这是石油出版社2016年出版的新书,能有半部已经很不错啦
看目录,这是原版2011年第一版的中译本
此书2015年又出新本,第二版啦,仍然11章,但其中小节有些变化。
原版第一版494页,第二版512页,变化不大。
第二版目录
Table of ContentsChapter 1: Rocks—Their Classification and General Properties- Abstract
- 1.1 Introduction
- 1.2 Igneous Rocks
- 1.3 Metamorphic Rocks
- 1.4 Sedimentary Rocks
- 1.5 Physical Properties of Rocks—Some General Characteristics
- 1.6 Measurements of Rock Samples and Core Analysis
Chapter 2: Pore Space Properties- Abstract
- 2.1 Introduction
- 2.2 Porosity
- 2.3 Specific Internal Surface
- 2.4 Fluids in the Pore Space—Saturation and Bulk Volume Fluid
- 2.5 Permeability
- 2.6 Capillary Pressure
- 2.7 The Digital Core—A Look into the Pore Space
Chapter 3: Nuclear Magnetic Resonance (NMR): Petrophysical Properties- Abstract
- 3.1 Introduction
- 3.2 The Principle of an NMR Measurement
- 3.3 NMR Relaxation Mechanisms of Fluids in Pores and Fluid-Surface Effects
- 3.4 Applications
Chapter 4: Density- Abstract
- 4.1 Definition and Units
- 4.2 Density of Rock Constituents
- 4.3 Density of Rocks
Chapter 5: Nuclear/Radioactive Properties- Abstract
- 5.1 Fundamentals
- 5.2 Natural Radioactivity
- 5.3 Interactions of Gamma Radiation
- 5.4 Interactions of Neutron Radiation
- 5.5 Application of Nuclear Measurements for a Mineral Analysis
- 5.6 Combination of Gamma–Gamma Density and Neutron Porosity—Multiple Porosity Methods
Chapter 6: Elastic Properties- Abstract
- 6.1 Fundamentals
- 6.2 Principles of Laboratory Measurements
- 6.3 Elastic Properties of the Rock Constituents
- 6.4 Velocity of Rocks—Overview
- 6.5 Velocity of Igneous and Metamorphic Rocks
- 6.6 Velocity of Sedimentary Rocks
- 6.7 Anisotropy
- 6.8 Theories
- 6.9 Reservoir Properties from Seismic Parameters
- 6.10 Attenuation of Elastic Waves
Chapter 7: Geomechanical Properties- Abstract
- 7.1 Overview: Introduction
- 7.2 Classification Parameters
- 7.3 Fundamental Geomechanical Properties and Processes
- 7.4 Correlation Between Static and Dynamic Moduli
- 7.5 Correlation Between Seismic Velocity and Strength Properties
- 7.6 Some Remarks About Shale Brittleness
Chapter 8: Electrical Properties- Abstract
- 8.1 Fundamentals
- 8.2 Electrical Properties of Rock Components
- 8.3 Specific Electrical Resistivity of Rocks
- 8.4 Clean Rocks—Theories and Models
- 8.5 Rocks with Electrolytic Conductivity and a Second Conductivity Component—Shaly Rocks, Shaly Sands
- 8.6 Laminated Shaly Sands and Laminated Sands—Macroscopic Anisotropy
- 8.7 Dielectric Properties of Rocks
- 8.8 Complex Resistivity—Spectral Induced Polarization
Chapter 9: Thermal Properties- Abstract
- 9.1 Introduction
- 9.2 Thermal Properties of Minerals and Pore Contents
- 9.3 Thermal Properties of Rocks—Experimental Data
- 9.4 Theories and Models
- 9.5 Relationships Between Thermal Conductivity and Elastic Wave Velocities
Chapter 10: Magnetic Properties- Abstract
- 10.1 Fundamentals and Units
- 10.2 Magnetic Properties of Rock Constituents
- 10.3 Magnetic Properties of Rocks
Chapter 11: Model Equations and Excel Worksheets- Abstract
- 11.1 Mixing Rules and Models for Electrical and Thermal Properties
- 11.2 Excel Worksheets for Model Calculations
Appendix- Appendix A Physical Properties of Rock-Forming Minerals
- Appendix B Some Conversions
References
