  • 1400阅读
  • 9回复
怎么翻啊 [复制链接]
离线chy19861112
153
57
只看楼主 倒序阅读 使用道具 0楼 发表于: 2009-03-16 | 石油求职招聘就上: 阿果石油英才网
RETENTION OF HIGH PERMEABILITY DURING SHALLOW BURIAL (300 TO 500 M) OF
CARBONATE GRAINSTONES
特别是CARBONATE GRAINSTONES
离线sydxxq2008
1379
261
只看该作者 1楼 发表于: 2009-03-16 | 石油求职招聘就上: 阿果石油英才网
CARBONATE GRAINSTONES 粒状碳酸盐
allex02 财富 +8 应助奖励 2009-03-16
离线chy19861112
153
57
只看该作者 2楼 发表于: 2009-03-16 | 石油求职招聘就上: 阿果石油英才网
整句这样通不通啊?
浅层( 300 〜 500米)粒状碳酸岩的保留高渗透性
allex02 财富 +10 LZ贴得就不是完整的句子嘛 2009-03-16
离线dedream
5085
5058
211
只看该作者 3楼 发表于: 2009-03-16 | 石油求职招聘就上: 阿果石油英才网
仔细分析一下英文的结构看看。
翻不通不是最后那两个单词的问题
Shale gas
离线guoditang
467
456
25
只看该作者 4楼 发表于: 2009-03-17 | 石油求职招聘就上: 阿果石油英才网
具体把一段话贴出来,联系前后会好理解些……
离线chy19861112
153
57
只看该作者 5楼 发表于: 2009-03-17 | 石油求职招聘就上: 阿果石油英才网
这是一个论文的题目
离线chy19861112
153
57
只看该作者 6楼 发表于: 2009-03-17 | 石油求职招聘就上: 阿果石油英才网
我把摘要放在后面吧,
ABSTRACT: A progressive decrease in matrix permeability occurs with burial in the Paleogene limestones of west-central
Florida, yet grainstones with permeabilities . 400 md persist below burial depths of 300 m. Why some grainstones retain high
permeability during passage through the shallow-burial realm was investigated using 85 dominantly foraminifera and
micritized-grain grainstones from the Eocene Avon Park Formation. Twenty-seven variables representing diagenesis,
stratigraphic packaging, depositional energy, grain types, and pore-network attributes were quantified. Permeabilities range
from 23 to 7,160 md and thin-section porosities range from 14% to 36%. Grain size (lower coarse to upper fine sand) covaries
positively with sorting (poor to very good). The samples are from three different systems tracts within the Avon Park, and
sampled grainstone bodies ranged in thickness from 0.5 to 3.5 m. Evidence of diagenesis include mechanical and chemical burial
compaction, pre-compaction cements, and dissolution. Original interparticle porosity loss due to compaction (COPL) and
cementation (CEPL) range from 0 to 35.3% and 1.6 to 26.2% respectively. Most original intraparticle porosity is occluded, but
most moldic porosity, which ranges from 1.2% to 12%, remains open.
Multivariate regression reveals that 61% of the variance in permeability is attributed to grain size, CEPL, COPL, and
systems tract (a proxy for relative abundance of compactable foraminifera versus robust micritized grains). Large grain size
means a large initial permeability; all other regression components reflect diagenetic reductions in permeability. Observed
ranges in CEPL and COPL values mean they can reduce permeability by more than three orders of magnitude whereas the
other regression parameters reduce it by only one order of magnitude. Retention of high (. 400 md) permeability can occur by
(1) cementation of , 40% of the original interparticle pore space, which inhibits subsequent compaction yet preserves high
permeability, or (2) a combination of cementation and compaction that destroys less than two thirds of the original interparticle
pore space. These relations, derived from originally calcite-rich sediments, provide a quantitative reference by which to evaluate
permeability preservation during shallow burial in numerical simulation of diagenesis and reservoir development.
Capillary-pressure data also support the hypothesis that pore geometries, and hence permeability, respond differently to
compaction versus cementation. Cement-dominated samples exhibit a dominance of porosity behind intermediate-sized pores at
higher permeabilities than compaction-dominated samples. Compaction also does not yield a large change in the amount of
porosity behind pore throats smaller than 1 mm at any permeability above 20 md, whereas cementation-dominated diagenesis
generates significant amounts of pore space behind those small throats once permeability goes below 100 md. These differences
arise because cementation converts the original interparticle pores to a system of interparticle polyhedral and sheet-like pores
connected by progressively smaller pore throats between cement crystals, whereas compaction merely constricts the original
interparticle porosity behind smaller intergranular pore throats.
离线unknown1
762
999
只看该作者 7楼 发表于: 2009-03-17 | 石油求职招聘就上: 阿果石油英才网
浅埋深(300-500米)粒状碳酸岩具有的高渗透率?
allex02 财富 +8 应助奖励 2009-03-17
离线笑韵
4043
11582
878
只看该作者 8楼 发表于: 2009-03-17 | 石油求职招聘就上: 阿果石油英才网
CARBONATE GRAINSTONES 应该指的是颗粒岩吧
碳酸盐岩分类表(Dunham,1962)
spearshield 财富 +5 Rewards for discussing! 2010-05-10
久违了的
离线sxh1688
4830
16012
26
只看该作者 9楼 发表于: 2010-05-02 | 石油求职招聘就上: 阿果石油英才网
应该是: 浅埋深(300-500米)颗粒状高渗透率碳酸岩的保留时间?
