上面是破解补丁的版本
我下载安装Petrel2005后,把破解补丁和lisence打上以后,还是无法运行,出现"No Petrel license packages were found in the FLEXlm license file"
具体日志如下,请高人指点:
4:16:03 (lmgrd) -----------------------------------------------
4:16:03 (lmgrd) Please Note:
4:16:03 (lmgrd)
4:16:03 (lmgrd) This log is intended for debug purposes only.
4:16:03 (lmgrd) There are many details in licensing policies
4:16:03 (lmgrd) that are not reported in the information logged
4:16:03 (lmgrd) here, so if you use this log file for any kind
4:16:03 (lmgrd) of usage reporting you will generally produce
4:16:03 (lmgrd) incorrect results.
4:16:03 (lmgrd)
4:16:03 (lmgrd)
4:16:03 (lmgrd)
4:16:03 (lmgrd) Done rereading
4:16:03 (lmgrd) FLEXlm (v9.50) started on IBM-ld (IBM PC) (4/1/2008)
4:16:03 (lmgrd) Copyright (c) 1988-2004 by Macrovision Corporation. All rights reserved.
4:16:03 (lmgrd) US Patents 5,390,297 and 5,671,412.
4:16:03 (lmgrd) World Wide Web:
http://www.macrovision.com 4:16:03 (lmgrd) License file(s): C:\Program Files\Schlumberger\Flexlm95\license.dat
4:16:03 (lmgrd) lmgrd tcp-port 27009
4:16:03 (lmgrd) Starting vendor daemons ...
4:16:03 (lmgrd) Started lmgrd.slb (pid 2028)
4:16:04 (lmgrd) lmgrd.slb using TCP-port 1032
istent authentication code)
4:16:03 (lmgrd.slb) ==>FEATURE Petrel_20050409_4294967295 lmgrd.slb 838 permanent 10 \
D6FFBC520B8FE463 ISSUER=sl ck=207 SIGN2="DEAD BEEF DEAD BEEF \
DEAD BEEF DEAD BEEF DEAD BEEF DEAD BEEF DEAD BEEF C0DE"
4:16:03 (lmgrd.slb) Server started on IBM-ld
[ 此贴被dwg123在2008-12-03 21:38重新编辑 ]
