a diffusion-like process. Analytical solutions for water saturation and normalized oil recovery are presented.
[ 此帖被笑韵在2010-03-26 16:42重新编辑 ]
本主题包含附件,请 登录 后查看, 或者 注册 成为会员
离线303404980
316
46
61
只看该作者 1楼 发表于: 2011-02-21 | 石油求职招聘就上: 阿果石油英才网
学习了
