  • 4446阅读
  • 3回复
外文文献(PDF)及对应报告(PPT格式) [复制链接]
离线min_9905
22
146
只看楼主 倒序阅读 使用道具 0楼 发表于: 2009-03-04 | 石油求职招聘就上: 阿果石油英才网
— 本帖被 笑韵 执行加亮操作(2009-08-02) —
说明:
reportspapers.htm是总体的目录,上面包括论文名,作者,日期,大小等基本信息。
PDf格式的论文是申请上传的外文文献,对应PPT格式的报告分散在2001-2008的文件夹中。
找论文对应报告的时候,先看论文是那个年份的,然后进相应年份的文件夹中就可以找到作者名字命名的PPT格式的报告。
以下为reportspapers.htm文件内容:
Technical Reports (以下文章均可通过Google搜索后下载源文)
"Reservoir Analysis Based on Compositional Gradients", Olubusola Thomas, February 2007. [PDF file, 1.1 MB]
"Multiresolution Reparameterization and Partitioning of Model Space for Reservoir Characterization", Isha Sahni, September 2006. [PDF file, 4.4MB]
"Processing and Interpretation of Pressure Transient Data from Permanent Downhole Gauges", Masahiko Nomura, September 2006. [PDF file, 9MB]
"Gas Flow During Well Testing", Zhun Li, June 2006. [PDF file, 812KB]
"Analyzing Rate Data from Permanent Downhole Gauges", Himansu Rai, June 2005. [PDF file, 426KB]
"Optimization of Well Placement Under Time-Dependent Uncertainty", Umut Ozdogan, June 2004. [PDF file, 2498KB]
"Estimating Time-Dependent Reservoir Properties by Analyzing Long-Term Pressure Data", Jang Hyun Lee, June 2003, [PDF file, 4930KB]
"Wavelet Analysis for the Generation of Multiple History-Matched Reservoir Models", Isha Sahni, June 2003. [PDF file, 1254KB]
"Green Well Testing", Ashish Dabral, June 2003. [PDF file, 629KB]
"Well Testing in Gas-Condensate Reservoirs", Rajeev Lal, June 2003. [PDF file, 385KB]
"Well Placement Optimization Using the Quality Map Approach", Oluwatoyin Badru, June 2003. [PDF file, 1552KB]
"Effects of Relative Permeability on Parameter Estimation", Martin Cocco, September 2002. [PDF file, 538KB]
"Modeling Technique for Generating Fluvial Reservoir Descriptions Conditioned to Static and Dynamic Data", Vinh Phan, June 2002. [PDF file, 3.1MB]
"Optimization of Well Placement and Assessment of Uncertainty" , Baris Guyaguler, June 2002. [PDF file, 3.8MB]
"The Data as the Model: Interpreting Permanent Downhole Gauge Data Without Knowing the Reservoir Model", Olubusola Thomas, June 2002. [PDF file, 581KB]
"Effects of Cyclic Pressure Variation on Permeability", Chuntang Xu, June 2002. [PDF file, 1.4MB]
"Permanent Downhole Gauge Data Interpretation" , KC Khong, June 2001. [PDF file, 825KB]
"Reservoir Parameter Estimation Using Wavelet Analysis" , Pengbo Lu, March 2001. [PDF file, 2.5MB]
"Well Test Analysis of Gas Condensate Wells" , Bruno Roussennac, March 2001. [PDF file, 900KB]
"Computing Flow and Pressure Transients in Heterogeneous Media Using Boundary Element Methods" , Rosalind Archer, March 2000. [PDF file, 870KB]
"Reservoir Analysis Using Intermediate Frequency Excitation", Yan Pan, August 1999. [PDF file, 1.2MB]
"Development of an Interpretation Methodology for Long-Term Pressure Data from Permanent Downhole Gauges", Suwat Athichanagorn, June 1999. [PDF file, 3.8MB]
"Integrating Resistivity Data into Parameter Estimation Problem", Pengju Wang, June 1999. [PDF file, 487KB]
"Inferring Depth-Dependent Reservoir Properties from Integrated Analysis Using Dynamic Data", Vinh Phan, June 1998. [PDF file, 1.4MB]
"Analysis of Pressure/Flow-Rate Data With the Pressure-History-Recovery Method", Patrick Gilly, SPE57601, SPE Reservoir Evaluation and Engineering, August 1999. [PDF file, 328KB] Original version.
"Reservoir Parameter Estimation Constrained to Pressure Transients, Performance History and Distributed Saturation Data", Jorge Landa, June 1997. [PDF file, 1.9MB]
"Horizontal and Slanted Wells in Layered Reservoirs with Crossflow", Pengbo Lu, June 1997. [PDF file, 404KB]
"Optimizing Hydrocarbon Field Development Using a Genetic Algorithm Based Approach", Antonio Bittencourt, March 1997. [PDF file 4.8MB]
"Ultrasonic Measurement of Velocities in Multiphase Flow", Vinh Phan, January 1997. [PDF 62KB].
"Nonlinear Optimization of Well Production Considering Gas Lift and Phase Behavior", Miles Palke, September 1996. [PDF file 611KB]
"Application of Least Squares and Kriging in Multivariate Optimizations of Field Development Scheduling and Well Placement Design", Yan Pan, July 1995. [PDF file 900KB] (SUPRI-B report by current SUPRI-D student)
"Using Artificial Neural Network and Sequential Predictive Probability Method to Mechanize Interpretation of Well Test Data", Suwat Athichanagorn, June 1995. [PDF file 428 KB]
"Integration of Well Test Data into Stochastic Modeling", Eric Tauzin, April 1995. [PDF file 1.2MB]
"Optimal Scheduling of Development in an Oil Field", Antonio Bittencourt, August 1994. [PDF file 3.2MB] (SUPRI-B report by subsequent SUPRI-D student)
"Discrimination Between Reservoir Models in Well Test Analysis", Toshiyuki Anraku, December 1993. [PDF file 1.1MB]
"Accelerated Perturbation Boundary Element Model for Flow Problems in Heterogenous Reservoirs", Kozo Sato, June 1992. [PDF file 2.2MB]
"Well Test Interpretation Using Laplace Space Type Curves", Marcel Bourgeois, March 1992. [PDF file, 437KB]
"Multivariate Production Systems Optimization", James A. Carroll, III, December 1990. [PDF file, 375KB]
"Well Test Analysis of a Multilayered Reservior with Formation Crossflow", Heungjun Park, June 1989. [PDF file, 657KB]
Some Recent Papers: (以下SPE文章下载地址为http://pangea.stanford.edu/ERE/research/suprid/papers/)
Phan, V.Q., and Horne, R.N.: "Fluvial Channel Parameter Estimation Constrained to Static, Production, and 4D Seismic Data", paper SPE 77518 presented at the SPE Annual Technical Conference and Exhibition held in San Antonio, Texas, 29 September–2 October 2002.  [PDF file, 1.4MB]
Guyaguler, B., Horne, R.N., and Tauzin, E.: "Automated Reservoir Model Selection in Well Test Interpretation", paper SPE 71569 presented at the SPE Annual Technical Conference and Exhibition, held in New Orleans, LA, 30 September - 3 October, 2001. [PDF file, 551KB]
Guyaguler, B., and Horne, R.N.: "Uncertainty Assessment of Well Placement Optimization", paper SPE 71625 presented at the SPE Annual Technical Conference and Exhibition, held in New Orleans, LA, 30 September - 3 October, 2001. [PDF file, 954KB]
Lu, P., and Horne, R.N.: "A Multiresolution Approach to Reservoir Parameter Estimation Using Wavelet Analysis", paper SPE62985 presented at the SPE Annual Technical Conference and Exhibition held in Dallas, TX. 1-4 October, 2000. [PDF file, 508KB]
Guyaguler, B., Horne, R.N., Rogers, L., and Rosenzweig, J.J.: "Optimization of Well Placement in a Gulf of Mexico Waterflooding Project", paper SPE63221 presented at the SPE Annual Technical Conference and Exhibition held in Dallas, TX. 1-4 October, 2000. [PDF file, 300KB]
Archer, R.A., and Horne, R.N.: "The Green Element Method for Numerical Well Test Analysis", paper SPE62916 presented at the SPE Annual Technical Conference and Exhibition held in Dallas, TX. 1-4 October, 2000. [PDF file, 245KB]
Guyaguler, B., and Horne, R.N.: "Optimization of Well Placement", presented at the ASME Energy Sources Technology Conference in New Orleans, February 14-16, 2000; to appear in the Journal of Energy Resources Technology [PDF file, 420KB]
Wang, P., and Horne, R.N.: "Integrating Resistivity Data with Production Data to Improve Reservoir Modeling", paper SPE59425, presented at the 2000 SPE Asia Pacific Conference on Integrated Modeling for Asset management, Yokohama, Japan, 25-26 April, 2000. [PDF file, 279KB]
Archer, R., Horne, R.N., and Onyejekwe, O.: "Petroleum Reservoir Engineering Applications of the Dual Reciprocity Boundary Element Method and the Green Element Method", presented at the 21st World Conference on the Boundary Element Method, 25-27 August 1999, Oxford University. [PDF file, 155KB]
Athichanagorn, S., Horne, R.N., and Kikani, J.: "Processing and Interpretation of Long-Term Data Acquired from Permanent Pressure Gauges", SPE56419, presented at the 74th Annual Technical Conference and Exhibition, Houston, TX, 3-6 October 1999. [PDF file, 504KB]
Phan, V.Q., and Horne, R.N.: "Determining Depth-Dependent Reservoir Properties Using Integrated Data Analysis", SPE56423, presented at the 74th Annual Technical Conference and Exhibition, Houston, TX, 3-6 October 1999. [PDF file 273KB]
Pan, Y., and Horne, R.N.: "Improved Methods for Multivariate Optimization of Field Development Scheduling and Well Placement Design", SPE 49055, presented at the 73rd Annual Technical Conference and Exhibition, New Orleans, LA, 27-30 September 1998. [PDF file, 453KB]
Gilly, P., and Horne, R.N.: "A New Method for Analysis of Long-Term Pressure History", SPE 48964, presented at the 73rd Annual Technical Conference and Exhibition, New Orleans, LA, 27-30 September 1998. [PDF file, 358KB]
Archer, R., and Horne, R.N.: "Flow Simulation in Heterogeneous Reservoirs using the Dual Reciprocity Boundary Element Method and the Green Element Method", presented at ECMOR VI Conference, Peebles, Scotland, Sept 8-11, 1998. [PDF file, 202KB, or Postscript file, 202KB]
Landa, J.L., and Horne, R.N.: "A Procedure to Integrate Well Test Data, Reservoir Performance History and 4-D Seismic Information into a Reservoir Description", SPE38653, presented at the 72nd Annual Technical Conference and Exhibition, San Antonio, TX, 5-8 October 1997. [PDF file, 316KB]
Bittencourt, A.C., and Horne, R.N.: "Reservoir Development and Design Optimization", SPE38895, presented at the 72nd Annual Technical Conference and Exhibition, San Antonio, TX, 5-8 October 1997. [PDF file, 191KB]
Palke, M.R., and Horne, R.N.: "Nonlinear Optimization of Well Production Considering Gas Lift and Phase Behavior", SPE 37428, presented at the 1997 SPE Production Operations Symposium, Oklahoma City, OK, 9-11 March 1997. [PDF file, 230KB]
Palke, M.R., and Horne, R.N.: "Determining the Value of Reservoir Data by Using Nonlinear Production Optimization Techniques", Society of Petroleum Engineers 38047 presented at the Society of Petroleum Engineers Asia Pacific Oil and gas Conference, Kuala Lumpur, April 14-17, 1997. [PDF file, 83KB]
Landa, J.L., Kamal, M.M., Jenkins, C.D., and Horne, R.N.: "Reservoir Characterization Constrained to Well Test Data: A Field Example", SPE 36511, presented at the 71st Annual Technical Conference & Exhibition, Denver, CO, October 6-9, 1996. [PDF file, 210KB]
Athichanagorn, S., and Horne, R.N.: "Automatic Parameter Estimation of Well Test Data using Artificial Neural Networks", SPE 30556, presented at the 70th Annual Technical Conference & Exhibition, Dallas, TX, October 22-25, 1995. [PDF file, 176KB]
[ 此贴被笑韵在2009-08-02 12:16重新编辑 ]
2条评分
笑韵 财富 +100 FTP上传奖励 2009-03-04
笑韵 财富 +100 感谢分享 2009-03-04
离线笑韵
4043
11582
878
只看该作者 1楼 发表于: 2009-03-05 | 石油求职招聘就上: 阿果石油英才网
同意上传,账号已发送,请及时上传,谢谢合作
久违了的
离线min_9905
22
146
只看该作者 2楼 发表于: 2009-03-09 | 石油求职招聘就上: 阿果石油英才网
— (笑韵) 问问,所上传的各个年份的meeting,具体是什么会议? (2009-03-11 11:27) —
3月9号早上已经上传了!!
[ 此贴被min_9905在2009-03-09 14:19重新编辑 ]
本主题包含附件,请 登录 后查看, 或者 注册 成为会员
离线笑韵
4043
11582
878
只看该作者 3楼 发表于: 2009-08-02 | 石油求职招聘就上: 阿果石油英才网
该文件保存在FTP\其他未分类\min_9905文件夹下
久违了的
