PVTsim 17.3C
Updates and Bug fixes from PVTsim 17.2 to 17.3
Error corrected in saturation point logic that might cause failure of regression when including swelling data.
Limit on number of cells in slimtube option increased to 2000. Time step and cell output frequency introduced.
Tabulated saturation pressure in Prosper/Mbal interface changed to always be the higher one (relevant for temperature tabulation points with two saturation point pressures).
Plus regression erroneously changed the Peneloux parameter of CO2 marginally. This caused problems e.g. in MMP simulations with a CO2 "No Plus" fluid as injection gas.
Error corrected in DepoWax causing the simulation results to be the same after all time steps.
The Save Phase option erroneously assigned asphaltene components an asphaltene fraction of 0.0. Corrected to be 1.0.
Error corrected in weaving option for asphaltene components.
Too low a thickness of laminar film layer in DepoWax caused too much wax deposition
