Paper Number 99371-MS
DOI What's this? 10.2118/99371-MS
Title When and Where Relative Permeability Modification Water-Shutoff Treatments Can Be Successfully Applied
Authors R.D. Sydansk, SPE, Sydansk Consulting Services, and R.S. Seright, SPE, New Mexico Petroleum Recovery Research Center
Source SPE/DOE Symposium on Improved Oil Recovery, 22-26 April 2006, Tulsa, Oklahoma, USA
Copyright 2006. Society of Petroleum Engineers
Preview Abstract
This paper provides guidance on when and where relative-permeabiliy-modification/disproportionate-permeability-reduction (RPM/DPR) water-shutoff (WSO) treatments can be successfully applied for use in either oil or gas production wells. When properly designed and executed, these treatments can be successfully applied to a limited range of oilfield excessive-water-production problems. When these treatments are applicable, they may be placed using bullhead injection (not requiring mechanical zone isolation)—a very favorable feature. However, there are a substantial number of limitations and possible pitfalls relating to the successful application of RPM/DPR WSO treatments. First-time application by an inexperienced operator should be considered a somewhat high-risk undertaking. In order to successfully treat unfractured production wells (i.e., radial flow through matrix rock into the well) that are fully drawn down, the oil and water zones should not be in pressure communication and the oil-producing zone(s) must be producing at 100% oil cut (dry oil). When treating unfractured and multi-zoned production wells that are not fully drawn down, the well’s long-term oil-production rate can be increased if the post-treatment drawdown is increased substantially. Treatments that promote short-term (transient) decreased water/oil ratios can, in principle, be applied to many unfractured production wells (that are not totally watered out) in matrix rock reservoirs. However, these latter treatments must be custom designed and engineered on a well-by-well basis. Furthermore, for most wells, the performance and the economics of such transient WSO treatments are generally marginal. An attractive application of RPM/DPR WSO treatments is the use of robust pore-filling gels in the matrix reservoir rock that is adjacent to a fracture(s) when oil and water is being co-produced into the treated fracture.
