【软件名称】 Golden Software Surfer
【软件版本】 8.0
【语言种类】 中文
【文件大小】 1.20MB
【文件格式】 pdf
【目录】
§1 Surfer 8.0软件简介...........................................................................................................1
1.1 软件运行环境及特点..........................................................................................................1
1.2 软件界面及命令菜单..........................................................................................................2
1.2.1 文件菜单(File)......................................................................................................2
1.2.2 编辑菜单(Edit).....................................................................................................2
1.2.3 查看菜单(View)...................................................................................................3
1.2.4 手工绘图菜单(Draw)...........................................................................................3
1.2.5 排列菜单(Arrange)...............................................................................................3
1.2.6 网格化菜单(Grid)................................................................................................4
1.2.7 绘图菜单(Map)....................................................................................................4
1.2.8 窗口菜单(Window)..............................................................................................5
1.2.9 帮助菜单(Help)....................................................................................................5
1.3 软件使用流程......................................................................................................................5
§2 基本图形的绘制..................................................................................................................6
2.1 建立XYZ数据文件..............................................................................................................6
2.2 数据文件的网格化(Grid)..............................................................................................6
2.3 绘制和设置等高线..............................................................................................................7
2.3.1 绘制等高线................................................................................................................7
2.3.2 等高线图的设置........................................................................................................7
2.4 绘制Wireframe.....................................................................................................................9
2.5 绘制Image Map...................................................................................................................9
2.6 绘制Shaded Relief Map.....................................................................................................10
2.7 绘制Surface Map...............................................................................................................10
2.8 在等高线图上加上背景地图(base map)..........................................................................11
2.9 bln文件及blank作图...........................................................................................................11
2.10 Post Map和Classed Post Map...........................................................................................12
2.11 vector map 向量图(或风向图)........................................................................................13
2.12 ASCII 码的grd文件.........................................................................................................14
2.13 应用Surfer给出数据文件的统计性质............................................................................16
2.14 Surfer其它功能.................................................................................................................16
§3 图形绘制的技巧................................................................................................................17
3.1 在生成grd文件时使用的插值方法..................................................................................17
3.2 Surfer如何将所绘图形进行输出.......................................................................................19
3.3 Surfer如何忽略(或设置)缺省值...................................................................................19
3.4 如何正确的设置label........................................................................................................20
3.5 overlay的含义.....................................................................................................................20
3.6 做2维矢量图可以设定不同流速用不同的箭头比例长度............................................21
3.7 如何在VB中调用Surfer 8.0..............................................................................................21
3.8 Surfer 8.0自带的sample2是怎么做出来的.....................................................................22
3.9 Surfer 8.0格点数据的格式................................................................................................23
3.10 Contour+Wirefarme+Classed Post Map三图组合...................................................23
3.11 如何blank多个多边形的外部数据.................................................................................23
3.12 沿某条曲线(不闭合)进行blank.................................................................................25
3.13 剖面线(slice)的用法..................................................................................................25
3.14 在Surfer中应用Basemap.................................................................................................26
3.15 Surfer 8.0可以做地图投影吗..........................................................................................26
3.16 制作剖面平面图..............................................................................................................27
3.17 如何调整色标(Color Scale)为水平...........................................................................28
3.18 如何设置类似GMT软件等的黑白相间的色标.............................................................29
3.19 用bln来blank一个多边形外部........................................................................................29
3.20 blankline的解释................................................................................................................30
3.21 怎样做三维底图..............................................................................................................30
3.22 关于断层(Faults)的用法............................................................................................30
3.23 英文版surfer8中输入中文坐标名的方法.....................................................................31
3.24 Surfer中能否将Y值反向(颠倒)标注.......................................................................31
§4 Surfer 8.0与Script..........................................................................................................35
§5 结束语.................................................................................................................................35
【威望要求】 0
说明:
本文档来自华夏土地论坛,缺少第四节 Sufer与Script脚本语言部分。如有异议,立即删除。针对surfer初学者,高手就不要下载了,省点果果。
[ 此贴被sdyking在2009-04-23 16:49重新编辑 ]
