英文文献--水平安装文丘里管流量计计量湿气
提供一篇英文文献,希望对大家有帮助。
Wet gas metering with a horizontally mounted Venturi meter.pdf
R. N. Steven, , a, b
a Flow Centre, NEL, East Kilbride, Glasgow, G75 0QU, UK b Department of Mechanical Engineering, University of Strathclyde, Glasgow, UK
Received 15 May 2001; revised 9 January 2002; accepted 9 January 2002. Available online 15 February 2002.
Abstract
Wet gas metering is becoming an increasingly important problem to the Oil and Gas Industry. The Venturi meter is a favoured device for the metering of the unprocessed wet natural gas production flows. Wet gas is defined here as a two-phase flow with up to 50% of the mass flowing being in the liquid phase. Metering the gas flowrate in a wet gas flow with use of a Venturi meter requires a correction of the meter reading to account for the liquids effect. Currently, most correlations in existence were created for Orifice Plate Meters and are for general two-phase flow. However, due to no Venturi meter correlation being published before 1997 industry was traditionally forced to use these Orifice Plate Meter correlations when faced with a Venturi metering wet gas flows. This paper lists seven correlations, two recent wet gas Venturi correlations and five older Orifice Plate general two-phase flow correlations and compares their performance with new independent data from the NEL Wet Gas Loop with an ISA Controls Ltd. Standard specification six inch Venturi meter of 0.55 beta ratio installed. Finally, a new correlation is offered.
Author Keywords: Wet gas metering; Two-phase flow metering; Venturi meter; Flow measurement
[ 此贴被笑韵在2008-08-31 19:17重新编辑 ]
