  • 939阅读
  • 3回复
求翻译:地面处理设备中的一句话 [复制链接]
离线无产者
269
91
只看楼主 倒序阅读 使用道具 0楼 发表于: 2012-11-18 | 石油求职招聘就上: 阿果石油英才网
The minimal pressure drop across the meter and its high pressure rating make it possible to flow the well effluents naturally through the sea line without separating the well effluent phases.
离线ccl6012
425
748
只看该作者 1楼 发表于: 2012-11-18 | 石油求职招聘就上: 阿果石油英才网
井的采出液的本身的高压以及在流量计周围的微小压降使采出液不会气液分离,可以直接在海管中流动。
离线无产者
269
91
只看该作者 2楼 发表于: 2012-11-21 | 石油求职招聘就上: 阿果石油英才网
回 ccl6012 的帖子
ccl6012:井的采出液的本身的高压以及在流量计周围的微小压降使采出液不会气液分离,可以直接在海管中流动。 (2012-11-18 16:45)
谢谢,是高手呀
离线无产者
269
91
只看该作者 3楼 发表于: 2012-11-21 | 石油求职招聘就上: 阿果石油英才网
The PhaseTester* portable multiphase periodic well testing equipment has been introduced into the system. It has enhanced operational flexibility and provided accurate phase flow rates. During the post cleanup operations, the PhaseTester led to the elimination ofgas flaring. The minimal pressure drop across the meter and its high pressure rating make it possible to flow the well effluents naturally through the sea line without separating the well effluent phases.The deployment of this multiphase flow meter in the system has resulted in a reduction in the gas flaring of about 60% during duration of the job.
