  • 785阅读
  • 3回复
[应助成功]求助SD文献2篇 [复制链接]
离线gmail
383
1494
53
只看楼主 倒序阅读 使用道具 0楼 发表于: 2008-04-25 | 石油求职招聘就上: 阿果石油英才网
— 本帖被 坐看云起 执行加亮操作(2008-04-26) —
第1篇:
标题:Hydromechanical interactions in a fractured carbonate reservoir inferred from hydraulic and mechanical measurements
作者:F. Cappaa, , , Y. Guglielmia, P. Fénartb, V. Merrien-Soukatchoffc and A. Thoraval
相关信息:Accepted 5 November 2004.  Available online 31 December 2004.
Abstract:
Hydromechanical coupled processes in a shallow fractured carbonate reservoir rock were investigated through field experiments coupled with analytical and numerical analyses. The experiments consist of hydraulic loading/unloading of a water reservoir in which fluid flow occurs mainly inside a heterogeneous fracture network made up of vertical faults and bedding planes. Hydromechanical response of the reservoir was measured using six pressure–normal displacement sensors located on discontinuities and two surface tiltmeters. A dual hydraulic behavior was characterized for low-permeability bedding planes well connected to high-permeability faults. Displacement responses show high-variability, nonlinear changes, sometimes with high-frequency oscillations, and a large scattering of magnitudes. Initial normal stiffnesses and effective normal stresses along fault planes were estimated in the field by interpreting pressure–normal displacement relations with a nonlinear function between effective normal stress and normal displacement. Two-dimensional discontinuum modeling with transient fluid flow was performed to fit measurements during hydraulic loading tests. Results show that the hydromechanical behavior of the reservoir is restored if a high stiffness contrast is allocated between low- and high-permeability discontinuities. Thus, a dual-permeability network of discontinuities will likely also be a contrasting stiffness network, in which the deformation of major flow-conducting discontinuities is significantly influenced by the stiffness of the surrounding less-permeable discontinuities.
Keywords: Hydromechanical coupling; Fractured rocks; Mechanical; Permeability; In situ measurements
第2篇
标题:The hydromechanical behaviour of a fracture: an in situ experimental case study
作者:F. H. Cornet, , a, L. Lia, J. -P. Hulinb, I. Ippolitoc and P. Kurowski
相关信息:Accepted 10 July 2003. ; Available online 17 September 2003.
Abstract
Relationships between flow distributions and mechanical opening in a single natural fracture are investigated in situ through field experiments, at a scale of about 1 m, in a granitic quarry. Experiments have been conducted at various injection flow-rates while the normal stress applied to the fracture was controlled by hydraulic flat jacks. Variations of the collected flow-rate (monitored through contiguous flow collectors distributed along the fracture periphery) with the injection pressure are fully reproducible. They show that the fracture opens only above a threshold pressure which increases with the externally applied stress. This threshold is non-zero with no applied flat jacks pressure which raises questions on the reliability of hydraulic jacking techniques for the measurement of the normal stress on preexisting fractures. It is shown that equivalent hydraulic aperture and mechanical opening are comparable only above a critical mean fracture opening estimated to be around 15–20 μm for the tested granite. For mean fracture openings smaller than this value, the standard time scale used for stress measurements distorts the results. It is also shown that channeling effects may control flow away from the injection hole so that the hydraulic jacking stress measurement technique may overestimate the mean normal stress acting on the fracture plane by as much as 4 MPa. It is concluded that hydraulic testing techniques for normal stress measurements should not include results from the fracture opening phase. Moreover, criteria should be established for validating results from the closing phase in order to demonstrate the absence of channelling effects. Finally, it is shown that, because of the elastic response of the rock, water injection in a fracture system decreases the interstitial pressure ahead of the increasing pressure front associated with the water flow.
Author Keywords: Fractures; Flow; Stress; Hydromechanical
PACS classification codes: 91.60.Ba; 47.55.Mh
[ 此贴被rendelu在2008-04-26 14:54重新编辑 ]
离线undercooling
994
只看该作者 1楼 发表于: 2008-04-26 | 石油求职招聘就上: 阿果石油英才网
111 ok
文件名: 111111111111111111.pdf 下载链接: http://www.fs2you.com/files/1fca3114-1350-11dd-8f70-0014221f3995/
坐看云起 财富 +15 应助奖励 2008-04-26
离线undercooling
994
只看该作者 2楼 发表于: 2008-04-26 | 石油求职招聘就上: 阿果石油英才网
22 ok
文件名: 222222222222.pdf 下载链接: http://www.fs2you.com/files/4643558f-1350-11dd-8204-0014221b798a/
离线gmail
383
1494
53
只看该作者 3楼 发表于: 2008-04-26 | 石油求职招聘就上: 阿果石油英才网
谢谢undercooling提供的文献!
