Angle Pattern 角型(阀)
Angle Stop Valves 角式截止阀
Angle Throttle Valves 角式节流阀
Angle Type Globe Valves 角式截止阀
Axes Guide 轴套
Applicable media 适用介质
Applicable tempure 适用温度
Air valves 空气阀门
Angle Stop valves 角式截止阀
Ash valves 排灰阀
Aspirating valves 吸(抽)气阀
Auxiliary valves 辅助(副)阀
API gate valve series 美标闸阀系列
B.
Backseat Bushing 上密封螺母
Balance valves 平衡阀
Body Nut 阀体螺母
Bonnet Cap Nut 阀盖罩螺母
Bonnet Bolt Nut 阀盖螺栓螺母
Bonnet Cap Bolt 盖罩螺栓
Bonnet Bolt 阀盖螺栓
Body Bolt 阀体螺栓
Bonnet Gasket 阀盖垫圈
Body Gasket 阀体垫圈
Bonnet 阀盖
Bonnet Cap 阀盖罩
Bolted Bonnet 法兰阀盖
Bushing 衬套
Bronze Mounted 青铜安装架
Butterfly Handle Nut 蝶型手柄螺母
Butterfly Handle 蝶型手柄
bolt circle 螺栓外径
Body - Lug 阀体- 吊耳
Booted Liner 密封罩衬垫
Body Seal 阀体密封
Body (Wafer) 阀体(平板)
Ball 球体(关闭件)(球、球芯)
Body Insert 阀体衬垫
Belleville Washer Belleville 垫圈
Body Endpiece 阀体端口
BODY AND END PIECE 阀体和端口
Butterfly Type Non-slam Check 蝶式缓冲止回阀
Butterfly Valves with Gear Actuator 蜗轮传动蝶阀
Ball seat 密封圈
Blowdown Sealing Face 启、阀件密封面
Body 阀体
Bonnet 阀盖
Butt Clamp 对夹
Buna-N rubber 丁晴橡胶
Bellows valves 波纹管阀
Blowdown valves 泄料(放空,排污)阀
Brake valves 制动阀
Buttwelding valves 对焊连接阀
Butterfly valve 蝶阀
Backseat Test 上密封试验
BUBBLE TIGHT SHUT-OFF 不透气关闭
C.
Control Valve Stem 控制阀杆
Control Valve Pack Nut 控制阀组合螺母
Control Valve Pack Gland 控制阀组合盖
Control Valve Packing 控制阀填料
Control Valve Body 控制阀体
Collar Bushing 轴环衬套
Cap 阀盖
Cock 二通
Cover 阀盖
CQ Thread Ball Valves CQ 螺纹球阀
Chemical anaiysis 化学成份
Connecting format 连接形式
Casting aluminium brass 铸铝黄铜
Casting aluminium bronze 铸铝青铜
CHR rubber 氯晴橡胶
Chrominm-molybdenum-vanadium steel 铬钼钒钢
Chromium stainless steel 铬不锈钢
Chromium-molybdenum steel 铬钼钢
Corrugation pad 波形垫
Cuprum alloy 铜合金
Clamp valves 对夹式阀门
Cock 二通
Combination valves 组合阀
Culvert valves 地下管道阀
Cut-off valve 截止阀
Check valve 止回阀
D.
Disc 阀瓣(蝶板)
Disc Cage 阀瓣座
Disc Plate 阀瓣板
Disc Nut 阀瓣螺母
Disc Pilot 阀瓣导杆
Disc Ring 阀瓣垫圈
Disc Holder Nut 阀瓣基座螺母
Disc Holder 阀瓣基座
Dashpot 减振器
Dashpot Gasket 减振器垫圈
Disc Cage 阀瓣槽
Disc Plate & Nut 阀瓣板与螺母
Disc Face Ring 阀瓣表面垫圈
Disc Hinge Pin 阀瓣销轴
Disc Thrust Bearing 阀瓣止推轴承
Disc Bolt 阀瓣螺栓
Disc Nut 阀瓣螺母
Disc Stop Pin 阀瓣锁销
Dust Plug 防尘塞
Dust Seal 防尘密封
Diaphragm Valves 隔膜阀
Double Disc Flat Gate Valves 双闸板平板闸阀
Double Disk Parallel Gate Valves 明杆平行式双闸板闸板
Double Opening Exhaust Valves 双口排气球
Double disc 双闸板
Ductile Cast iron 球墨铸铁
Decompression valves 泄压阀
Drainage valves 排水阀
Deceleration valves 减速阀
E.
Electric Actuated Stop Valves 电动截止阀
Electric Actuated Wedge Gate Valves 电动楔式闸阀
Electric Double Disk Parallel Gate Valves 电动平行式双闸板闸板
Emergeny Cut-off Valves 紧急切断阀
Expanded graphite 柔性石墨
Exhaust valves 排气阀
Electric remote-control valve 电动遥控阀
end cap 端盖
F.
Full Plug 全插销
Free Float Type Steam Trap 浮球式疏水阀
Flange Ball Valves 法兰球阀
Flange Gate Valves 法兰闸阀
Flange Globe Valves 法兰截止阀
Flexible disc 弹性闸板
Flange 法兰
Fine Steel Casting iron 优质碳素钢
Fluorous rubber 氟橡胶
Flow-control valve 流量控制阀
Flanged Connection Dimensions 法兰连接尺寸
Face To Face 结构长度
G.
Gland Follower Nut 料盖随动件螺母Gland Follower Bolt 填料盖随动件螺栓
Gland Follower 料盖随动件Grease Fitting 润滑器
Gland Follower Stud 料盖随动件双头螺栓Gear Operator 蜗轮操作装置
Grounding Washer 基座垫圈Gland Nut 密封压盖螺母
Gauge Valves 仪表阀
Gray Cast iron 灰铸铁
H.
Handwheel Nut 手轮螺母
Hand wheel 手轮
Hex Head Cap Screws 六角头螺栓罩
Horizontal Swing 水平直通旋启式
Hinge Pin Retainer 销轴定位器
Hanger 销
Hanger Pin 销轴
