  • 1893阅读
  • 6回复
[吃喝玩乐]汽车省油 10 法 [复制链接]
离线magic1973
1141
322
45
只看楼主 倒序阅读 使用道具 0楼 发表于: 2008-05-06 | 石油求职招聘就上: 阿果石油英才网
你知道这儿有很多方法都能帮你节省大量汽车油耗而无需大动干戈吗?它不但帮你节省省开支,也能挽救我们的星球。
1.缓慢加速,避免急速刹车:急加速和急刹车会消耗更多燃料,据估计平稳驾车的燃耗相对减少30%。
2. 尽可能少使用空调,比较而言,使用空调的燃耗相会增加近10%。
3. 保持限速内行驶, 除了法律约束的原因外,这样的费用会更便宜些。
4.避免装行李架或箱子,如果在假期,到达目的地后箱子要取出来。
5.确定你的轮胎压力正常:切记在车子冷却却后检查胎压,这个工作要在开车之前进行而不是在途中。
6.不要让你的车子空转。启动后马上开动,不要等车加热。如果平缓的开动,车子同样会加热没有问题。
7.车内不必要的物品都应清除出去。负重越多,油耗越大。
8.在周围最便宜的加油站加油是非常值得的。它一年能为你省下大概??100.
  9. 避免短途开车,用步行或公共交通工具代替,这对自己和整个环境都有益。
10. 规划你的开车路线,避免诸如交通堵塞,筑路之类的耽搁以免除你的损失。
原文:Top 10 Tips for Reducing Your Car Fuel Consumption
Did you know there are ways you can actually cut down the amount of fuel you use in your car without making huge changes? Not only will it save you money it will help save the planet too.
1. Accelerate away slowly and avoid harsh braking - both use more fuel, estimated to be about 30% less with smooth driving
2. Avoid using your air conditioner as much as possible - it can increase your consumption by 10%
3. Keep to the speed limit - apart from it being the law it is also cheaper
4. Avoid using a roof-rack or box or if you are on holiday take the box off when you arrive
5. Make sure your tires are at the correct pressure: remember to check them when the car is cold, that is before not during a journey
6. Don't sit and idle your car. When you start up move off immediately, don't wait for the car to "heat up". If you are driving smoothly it will do so no problem.
7. Take out any unnecessary things from your car: the heavier the load the more fuel you use
8. It is really worth shopping around for the cheapest local petrol/gas. It could save you as much as ??100 a year.
9. Avoid taking short trips - walk instead or take public transport, it is better for you and better for the environment
10. Plan your journey to avoid delays such as traffic jams and road-works and avoid getting lost!
离线且末
250
77
只看该作者 1楼 发表于: 2008-05-06 | 石油求职招聘就上: 阿果石油英才网
没车,但是可以学习
双项基本功——地质石工
离线magic1973
1141
322
45
只看该作者 2楼 发表于: 2008-05-06 | 石油求职招聘就上: 阿果石油英才网
我一直想有辆车
离线clzcd16606
2123
368
只看该作者 3楼 发表于: 2008-05-06 | 石油求职招聘就上: 阿果石油英才网
我有一辆1.5排量的车,油耗在6-7个每百公里,很有必要学习一下节油的方法。
我们的希望都在下一代,希望他们坚强、勇敢、自信、努力、成就。。。
离线liuqing
8964
27309
只看该作者 4楼 发表于: 2016-06-14 | 石油求职招聘就上: 阿果石油英才网
有必要学习一下节油的方法。
离线liuguilong
844
2564
只看该作者 5楼 发表于: 2016-06-14 | 石油求职招聘就上: 阿果石油英才网
有必要学习一下节油的方法。
离线liuqing
8964
27309
只看该作者 6楼 发表于: 2016-09-09 | 石油求职招聘就上: 阿果石油英才网
感谢你把好的经验分享出来。
