cgg4110安装 list文件信息 希望各位领导帮助 可以用软件交换
-- Post Pr -- Job not executed, no POST-PROCESSING on linux66 at ZYCGGPTS
-- Execute -- ERROR in PRE-ANALYZE on linux66 at ZYCGGPTS
>>>>>>>>>>>>>>>>>> PREANALYSIS PHASE <<<<<<<<<<<<<<<<<<<
[Sat May 2 09:05:36 2009] PREANALYZING dagensl0 (Level 4100 used) (Message received and po
sted)
===== Job run with OS = Linux2.4 and CPU = PIV =====
===== Configuration file /cgg/jobmgr/data/linux66_env sourced =====
if (-e ~/.flexlmrc) /bin/rm ~/.flexlmrc
setenv LM_LICENSE_FILE /cgg/license/license.dat:1700@linux66
unlimit
========== End of configuration file ===========
PATCHDEF: *** Default patches to apply (OS = Linux2.4 CPU = PIV) ***
General default Patches :
/cgg/lv4100/patch/patchdefaults/patches
MDG_DECSC4100_1734
MDG_DEPTV4100_1741
MDG_FILTR4100_1690
MDG_FKF3D4100_1810
MDG_FSFIM4100_1697
..................................................MDG_XPSAPI4100_1820
READ: linux66:/proj/1006400/JOBS/dagensl0.txt
Usage: preanl <local input file> <implicit liste>
>>>>>>>>>>>>>> END OF PREANALYSIS PHASE <<<<<<<<<<<<<<<<
>>>>>>>>>>>> PREANALYSIS ERR AND DIAG FILE <<<<<<<<<<<<<
>>>>>>>> END OF PREANALYSIS ERR AND DIAG FILE <<<<<<<<<<
>>>>>>>>>>>>>>>>>>>>>> DEBUG FILE <<<<<<<<<<<<<<<<<<<<<<
============ Machine configuration ==============
Current system is :
Hostname: linux66
OS version: Linux version 2.6.9-78.EL (
brewbuilder@hs20-bc2-3.build.redhat.com) (gcc versi
on 3.4.6 20060404 (Red Hat 3.4.6-10)) #1 Wed Jul 9 15:27:01 EDT 2008
