  • 187阅读
  • 1回复
SPE 107705-推荐一篇很好的煤层气论文 [复制链接]
离线hujg
3576
2091
100
只看楼主 倒序阅读 使用道具 0楼 发表于: 2008-09-10 | 石油求职招聘就上: 阿果石油英才网
— 本帖被 笑韵 从 资料上传 移动到本区(2008-10-07) —
SPE 107705 Production Data Analysis of CBM Wells_____2007 SPE Rocky Mountain Oil & Gas Technology Symposium paper
Abstract
Recent advances in production data analysis (PDA) techniques have greatly assisted engineers in extracting meaningful reservoir and stimulation information from well production and flowing pressure data. Application of these techniques to coalbed methane (CBM) reservoirs requires that the unique coal storage and transport properties be accounted for. In recent work, the authors and others have demonstrated how new techniques such as the flowing material balance (FMB)
and production type-curves may be adapted to account for CBM storage mechanisms (i.e. adsorption), but to date the focus has been on relatively simple CBM reservoir behavior.
Although adaptations of PDA to include more complex CBM reservoir characteristics were introduced, the focus of the current work is advancement of modern PDA techniques to incorporate reservoir behavior such as single-phase flow of water in undersaturated reservoirs, two-phase (gas+water) flow in saturated reservoirs, effective permeability changes during depletion, and changing gas composition due to relative adsorption. Specifically, the FMB technique is modified in
this work to include several complex CBM reservoir characteristics. FMB can be a powerful diagnostic technique when relative and absolute permeability changes are apparent during depletion. Several synthetic and field examples are given to demonstrate how FMB, type-curve analysis and
analytical simulation can be used in parallel to provide a particularly useful data analysis tool.
The adapted PDA techniques used in this work make use of the pseudotime and pseudopressure concepts, modified to account for CBM reservoir behavior, to linearize the (constant-rate) diffusivity equation for CBM. Material balance pseudotime was used to account for variable operating
conditions. These techniques were used successfully to extract quantitative reservoir information from single- and two-phase CBM simulated and field production and pressure evaluation, however.
Several key assumptions were used in deriving the PDA techniques including (but not limited to) instantaneous desorption (small sorption times) and single-layer behavior.
Although the former is not considered a serious limitation, as most commercial reservoirs analyzed to date by the authors have exhibited single-porosity behavior during production, the latter may be quite important for some producing fields. PDA of multi-layered CBM reservoirs will be discussed at length in a future paper.
[ 此贴被笑韵在2008-09-11 12:38重新编辑 ]
本主题包含附件,请 登录 后查看, 或者 注册 成为会员
笑韵 财富 +10 感谢分享 2008-09-10
离线qijiyingyu
87
49
只看该作者 1楼 发表于: 2008-09-27 | 石油求职招聘就上: 阿果石油英才网
感谢分享,非常好!
