  • 3654阅读
  • 9回复
[分享]【原创】备份:压汞数据统计宏程序 [复制链接]
离线阿果
10085
62933
2083
62
只看楼主 倒序阅读 使用道具 0楼 发表于: 2007-12-05 | 石油求职招聘就上: 阿果石油英才网
居然没放这里,针对西南油田分公司研究院做的压汞资料进行数据统计,半自动化,提高工作效率。
自用备份,加密很高,其他人用不上,其实就是简单的宏代码而已。
  1. Sub 宏3()
  2. '
  3. ' 宏3 Macro
  4. ' chen guo 记录的宏 2006-4-18
  5. '
  6. ' 快捷键: Ctrl+q
  7. '
  8.     Range("B2").Select
  9.     Selection.Copy
  10.     Sheets("Sheet1").Select
  11.     Range("A3").Select
  12.     ActiveSheet.Paste
  13.     Sheets("Sheet2").Select
  14.     Range("F2").Select
  15.     Application.CutCopyMode = False
  16.     Selection.Copy
  17.     Sheets("Sheet1").Select
  18.     Range("B3").Select
  19.     ActiveSheet.Paste
  20.     Sheets("Sheet2").Select
  21.     Range("B4").Select
  22.     Application.CutCopyMode = False
  23.     Selection.Copy
  24.     Sheets("Sheet1").Select
  25.     Range("C3").Select
  26.     ActiveSheet.Paste
  27.     Sheets("Sheet2").Select
  28.     Range("F4").Select
  29.     Application.CutCopyMode = False
  30.     Selection.Copy
  31.     Sheets("Sheet1").Select
  32.     Range("D3").Select
  33.     ActiveSheet.Paste
  34.     Sheets("Sheet2").Select
  35.     Range("C9").Select
  36.     Application.CutCopyMode = False
  37.     Selection.Copy
  38.     Sheets("Sheet1").Select
  39.     Range("E3").Select
  40.     ActiveSheet.Paste
  41.     Sheets("Sheet2").Select
  42.     Range("G9").Select
  43.     Application.CutCopyMode = False
  44.     Selection.Copy
  45.     Sheets("Sheet1").Select
  46.     Range("F3").Select
  47.     ActiveSheet.Paste
  48.     Sheets("Sheet2").Select
  49.     Range("C10").Select
  50.     Application.CutCopyMode = False
  51.     Selection.Copy
  52.     Sheets("Sheet1").Select
  53.     Range("G3").Select
  54.     ActiveSheet.Paste
  55.     Sheets("Sheet2").Select
  56.     Range("G10").Select
  57.     Application.CutCopyMode = False
  58.     Selection.Copy
  59.     Sheets("Sheet1").Select
  60.     Range("H3").Select
  61.     ActiveSheet.Paste
  62.     Sheets("Sheet2").Select
  63.     Range("G11").Select
  64.     Application.CutCopyMode = False
  65.     Selection.Copy
  66.     Sheets("Sheet1").Select
  67.     Range("I3").Select
  68.     ActiveSheet.Paste
  69.     Sheets("Sheet2").Select
  70.     Range("G12").Select
  71.     Application.CutCopyMode = False
  72.     Selection.Copy
  73.     Sheets("Sheet1").Select
  74.     Range("J3").Select
  75.     ActiveSheet.Paste
  76.     Sheets("Sheet2").Select
  77.     Range("G13").Select
  78.     Application.CutCopyMode = False
  79.     Selection.Copy
  80.     Sheets("Sheet1").Select
  81.     Range("K3").Select
  82.     ActiveSheet.Paste
  83.     Sheets("Sheet2").Select
  84.     Range("G14").Select
  85.     Application.CutCopyMode = False
  86.     Selection.Copy
  87.     Sheets("Sheet1").Select
  88.     Range("L3").Select
  89.     ActiveSheet.Paste
  90.     Sheets("Sheet2").Select
  91.     Range("B13").Select
  92.     Application.CutCopyMode = False
  93.     Selection.Copy
  94.     Sheets("Sheet1").Select
  95.     Range("M3").Select
  96.     ActiveSheet.Paste
  97.     Sheets("Sheet2").Select
  98.     Range("B11").Select
  99.     Application.CutCopyMode = False
  100.     Selection.Copy
  101.     Sheets("Sheet1").Select
  102.     Range("N3").Select
  103.     ActiveSheet.Paste
  104.     Sheets("Sheet2").Select
  105.     Range("B14").Select
  106.     Application.CutCopyMode = False
  107.     Selection.Copy
  108.     Sheets("Sheet1").Select
  109.     Range("O3").Select
  110.     ActiveSheet.Paste
  111.     Sheets("Sheet2").Select
  112.     Range("B12").Select
  113.     Application.CutCopyMode = False
  114.     Selection.Copy
  115.     Sheets("Sheet1").Select
  116.     Range("P3").Select
  117.     ActiveSheet.Paste
  118.     ActiveWindow.LargeScroll ToRight:=1
  119.     ActiveWindow.ScrollColumn = 6
  120.     Sheets("Sheet2").Select
  121.     Range("B19").Select
  122.     Sheets("Sheet1").Select
  123.     ActiveWindow.SmallScroll ToRight:=1
  124.     Sheets("Sheet2").Select
  125.     Range("B19:G19").Select
  126.     Application.CutCopyMode = False
  127.     Selection.Copy
  128.     Sheets("Sheet1").Select
  129.     Range("Q3").Select
  130.     ActiveSheet.Paste
  131.     ActiveWindow.SmallScroll ToRight:=1
  132.     Sheets("Sheet2").Select
  133.     Range("B20:G20").Select
  134.     Application.CutCopyMode = False
  135.     Selection.Copy
  136.     Sheets("Sheet1").Select
  137.     Range("W3").Select
  138.     ActiveSheet.Paste
  139.     ActiveWindow.LargeScroll ToRight:=1
  140.     Sheets("Sheet2").Select
  141.     Range("B21:G21").Select
  142.     Application.CutCopyMode = False
  143.     Selection.Copy
  144.     Sheets("Sheet1").Select
  145.     Range("AC3").Select
  146.     ActiveSheet.Paste
  147.     Sheets("Sheet2").Select
  148.     Range("B22:G22").Select
  149.     Application.CutCopyMode = False
  150.     Selection.Copy
  151.     Sheets("Sheet1").Select
  152.     Range("AI3").Select
  153.     ActiveSheet.Paste
  154.     Sheets("Sheet2").Select
  155.     Range("B23:G23").Select
  156.     Application.CutCopyMode = False
  157.     Selection.Copy
  158.     Sheets("Sheet1").Select
  159.     Range("AO3").Select
  160.     ActiveSheet.Paste
  161.     ActiveWindow.LargeScroll ToRight:=1
  162.     Sheets("Sheet2").Select
  163.     Range("B24:G24").Select
  164.     Application.CutCopyMode = False
  165.     Selection.Copy
  166.     Sheets("Sheet1").Select
  167.     Range("AU3").Select
  168.     ActiveSheet.Paste
  169.     Sheets("Sheet2").Select
  170.     Range("B25:G25").Select
  171.     Application.CutCopyMode = False
  172.     Selection.Copy
  173.     Sheets("Sheet1").Select
  174.     Range("BA3").Select
  175.     ActiveSheet.Paste
  176.     ActiveWindow.LargeScroll ToRight:=1
  177.     ActiveWindow.SmallScroll ToRight:=-1
  178.     Sheets("Sheet2").Select
  179.     Range("B26:G26").Select
  180.     Application.CutCopyMode = False
  181.     Selection.Copy
  182.     Sheets("Sheet1").Select
  183.     Range("BG3").Select
  184.     ActiveSheet.Paste
  185.     Sheets("Sheet2").Select
  186.     Range("B27:G27").Select
  187.     Application.CutCopyMode = False
  188.     Selection.Copy
  189.     Sheets("Sheet1").Select
  190.     Range("BM3").Select
  191.     ActiveSheet.Paste
  192.     Sheets("Sheet2").Select
  193.     Range("B28:G28").Select
  194.     Application.CutCopyMode = False
  195.     Selection.Copy
  196.     Sheets("Sheet1").Select
  197.     Range("BS3").Select
  198.     ActiveSheet.Paste
  199.     ActiveWindow.SmallScroll ToRight:=12
  200.     Sheets("Sheet2").Select
  201.     Range("B29:G29").Select
  202.     Application.CutCopyMode = False
  203.     Selection.Copy
  204.     Sheets("Sheet1").Select
  205.     Range("BY3").Select
  206.     ActiveSheet.Paste
  207.     Sheets("Sheet2").Select
  208.     Range("B30:G30").Select
  209.     Application.CutCopyMode = False
  210.     Selection.Copy
  211.     Sheets("Sheet1").Select
  212.     Range("CE3").Select
  213.     ActiveSheet.Paste
  214.     ActiveWindow.SmallScroll ToRight:=12
  215.     Sheets("Sheet2").Select
  216.     Range("B31:G31").Select
  217.     Application.CutCopyMode = False
  218.     Selection.Copy
  219.     Sheets("Sheet1").Select
  220.     Range("CK3").Select
  221.     ActiveSheet.Paste
  222.     Sheets("Sheet2").Select
  223.     Range("B32:G32").Select
  224.     Application.CutCopyMode = False
  225.     Selection.Copy
  226.     Sheets("Sheet1").Select
  227.     Range("CQ3").Select
  228.     ActiveSheet.Paste
  229.     ActiveWindow.SmallScroll ToRight:=13
  230.     Sheets("Sheet2").Select
  231.     Range("B33:G33").Select
  232.     Application.CutCopyMode = False
  233.     Selection.Copy
  234.     Sheets("Sheet1").Select
  235.     Range("CW3").Select
  236.     ActiveSheet.Paste
  237.     Sheets("Sheet2").Select
  238.     Range("B34:G34").Select
  239.     Application.CutCopyMode = False
  240.     Selection.Copy
  241.     Sheets("Sheet1").Select
  242.     Range("DC3").Select
  243.     ActiveSheet.Paste
  244.     ActiveWindow.SmallScroll ToRight:=14
  245.     Sheets("Sheet2").Select
  246.     Range("B35:G35").Select
  247.     Application.CutCopyMode = False
  248.     Selection.Copy
  249.     Sheets("Sheet1").Select
  250.     Range("DI3").Select
  251.     ActiveSheet.Paste
  252.     Sheets("Sheet2").Select
  253.     Range("B36:G36").Select
  254.     Application.CutCopyMode = False
  255.     Selection.Copy
  256.     Sheets("Sheet1").Select
  257.     Range("DO3").Select
  258.     ActiveSheet.Paste
  259.     Sheets("Sheet2").Select
  260.     Range("B37:G37").Select
  261.     Application.CutCopyMode = False
  262.     Selection.Copy
  263.     Sheets("Sheet1").Select
  264.     Range("DU3").Select
  265.     ActiveSheet.Paste
  266.     ActiveWindow.SmallScroll ToRight:=19
  267.     Sheets("Sheet2").Select
  268.     Range("B38:G38").Select
  269.     Application.CutCopyMode = False
  270.     Selection.Copy
  271.     Sheets("Sheet1").Select
  272.     Range("EA3").Select
  273.     ActiveSheet.Paste
  274.     Sheets("Sheet2").Select
  275.     Range("B39:G39").Select
  276.     Application.CutCopyMode = False
  277.     Selection.Copy
  278.     Sheets("Sheet1").Select
  279.     Range("EG3").Select
  280.     ActiveSheet.Paste
  281.     Sheets("Sheet2").Select
  282.     Range("B40:G40").Select
  283.     Application.CutCopyMode = False
  284.     Selection.Copy
  285.     Sheets("Sheet1").Select
  286.     Range("EM3").Select
  287.     ActiveSheet.Paste
  288.     ActiveWindow.SmallScroll ToRight:=16
  289.     Sheets("Sheet2").Select
  290.     Range("B41:G41").Select
  291.     Application.CutCopyMode = False
  292.     Selection.Copy
  293.     Sheets("Sheet1").Select
  294.     Range("ES3").Select
  295.     ActiveSheet.Paste
  296.     Sheets("Sheet2").Select
  297.     Range("B42:G42").Select
  298.     Application.CutCopyMode = False
  299.     Selection.Copy
  300.     Sheets("Sheet1").Select
  301.     Range("EY3").Select
  302.     ActiveSheet.Paste
  303.     Sheets("Sheet2").Select
  304. End Sub
描述: 压汞数据统计程序
附件: 压汞数据统计方法.rar (46 K) 下载次数:2 ,你所在用户组没有附件下载权限 VIP会员免积分下载 ,该附件已加密,拥有1威望才能下载
石油行业最新求职招聘信息,上阿果石油英才网:http://www.cnpcjob.com/
石油行业最新产品供应求购信息,上阿果石油供需网:http://b2b.agoil.cn/
石油文献资料预览下载,上石油文库:http://www.oilwenku.com/
网站事务联系QQ:1392013
个人微博:http://weibo.com/028chenguo
离线eclipse
1929
1931
234
只看该作者 1楼 发表于: 2007-12-29 | 石油求职招聘就上: 阿果石油英才网
录制的?好累缀
本人所回复内容为网络提供,内容的真实、准确和合法性由国际互联网负责,本人对此不承担任何责任。
离线心平气和
1399
1778
190
只看该作者 2楼 发表于: 2008-06-19 | 石油求职招聘就上: 阿果石油英才网
500个威望,让人感觉更神密了!!!
离线wangxx
1097
1308
只看该作者 3楼 发表于: 2008-08-03 | 石油求职招聘就上: 阿果石油英才网
能不能降低威望,这样一般人都看不了啊!
离线阿果
10085
62933
2083
62
只看该作者 4楼 发表于: 2008-08-04 | 石油求职招聘就上: 阿果石油英才网
引用第3楼wangxx于2008-08-03 15:47发表的  :
能不能降低威望,这样一般人都看不了啊!
宏程序的源代码都给出来了,根本不需要下载那个文件。
网站事务联系QQ:1392013
离线wangxx
1097
1308
只看该作者 5楼 发表于: 2008-08-05 | 石油求职招聘就上: 阿果石油英才网
请问楼主,根据压汞数据做“喉道半径与渗透率贡献率”关系曲线,用的是进汞曲线的数据还是退汞曲线的数据?
离线wangxx
1097
1308
只看该作者 6楼 发表于: 2008-08-05 | 石油求职招聘就上: 阿果石油英才网
还请教楼主:平均孔隙半径和半径均值一样吗,或者有什么区别?以上公式哪个是求均值比较权威的算法?
离线阿果
10085
62933
2083
62
只看该作者 7楼 发表于: 2008-08-05 | 石油求职招聘就上: 阿果石油英才网
to wangxx : 建议向李传亮教授请教这两个问题,我也说不清楚,1年多没有和压汞数据打交道了,生疏了。
网站事务联系QQ:1392013
离线equivalent
172
455
46
只看该作者 8楼 发表于: 2012-02-24 | 石油求职招聘就上: 阿果石油英才网
看来下不了了,威望太高了
离线ysushy19
122
34
只看该作者 9楼 发表于: 2012-05-31 | 石油求职招聘就上: 阿果石油英才网
录制个宏,还要这么高威望,还不如贴出公式实用
