CMG 2008.4.30推出了2008新版,模块好像没有新加的,还没有具体测试功能有什么更新。据说使用了Sentinel RMS 8加密,不过仍可使用Sentinel LM 7的LIC:
MAJOR UPDATE OF THE CMGL LICENSING
With this release, CMGL has moved entirely to Sentinel RMS 8 for
our licensing. Previously we were using Sentinel LM 7. We have
made every attempt to allow the old and new software to continue
working together with your original authorization codes. However,
several changes to how the licensing works may require you to
obtain new authorization codes.
有时间了再试试Sentinel RMS 8的LIC。
[ 此贴被dwg123在2009-04-13 08:38重新编辑 ]
