【文件名】ISOPE -INTERNATIONAL OFFSHORE AND POLAR ENGINEERING CONFERENCE(2003)文集
【专业领域】海洋石油
【作者】 ISOPE 会议
【出版日期】 2003
【文件格式】 PDF
【页数】 共 114 篇
【压缩包大小】 70 M
【解压缩后文件大小】 84M
【内容简介】 第十三届国际近海与极地工程学术会议论文集
主题词: 近海工程
笑韵20090411补充
目录文件免费下载:
http://www.isope.org/publications/proceedings/ISOPE/Proc-2003-CD-vol2_toc_0422-FINAL.pdf可以按照目录中的页码在ftp中查询对应文件比如第一篇的文件名2001p001.pdf,其中001代表的就是页码!International Society of Offshore and Polar Engineers (ISOPE)
P.O. Box 189, Cupertino, California 95015−0189 USA
CONTENT
PIPELINES, RISERS AND CABLE MECHANICS
OFFSHORE AND ARCTIC PIPELINES
The Chemical Compatibility of Thermoplastic Hose used in Umbilicals
M. Brodesser, W.M. Banks, R.A. Pethrick, N. Casey and J. Brown ......................................... 1
Strength Criteria and Analytic Predictions of Failure Pressure in Corroded Line Pipes
Xian-Kui Zhu and Brian N. Leis ................................................................................................ 8
The Applicability of Elastic Plastic Fracture Mechanics Parameters for Defects in Girth Welds Subjected to Cyclic Loading
Kjell Olav Halsen and Stig Wästberg ....................................................................................... 16
Stability of Large Cylinder Sunken into Muddy Seabed during Construction
Chongren Qin, Chongjiu Zhao, Hongli Pang and Shi Sen Li ................................................... 24
Experimental Study of Pore Pressure Build Up Due to Horizontal Cyclic Loading of Pipeline
Tomiya Takatani and Mark F. Randolph .................................................................................. 31
Deep Water Sealines Installation by Using the J-lay Method - The Blue Stream Experience
Massimo Pulici, Marian Trifon and Andrei Dumitrescu .......................................................... 38
Experimental and Analytical Study for the Installation of Flexible Pipe in Existing Submarine Pipelines by Pipe-in-Pipe Technology
Takashi Mochizuki, Takashi Sakamoto, Tomohiro Yamada, Takayoshi Hayashi,
Kenichi Ishii and Toru Kagoura ................................................................................................ 44
A Theoretical Model of Straightening without an Aligner during the Reeling Installation Process
E.S. Focke, A.M. Gresnigt and F.S.K. Bijlaard ......................................................................... 52
Extending the Strain Limits for Reeling Small Diameter Flowlines
T. Sriskandarajah, A.L. Howard-Jones and A.N. Bedrossian .................................................. 61
Analytical Methods for Predicting Displacements and Stresses in SCRs Subjected to Static Loading
Daniel Averbuch, Cédric Le Cunff, David Costa and Francis Biolley .................................... 70
Design Challenges of Deepwater Dry Tree Riser Systems for Different Vessel Types
Claire Chedzoy and Frank Lim ................................................................................................. 76
A Variational Formulation for a Three-Dimensional Extensible Marine Pipe Transporting Fluid
Chainarong Athisakul, Somchai Chucheepsakul and Tseng Huang ........................................ 83
Catenary Equations for Top Tension Riser Systems
Metin Karayaka and Lixin Xu .................................................................................................... 91
A Numerical and Experimental Study on Dynamics of a Highly Flexible Free Hanging Pipe in Water
D.H. Jung, H.I. Park and W. Koterayama ................................................................................ 98
On the Tension-Compression Behaviour of Flexible Risers
Elton J.B. Ribeiro, José R.M. de Sousa, Gilberto B. Ellwanger and Edison C.P. Lima ......... 105
Optimal Condition of Vibration Absorber Used in Calm Water (Comprehensive Study by Quasi-Newton Method)
Yoshikazu Kobayashi, Kazuo Aso, Kazuyuki Masaki, Yotsugi Shibuya
and Mamoru Takahashi ............................................................................................................. 113
Numerical Simulations of Cable/Seabed Interaction
Caroline Gatti-Bono and N.C. Perkins ..................................................................................... 120
Three Dimensional Dynamics Simulation of Slack Tether Motion in an ROV System
Bradley J. Buckham, Frederick R. Driscoll, Meyer Nahon and Branka Radanovic ............... 127
Offshore Mooring Pile Design for Recovery of the Ehime Maru
Mathew J. Francis, Michael A. Yamasaki, Tony Abbs and James Kwong .............................. 135
Recovery Operation of Transponder Mooring System Using Rope and Grapnel Rescue System for Shinkai 6500
Kikuo Hashimoto, Yoshitaka Sasaki and Hiroyasu Momma .................................................... 139
Deformation and Mooring Force of Submerged Membrane and Net Sheet in Currents and Waves
Akio Yasui and Ichiro Deguchi .................................................................................................. 145
On the Design of S-Tether Oceanographic Moorings
Seon Han and Mark Grosenbaugh ............................................................................................ 150
Computational Model for the Analysis of Damaged Ropes
Juan F. Beltran, Jaroon Rungamornrat and Eric B. Williamson ............................................. 158
Experimental Investigation vs Numerical Simulation of the Dynamic Response of a Moored Floating Structure to Waves
D. Dessi, A. Carcaterra and G. Diodati ................................................................................... 164
AUV AND UNDERWATER CONTROL
Which Stage Does the AUV “URASHIMA” Evolve?
Tadahiro Hyakudome, Taro Aoki, Takashi Murashima, Satoshi Tsukioka, Hiroshi Yoshida, Hidehiko Nakajoh, Tadahiko Ida, Toshio Maeda,
Kiyoshi Hirokawa, Takuji Ichikawa, Shoujirou Ishibashi and Ryoko Sasamoto ..................... 172
Biology-Inspired Precision Maneuvering of Underwater Vehicles (Part 2)
Naomi Kato, Hao Liu and Hirohisa Morikawa ......................................................................... 178
Development of a Motion Simulator for Underwater Vehicles Using a Parallel Mechanism
Satoru Yamaguchi, Wataru Koterayama and Masaru Inada .................................................. 186
Fuel-Optimal Guidance and Tracking Control of AUV under Current Interaction
Kangsoo Kim and Tamaki Ura .................................................................................................. 191
Dynamic Analysis and Active Damping Control for Underwater Vehicle-Manipulator Systems
Jinhyun Kim and W.K. Chung .................................................................................................. 197
Development of the Homing and Docking Algorithm for AUV
Young-Hwa Hong, Jung-Yup Kim, Pan-Mook Lee, Bong-Hwan Jeon, Kyu-Hyun Oh and Jun-ho Oh .................................................................................................... 205
Monitoring the Exploitation of Sandbanks: Lessons from Conventional Surveys and Perspectives Opened by AUV
Alain M. Norro, Virginie Pison and José Ozer ......................................................................... 213
ASTRA – Automated Sensor Burial Tool for Set-Up of Subsea Seismic Networks
Hans W. Gerber and Günther F. Clauss ................................................................................... 221
Advanced Operation of Ocean Bottom Seismometer
Kazumi Baba, Makoto Ito, Hitoshi Tanaka and Hiroyasu Momma ......................................... 228
in a Workspace Divided into Cubes
Shojiro Ishibashi, Masanori Ito and Etsuro Shimizu ................................................................ 231
OCEAN AND ARCTIC ENVIRONMENT AND OIL POLLUTION
Baseline Assessment of Water Quality and Circulation Patterns in the Khalid and Al-Khan Adjacent Coastal Lagoons in Sharjah, UAE
Abdallah Shanableh, Maher Omar, Abdul-Aziz Al-Midfa and Anas Dolan ............................ 239
Positioning of Artificial Benthic Habitats off Mito, Southwestern Coast of Taiwan
Wen-Miin Tian ........................................................................................................................... 247
The Environmental Quality of Shrimp Ponds in Mangrove Areas
Tuan Xuan Le, Yukihiro Munekage, Dao Anh Thi Phan and Dao Quynh Thi Quan .............. 255
Nitrogen Budget of Artificial Salt Marsh in Inner Osaka Bay
Ryoichi Yanagawa, Susumu Yamochi and Sumiyo Matsuhisa ................................................. 263
Prediction of Oil-Ice Sandwich Formation
Koh Izumiyama, Shotaro Uto and Shigeki Sakai ...................................................................... 268
Recent Developments in the Analysis of TDR Waveforms for Evaluation
of Water Content and Subsurface Concentrations of Pollutants
Abdel-Mohsen O. Mohamed ...................................................................................................... 274
Typical Seasonal Circulation in the Bohai Sea
Shuxiu Liang, Zhaochen Sun, Ryoichi Yamanaka and Keiji Nakatsuji .................................... 282
Flow Structure and Mixing around Transverse Depth-Varied Barrier
Makoto Ifuku ............................................................................................................................. 290
Automatic Triangulation of Estuarine Arbitrary Planar Domain with Special Reference to Changjiang Estuary
S.S. Li, Zhi Xia Zhu and Z. Shi ................................................................................................... 296
Hydrography of the Bosphorus Strait, and the Effects to Submarine Constructions
Yalcin Yuksel, Ahmet Cevdet Yalciner, Isikhan Guler, Baris Mater and Ferruh Erturk ......... 303
A Simplified Moving Boundary Treatment in MEC Model
Zhixing Yu and Yusaku Kyozuka ................................................................................................ 310
Laminar to Turbulent Flow Liquid-liquid Jet Instability and Breakup
Liujuan Tang and Stephen M. Masutani ................................................................................... 317
A Numerical Simulation of a Tidal Current on a Tidal Flat
Koichi Masuda, Tomoki Ikoma, Fumikazu Otsuka and Hiroki Ozawa .................................... 325
Experimental Study on Flow and Tidal Exchange of a Reservoir through Dike Gatesin Isahaya Bay
Tomoki Yokoyama and Yusaku Kyozuka ................................................................................... 331
Development of an Inhabitable Quaywall for Improvement of Material Cycle
Junya Miyoshi, Yasunori Koduki, Kengo Kurata, Michio Kitano, Hitoshi Murakami and Hiroyuki Mizuguchi ............................................................................................................ 338
GEOTECHNICAL ENGINEERING
SOIL PROPERTIES
An Effective Stress Path of K0-consolidated Marine Clays
S. Nishie, L. Wang and M. Hyodo .............................................................................................. 345
Calcareous Deposits, Hydrogen Evolution and pH on Structures under Cathodic Polarization in Seawater
G. Salvago, S Maffi, L. Magagnin, A. Benedetti, S. Pasqualin and E. Olzi ............................. 353
Interpretation of Stress Paths from Pressuremeter Tests in Sand
Vincenzo Silvestri and Claudette Tabib .................................................................................... 360
Applications of Dilative Behavior in Marine Soil
Wei-feng, Lee, Chih-ying, Lin, Jing-wen, Chen and Bing-huan Ku ......................................... 366
Effects of Diatom Microfossil Contents on Engineering Properties of Soils
Masanori Tanaka, Hiroyuki Tanaka, Takeshi Kamei and Shogo Hayashi .............................. 372
Evaluating Stress History of Pusan Marine Clay from Cone Penetration Test
Kang W. Lee, Gil L. Yoon, Young S. Chae and Soo S. Kim ...................................................... 378
Effect of Drying Process on the Evaluation of Microstructure of Clays using Scanning
Electron Microscope (SEM) and Mercury Intrusion Porosimetry (MIP)
Min-Soo Kang, Yoichi Watabe and Takashi Tsuchida ............................................................. 385
Sand Drain Design Based on Cyclic Strain-Path Controlled Triaxial Data
Kazunori Uchida and James David Stedman ............................................................................ 393
Effect of Added Cement on Strength and Heavy Metals Leaching for Compacted Coal Fly Ash
N. Yoshimoto, M. Hyodo, Y. Nakata and A.F.L. Hyde .............................................................. 401
Settling Behavior and Zeta Potential of Kaolinite in Aqueous Media
Abidin Kaya, Ali Hakan Oren and Yeliz Yukselen .................................................................... 407
Wavy Pattern of Grain Size Distribution in Alluvial Layer and its Role on Engineering Properties
Mitsuharu Fukuda and Seiji Suwa ............................................................................................. 413
The Study of the Influencing Factors of Creep for Colluviums Slope Land by Using the Monitoring Data in Huafan University
Chen-Ping Chao and Wei Fang ................................................................................................. 419
Effect of Specimen Size on Unconfined Compressive Strength Properties for Natural Clay Deposits
Ryo Sakamoto and Takaharu Shogaki ....................................................................................... 426
Cemented Behavior of Hydraulic Fill Material
Jing-wen Chen, Chih-ying Lin and Wei-feng Lee ..................................................................... 432
SOIL DYNAMICS
Role of Plastic and Non-Plastic Fines on Cyclic Shear Behavior of Saturated Sands
Y. Nabeshima and T. Matsui ...................................................................................................... 440
The Mechanism Analysis of Wave-induced Seabed Liquefaction
Lien-kwei Chien, C.H. Chang, C.H. Hsiao, S.C. Chang and Y.H. Chang ............................... 445
Dynamic Analysis of One-dimensional Consolidation Problems by Finite-deformation FEM
Masayoshi Shimizu and Kenji Kigoshi ...................................................................................... 453
Response Characteristics of Soft Settled Type of Offshore Structures Subjected to Harmonic Sea Wave and Earthquake Wave
Tadahiro Fukusumi, Naoki Uchida and Daisuke Takahashi .................................................... 460
On Line Pseudo-dynamic Response Test on Stratified Ground Including Clay Layer
N. Takahashi, M. Hyodo, Y. Yoshihiro, S. Kimura and Y. Yamamoto ...................................... 466
Seismic Rehabilitation of Coastal Dikes by Sheet-Pile Enclosures
Korhan Adalier, Ahmet Pamuk and Thomas F. Zimmie ........................................................... 474
A Practical Method in Evaluating Liquefaction Potential of Soils
Yie-Ruey Chen, Shun-Chieh Hsieh and Pai-Lung Shan-Kung ................................................. 481
Evaluation of the Liquefaction Characteristics of Decomposed Granite Soil
Yoshihisa Nakayama, Keiji Inoue, Kazuhiko Nishida and Tatsuaki Nishigata ........................ 486
Ground Vibration Due to Dynamic Compaction
Jin-Hung Hwang and Tung-Yueh Tu ......................................................................................... 490
Vertical Composite Drains for Mitigating Liquefaction Hazard
Kyle M. Rollins, Joshua K.S. Anderson, Aaron K. McCain and R. Robert Goughnour .......... 498
Static and Dynamic Lateral Load Behavior of Pile Groups Based on Full-Scale Testing
Kyle M. Rollins, Steven R. Johnson, Kris T. Petersen and Thomas J. Weaver ........................ 506
Performance-Based Design Of Waterfront Structures
J.P. Singh, Mansour Tabatabaie and James B. French ........................................................... 514
Strain Wedge Model for Prediction of Lateral Response of Large Diameter Shafts/Piles in Liquefied and As-Is Conditions
Mohamed Ashour, Gary Norris and J.P. Singh ........................................................................ 522
Role of Soil Dynamics in the Offshore Environment
Vijay K Puri and Sanjeev Kumar ............................................................................................... 530
A Study of Liquefaction Potential for a Liquefied Area
Ku, Chih-Sheng, Lee, Der-Her, Chen, Chao-Shi and Tsai, Pai-Hsiang .................................. 538
Evaluating the Influence of Particle Shape on Liquefaction Behavior Using Discrete Element Modeling
Alaa K. Ashmawy, Beena Sukumaran and V. Vinh Hoang ....................................................... 542
SOIL MECHANICS
Development and Applicability of Compaction Control Technique for Embankment Using Apparent Resistivity
Nobumasa Ueno and Tamotsu Matsui ...................................................................................... 550
Strain-path Control K0 Consolidation of Marine Clays
Kazunori Uchida, David James Stedman and Toshihiko Sakagami ........................................ 555
Nonlinear Consolidation Nonlinear Consolidation Analysis of Dredged and Reclaimed Ground with The Lateral Drain Vacuum Consolidation Method
Myung Chan Kang, Song Lee and Kyu Hwan Lee .................................................................... 561
GEOSYNTHETICS AND SOIL IMPROVEMENT
The Estimation of Discharge Capacity for Vertical Drain Materials Using Composite Discharge Capacity Apparatus
Soo Sam Kim, Hyun Young Shin, Sang Jae Han and Byung I1 Kim ........................................ 568
Geosynthetic Embankment Stability on Soft Ground Considering Reinforcement Strain
Kwang Yeol Lee, Chin Gyo Chung, Jae Hong Hwang, Jin Won Hong and Yong Soo Ahn .... 574
Early Stabilization Technology of the Dredged and Reclaimed Soils
Soo-Sam Kim, Yong-Soo Kim, Seong- Yong Jung and Jae-Kwon Kim .................................... 580
SEABED AND SLOPE DEFORMATION
Investigation of the Age of Submarine Slope Failures in the Gulf of Mexico
Christopher D.P. Baxter, John W. King, Armand J. Silva and William R. Bryant .................. 586
Shear Wave Velocity Profiles of Sediments Determined from Surface Wave Measurements
B.L. Rosenblad, K.H. Stokoe, II, M.E. Kalinski and E. Kavazanjian ....................................... 594
Flow Deformation of Anisotropic Ground Induced by Ocean Wave Loading and Oscillation of Coastal Structures
Shima Kawamura and Seiichi Miura ........................................................................................ 601
Investigations on the Characteristics of Slope Stability for the Southern Cross Island Highway in Taiwan
Kuang-Jung Tsai, Chung-Tzung Hou, Jin-Bing Lin and Huang-Yu Wang .............................. 609
Coastal Subsidence in Golcuk during the 1999 Kocaeli Earthquake in Turkey
E.M. Rathje, S.G. Wright, I. Karatas and J. Bachhuber ........................................................... 614
FOUNDATION
Centrifuge Investigation of the Horizontal Capacity of Shallow Footings on Sand
Fraser Bransby and Gijae Yun .................................................................................................. 622
Experimental and Analytical Studies on Bearing Capacity of Suction Foundation
Kouki Zen, Guangqi Chen, Kiyonobu Kasama and Shintaro Deguchi .................................... 628
Cut-off Effect by Rock Grouting in the Area of Dam-foundation
Won-Pyo Hong, Geu-Guwen Yea and Han Lee ........................................................................ 636
Numerical Analysis of Stress States in Soil-Structure Interface Tests
Erman Evgin, Kazem Fakharian and Magdi Mohareb ............................................................ 641
Spudcan Foundation Penetration into Uniform Clay
M.S. Hossain, Y. Hu and M.F. Randolph .................................................................................. 648
Experimental Evaluation of Preload Effect on Skirt Suction Foundation
Naoki Masui, Masato Ito, Akio Inoue, Toyoyuki Okajima and Jon Hermstad ......................... 654
Excessive Soil Plug and Anti-failure Mechanism of Bucket Foundation
During Penetration by Suction
S.L. Yang , L.O. Grande, J.F. Qi and X.L. Feng ....................................................................... 660
Electrokinetic Strengthening of Soil Surrounding Offshore Skirted Foundations
S. Micic, J.Q. Shang and K.Y. Lo .............................................................................................. 666
Methodology On Defining Parameters of Enlarged-Bottom Equipment Corresponding To Soil Properties
Tran Thi. Hong and Nguyen Ngoc. Tam ................................................................................... 674
Simulation Analysis about Effects of a PC Wall-pile Barrier on Reducing Ground Vibration
Yukihiko Kani and Kiyoshi Hayakawa ...................................................................................... 678
A Study on Analytic Models of Retaining Walls for Un-Symmetrical Excavations
Yen Twu Kuo ............................................................................................................................. 684
Development Process and Application of NS-BOX Diaphragm Wall
Kazuyuki Tazaki, Tamotsu Matsui, Masaya Hirai and Kunito Sakai ....................................... 690
Seismic Stability Enhancement of Rigid Nonyielding Structures
Hemanta Hazarika, Seishi Okuzono and Yuji Matsuo .............................................................. 698
A Performance-based Quality Control System for Improved Grounds
Masahito Tamura, Hideto Sato, Makoto Kouda, Mamoru Fujii, Kazuhiro Watanabe and Masashi Kawamura ............................................................................................................ 704
Calibration of Analytical Solution Using Centrifuge Model Tests on Mooring Lines
S. Bang, R. Richardson, Y. Cho and Y.S. Kim ........................................................................... 712
PILE FOUNDATION
Comparative Behavior of Laterally Loaded Groups of Bored and Driven Piles in Cohesionless Soil
Michael W. O’Neill and An-Bin Huang .................................................................................... 719
Fatigue Design of Driven Piles for Deepwater Applications
Jaime Buitrago and Patrick C. Wong ........................................................................................ 727
Centrifuge Tests on Uplift Capacity of Suction Caissons with Active Suction
H.G.B. Allersma, J.A. Jacobse and R.L. Krabbendam ............................................................. 735
The Skin Friction Capacity of SDA (Separated Doughnut Auger) Pile
Won-Pyo Hong and Soo-Geun Chai .......................................................................................... 741
Method For Estimating Ultimate Tip Load Of Bored Piles And Applicability Of Empirical Formula
Takahide Horiuchi and Yukihiko Kani ...................................................................................... 747
Design Charts of Piled Raft Foundations on Soft Clay
Young-Kyo Seo, Kyung-sik Choi and Sung-Gyo Jeong ............................................................ 754
Model Shaking Table Test on the Damage to Pile Foundation in Earthquake-Induced Lateral Flow of Ground with Non-liquefied Surface Layer
Yuji Adachi, Kinya Miura, Masaya Mihara and Kazuhiko Urano ........................................... 757
CASSIONS AND ANCHORS
Suction Caisson Installation At Horn Mountain – A Case History
Jean M.E. Audibert, Ed. Clukey and Jun Huang ...................................................................... 763
Geotechnical Design Of Suction Caisson In Clay
Jun Huang, Jianchun Cao and Jean M.E. Audibert ................................................................. 771
Measured Response during Laboratory Installation of Suction Caissons
Alan F. Rauch, Roy E. Olson, Adam M. Luke and Elliott C. Mecham ..................................... 781
Centrifuge Model Tests on Embedded Suction Anchor Loading Capacities
S.H. Lee, Y. Cho, K.O. Kim, Y.S. Kim, T.H. Lee and D.J. Kwag .............................................. 789
An Experimental Study of Inflatible Offshore Anchors
T.A. Newson, F.W. Smith, P. Brunning and S. Gallagher ........................................................ 794
[ 此贴被笑韵在2009-04-11 18:58重新编辑 ]
