The PVT simulation package PVTsim is being used by leading oil producing and operating companies throughout the world. Based on an extensive data material collected over a period of more than 20 years, PVTsim carries the information from experimental PVT studies into simulation software in a consistent manner and without loosing valuable information on the way. PVTsim allows reservoir engineers, flow assurance specialists and process engineers to combine reliable fluid characterization procedures with robust and efficient regression algorithms to match fluid properties and experimental data. The fluid parameters may be exported to produce high quality input data for reservoir, pipeline and process simulators. PVTsim is petroleum phase behavior at the tip of your fingers. 游戏~
