  • 3080阅读
  • 8回复
Promax R5000中 3D Ref Statics Model* 不能运行 [复制链接]
离线lyhinsohu
507
728
只看楼主 正序阅读 使用道具 0楼 发表于: 2014-09-23 | 石油求职招聘就上: 阿果石油英才网
*** Start of STDOUT for sys/exe/superExec ***
*** ProMAX superExec Version 2.0.4                        ***
*** Built for Release 5000.0.0.0 Linux 2.6.9-42.ELsmp     ***
*** Copyright 1998-2008 Landmark Graphics Inc.            ***
*** Tue Sep 23 18:36:59 2014                              ***
*** Current Operating Environment:                        ***
*** sysname : Linux                                       ***
*** nodename: nexus                                       ***
*** release : 2.6.18-371.12.1.el5                         ***
*** version : #1 SMP Wed Sep 3 16:22:56 EDT 2014          ***
*** machine : i686                                        ***
*** request : 4180                                        ***
--- Searching for ProMAX license(s)                       ---
--- ProMAX license(s) checked out for this flow :-        ---
---  PROMAXFIELD                                          ---
--- ProMAX license(s) accessed, proceeding                ---
Ignore previous pvmd errors: will now start new pvm daemon on nexus.
*-*-*-*-*-*-*-*-* superExec packet analysis *-*-*-*-*-*-*-*-*
Start Sub Flow 1 ========
Library path = </data/PrMR5000/ProMAX/linux/lib> ;
                </data/PrMR5000/ProMAX/sys/lib> ;
                </data/PrMR5000/ProMAX/jre/lib/i386/server> ;
Exec path    = </data/PrMR5000/ProMAX/linux/exe/refracmod.exe> ;
Packet       = </data/PrMR5000/ProMAX/data/xiyuan/06/4-stat/4180/t10162> ;
Inherited Types =  "CoProcess End" ;
Processes =
  Name = VOID             ; Types = "Void" ;
   Packet # 2 ; Seq # 0 ;
   Packet # 3 ; Seq # 0 ;
   Packet # 4 ; Seq # 0 ;
   Packet # 5 ; Seq # 0 ;
   Packet # 6 ; Seq # 0 ;
   Packet # 7 ; Seq # 0 ;
   Packet # 8 ; Seq # 0 ;
  Name = FLOW_COMMENT     ; Types = "Void" "History" "Flow Comment" ;
   Comment      = <Processing flow comment:> ;
   Packet # 9 ; Seq # 0 ;
   Packet # 10 ; Seq # 0 ;
   Packet # 11 ; Seq # 0 ;
   Packet # 12 ; Seq # 0 ;
   Packet # 13 ; Seq # 0 ;
   Packet # 14 ; Seq # 0 ;
   Packet # 15 ; Seq # 0 ;
   Packet # 16 ; Seq # 0 ;
   Packet # 17 ; Seq # 0 ;
   Packet # 18 ; Seq # 0 ;
   Packet # 19 ; Seq # 0 ;
   Packet # 20 ; Seq # 0 ;
   Packet # 21 ; Seq # 0 ;
   Packet # 22 ; Seq # 0 ;
   Packet # 23 ; Seq # 0 ;
  Name = STATICS1         ; Types = "History" "Stand Alone Tool" ;
   Packet # 24 ; Seq # 1 ;
   Packet # 25 ; Seq # 0 ;
   Packet # 26 ; Seq # 0 ;
End Sub Flow 1   ========
Fatal error occurred on 23-Sep-14 at 18:37:03
Message is:
initColors failed:
This program cannot run on a 24 bit-only color
desktop.  You need to run on an 8 bit Xserver.
For the entire job:
Total CPU time =        0.1 seconds
Total elapsed time =          0 minutes,          0 seconds
SeisSpace JobRecord for index = 38
jobid=4180
jobState=70, FAILED
percent=0.000000
rate=0.000000
traces=0
submittedTime=Tue Sep 23 18:37:03 2014
initializedTime=Tue Sep 23 18:37:03 2014
completedTime=Tue Sep 23 18:37:03 2014
reqid=4180
pid=4213
host=nexus
queue=
*** Warning :         Sub Flow  1      Return code =   1  ***
*** Tue Sep 23 18:37:04 2014                              ***
*** ProMAX superExec - Version 2.0.4                      ***
*** Start of STDERR for sys/exe/superExec ***
pvm_startup: checking pvmd daemon.
libpvm [pid4210]: /tmp/pvmd.5000.0.0.0.500.nexus: No such file or directory
libpvm [pid4210]: pvm_mstat(): Can't contact local daemon
pvm_startup: pvmd daemon /tmp/pvmd.5000.0.0.0.500.nexus initiated.
Read error; Unable to read rec 38
3-D Refraction Statics Model Builder.
Area = xiyuan
Line = 06
New DB Name = DLY10000
New DB VEL Name = VEL10000
New DB OFFSET Name = OFF10000
Error occurred in database routine:  OPF OPENPARMFILE
[attempting to open for read only, parm file: /data/PrMR5000/ProMAX/data/xiyuan/06/OPF.TRC/OPF60_TRC.GEOMETRY.OFFSET]
Table Name = OFF10000
Table Description = Offset Range, Layer 1
Failed to find [PseudoColor 8 bit] visual
Check AGX_VISUAL_DEPTH and AGX_VISUAL_TYPE
and ensure that the X Server has this type of visual available
PVM daemon pvmd will remain running for later processes
离线yinniy00001
161
65
只看该作者 8楼 发表于: 2015-05-11 | 石油求职招聘就上: 阿果石油英才网
看不懂啊,学些了......
离线lyhinsohu
507
728
只看该作者 7楼 发表于: 2014-10-14 | 石油求职招聘就上: 阿果石油英才网
回 wyanforme 的帖子
wyanforme:Promax R5000出来的东西如何传给地震用?R2003可以直接传的! (2014-10-14 17:08)
你说的传给地震用什么意思?
离线wyanforme
54
13
只看该作者 6楼 发表于: 2014-10-14 | 石油求职招聘就上: 阿果石油英才网
离线wwwjianbin
512
534
只看该作者 5楼 发表于: 2014-10-14 | 石油求职招聘就上: 阿果石油英才网
R5000也遇到过静校正层位数不能超过20的问题,郁闷
世上无难事,只要肯折腾!
离线hbc2000
23
只看该作者 4楼 发表于: 2014-09-28 | 石油求职招聘就上: 阿果石油英才网
学习了,东西好东西
离线lyhinsohu
507
728
只看该作者 3楼 发表于: 2014-09-26 | 石油求职招聘就上: 阿果石油英才网
回 allex02 的帖子
allex02:Fatal error occurred on 23-Sep-14 at 18:37:03
Message is:
initColors failed:
....... (2014-09-25 21:49)
问题我也发现了,就是不知道好的解决办法,8bit的ColorDepth真是惨不忍睹。
离线allex02
2316
20054
345
只看该作者 2楼 发表于: 2014-09-25 | 石油求职招聘就上: 阿果石油英才网
Message is:
initColors failed:
致命的错误!
离线lyhinsohu
507
728
只看该作者 1楼 发表于: 2014-09-25 | 石油求职招聘就上: 阿果石油英才网
虽然有变通方法解决这个问题,但是都不是完美方法。
变通方法一: 在vncviewer中运行promax
变通方法二: 直接降低桌面的颜色深度为8bit
方法一稍微好一点。
谁有更好的办法,希望共享出来。
1条评分财富+15
allex02 财富 +15 技术交流 2014-09-25
