  • 1101阅读
  • 5回复
美石油规范API-2A 4.2.3 节点设计的句子含义 [复制链接]
离线amazon5
43
90
只看楼主 倒序阅读 使用道具 0楼 发表于: 2012-12-26 | 石油求职招聘就上: 阿果石油英才网
API-2A的 4.2.3 定义了“最小承载力”有:The connection at the ends of tension and compression members should develop the strength required by design loads ,
but not less than 50% of the effective strength of the member.
问:
1)effective strength 是什么?
2)为何规定不小于50%的effective strength of the member.?
多谢讨论。
2条评分认可度+10财富+13
tkj 认可度 +10 欢迎提问 2012-12-30
tkj 财富 +13 欢迎提问 2012-12-30
离线寰宇祥和
55
211
只看该作者 1楼 发表于: 2012-12-27 | 石油求职招聘就上: 阿果石油英才网
不是石油专业的,只是个翻译员,给点个人意见讨论:
有效强度
因为是在构件两端的连接,所以两端都大于50%时,在构件承受effective strength以上的负载时,才不会在连接处断裂。
是这样不
1条评分财富+25
tkj 财富 +25 参与讨论 2012-12-30
离线tkj
3697
1932
251
只看该作者 2楼 发表于: 2012-12-30 | 石油求职招聘就上: 阿果石油英才网
感觉你这个问题好像是有关钻柱设计的,建议看看钻井工程和材料力学
人人为我,我为人人,加入阿果石油网。
离线bhczq8
260
900
只看该作者 3楼 发表于: 2012-12-30 | 石油求职招聘就上: 阿果石油英才网
The connection (连接点) at the ends of tension and compression members (位于拉伸和压缩构件端点的) should develop (应该达到) the strength required by design loads (设计载荷要求的强度),
but not less than 50% of the effective strength of the member. (但是不能小于构件有效载荷的 50%)
问:
多谢讨论。
呵呵
离线bhczq8
260
900
只看该作者 4楼 发表于: 2012-12-30 | 石油求职招聘就上: 阿果石油英才网
柯林斯英汉双解大词典21世纪大英汉词典develop /dɪˈvɛləp/ CET4 TEM4(developing, developed, develops)
1. V-IWhen something develops, it grows or changes over a period of time and usually becomes more advanced, complete, or severe. 发展
例:It's hard to say at this stage how the market will develop.
在现阶段很难说市场会如何发展。
例:These clashes could develop into open warfare.
这些冲突可能会发展成公开的战争。
2. developedADJ发展的; 发育的
例:Their bodies were well developed and super fit.
他们的身体发育良好,极其健康。
3. V-IIf a problem or difficulty develops, it begins to occur. 产生
例:The space agency says a problem has developed with an experiment aboard the space shuttle.
航天局说在航天飞机上做的一项实验出了问题。
4. V-IIf you say that a country develops, you mean that it changes from being a poor agricultural country to being a rich industrial country. 发达
例:All countries, it was predicted, would develop and develop fast.
据预测,所有的国家都会发达起来,并且很迅速。
5. see also developed, developing
6. V-T/V-IIf you develop a business or industry, or if it develops, it becomes bigger and more successful. 扩展[商业]
例:An amateur hatmaker has won a scholarship to pursue her dreams of developing her own business.
一位业余制帽匠赢得了一笔奖学金,来实现她扩展自己企业的梦想。
7. developedADJ发达的
例:...the countries that have suffered the most from the absence of more developed financial systems.
…因缺乏更发达的金融体系而受损最严重的国家。
8. V-TTo develop land or property means to make it more profitable, by building houses or factories or by improving the existing buildings. 开发 (房地产)
例:Local entrepreneurs developed fashionable restaurants, bars and discotheques in the area.
当地的企业家在这个地区开办了时尚的餐馆、酒吧和迪斯科舞厅。
9. developedADJ已开发的
例:Developed land was to grow from 5.3% to 6.9%.
已开发的土地将从5.3%增长到6.9%。
10. V-TIf you develop a habit, reputation, or belief, you start to have it and it then becomes stronger or more noticeable. 获得; 形成
例:Mr. Robinson has developed the reputation of a ruthless cost-cutter.
鲁宾逊先生已经有了毫不留情的成本削减者的名声。
11. V-T/V-IIf you develop a skill, quality, or relationship, or if it develops, it becomes better or stronger. 增长; 增进
例:Now you have a good opportunity to develop a greater understanding of each other.
现在你们有了一个好机会来增进彼此的了解。
12. developedADJ增长的; 增进的
例:...a highly developed instinct for self-preservation.
…一种高度增长了的自卫本能。
13. V-TIf a piece of equipment develops a fault, it starts to have the fault. 发生
例:The aircraft made an unscheduled landing at Logan after developing an electrical fault.
飞机发生电气故障后,临时在洛根着陆。
14. V-TIf someone develops a new product, they design it and produce it. 开发 (产品)
例:He claims that several countries have developed nuclear weapons secretly.
他声称几个国家已经秘密开发了核武器。
15. V-T/V-IIf you develop an idea, theory, story, or theme, or if it develops, it gradually becomes more detailed, advanced, or complex. 展开
例:I would like to thank them for allowing me to develop their original idea.
我想感谢他们允许我展开他们最初的观点。
16. V-TTo develop photographs means to make negatives or prints from a photographic film. 冲洗
例:...after developing one roll of film.
…冲洗了一卷胶卷后。
呵呵
离线bhczq8
260
900
只看该作者 5楼 发表于: 2012-12-30 | 石油求职招聘就上: 阿果石油英才网
美国传统词典[双解]v.(动词)
de.vel.op
&b{de.vel.oped},&b{de.vel.op.ing},&b{de.vel.ops}
v.tr.(及物动词)
To bring from latency to or toward fulfillment:
开发:把潜在的因素引向完善:
To expand or enlarge:
扩展,使变大:
To aid in the growth of; strengthen:
强化,加强:帮助成长;加强:
To improve the quality of; refine:
改良,增进:提高质量;精炼:
To cause to become more complex or intricate; add detail and fullness to; elaborate:
使复杂:使变得更加复杂;增加细节;使变得复杂:
&I{Music} To elaborate (a theme) with rhythmic and harmonic variations.
&I{【音乐】} 使主题音乐繁复变调:用有节奏的和谐的变化使(弦律)更加精妙
To bring into being gradually:
逐渐形成:
To set forth or clarify by degrees:
逐步提出,逐步阐明:
To come to have gradually; acquire:
逐渐拥有;获得:
To become affected with; contract:
感染;受…传染:
To cause gradually to acquire a specific role, function, or form, as:
逐渐获得:使逐渐获得某一特定的地位、功能或形式,例如:
To influence the behavior of toward a specific end:
影响:朝着某一特定目标的影响行为:
To cause (a tract of land) to serve a particular purpose:
开发利用土地:使(一块土地)为特定的目的服务:
To make available and effective to fulfill a particular end or need:
使有用:为满足某个特定的目的或需要而使…有用,使…有效:
To convert or transform:
转换,转变:
&I{Games} To move (a chess piece) to or toward a more strategic position.
&I{【游戏】} 将棋子移自有利位置:朝某个更具战略性的位置移动(棋子)
To process (a photosensitive material), especially with chemicals, in order to render a recorded image visible.
洗相:为了使记录的图象可见,可处理(光敏物质),尤指用化学物质处理
To render (an image) visible by this means.
使显影:通过洗相使(图象)可见
adj.(形容词)
To grow by degrees into a more advanced or mature state:
发展成熟:按阶段向更高级或更成熟的状态生长:
To increase or expand.
增长,扩展
To improve; advance:
提高;发展:
To come gradually into existence or activity:
逐渐形成:逐渐出现,逐渐被激发:
To come gradually to light; be disclosed:
暴露:逐渐显示出来;被揭露:
&I{Biology}
&I{【生物学】}
To progress from earlier to later stages of a life cycle:
进化:从生命周期的早期阶段发展到后期阶段:
To progress from earlier to later or from simpler to more complex stages of evolution.
进化:从进化阶段的早期到末期或从简单到复杂的发展过程
French &I{développer}
法语 &I{développer}
from Old French &I{desveloper}
源自 古法语 &I{desveloper}
&I{des-} [dis-]
&I{des-} [前缀,表“不,没有”]
&I{voloper} [to wrap] [possibly of Celtic origin]
&I{voloper} [把…包起来] [可能源于塞尔特语]
现代英汉综合大辞典vi.
使发达, 使发展; 使成长; 使进化
开发(土地、矿山、资源等)
展开(情节、音乐主题、方程式等)
【摄】使显影, 冲洗
使显出, 出现, 产生; 研制
呵呵
