  • 2399阅读
  • 8回复
What's new in SurfSeis 2.0? [复制链接]
离线powerlw
1499
3962
只看楼主 倒序阅读 使用道具 0楼 发表于: 2008-08-26 | 石油求职招聘就上: 阿果石油英才网
— (dwg123) 发帖规范 (2008-08-26 19:16) —
SurfSeis 2 includes two modes of passive MASW (passive remote and roadside) in addition to the active MASW method covered in previous versions of SurfSeis. It can process passive (remote) surface waves recorded by using a two-dimensional (2-D) receiver array in a circular or cross (or any symmetric 2-D) layout. It can also process (roadside) surface waves recorded using a conventional linear array deployed along a road (and possibly moved in a roll-along mode) by accounting for the inherent offline nature of the incoming surface waves. It can combine active and passive surface wavefields together so that a dispersion image of broader bandwidth (and therefore a greater depth range) can be obtained. A Monte-Carlo inversion has also been added that can take into consideration the multi-modal nature of the surface wave dispersion. The previous processing mode with active data has been modified to significantly enhance the user-friendliness and reduce vulnerability to bugs. Please browse other pages at this site for more information on SurfSeis 2.0.
宠辱不惊看庭前花开花落
去留无意望天上云卷云舒
离线iask
117
18
只看该作者 1楼 发表于: 2008-08-26 | 石油求职招聘就上: 阿果石油英才网
看着不错。
不过不会用。
离线chenyaya
229
18
只看该作者 2楼 发表于: 2008-08-27 | 石油求职招聘就上: 阿果石油英才网
是现场采集用的吗?
离线jackply
269
164
只看该作者 3楼 发表于: 2008-08-27 | 石油求职招聘就上: 阿果石油英才网
不过不会用采集用的吗
离线geophylikai
1145
2086
12
只看该作者 4楼 发表于: 2008-08-27 | 石油求职招聘就上: 阿果石油英才网
KGS的面波处理软件!
和老版本相比,从新版本菜单按钮看,功能有了比较大的改变,看似带手动功能了(BOUND)
[ 此贴被geophylikai在2008-08-27 15:42重新编辑 ]
离线geophylikai
1145
2086
12
只看该作者 5楼 发表于: 2008-11-13 | 石油求职招聘就上: 阿果石油英才网
拿到了SURFSEI2的介质,修改四个字节后,程序可以运行!
试用效果感觉不如surfsei18 !
2。0的版本和之前的版本变化比较大,也可能是我用的不习惯
离线geophylikai
1145
2086
12
只看该作者 6楼 发表于: 2008-11-13 | 石油求职招聘就上: 阿果石油英才网
好象不把DEMO去掉,还是有些观测系统的数据无法处理
离线xjsegh
265
643
13
只看该作者 7楼 发表于: 2010-12-16 | 石油求职招聘就上: 阿果石油英才网
Re:What's new in SurfSeis 2.0?
能帮忙做一个license吗?
离线xf_2008
66
126
只看该作者 8楼 发表于: 2016-03-07 | 石油求职招聘就上: 阿果石油英才网
这个软件有操作手册吗
