las是一种文件格式,一般atlas公司仪器测的曲线都采用las格式,而斯伦贝谢采用dlis格式,las的文件头如下:
~Version Information Block
VERS. 2.00: CWLS LOG ASCII STANDARD - VERSION 2.000000
WRAP. NO: One Line Per Depth Step
~Well Information Block
#MNEM.UNIT Data Information
STRT.M 980.000:
STOP.M 1631.250:
STEP.M 0.125:
NULL. -999.250:
COMP. 测井数据库导出: COMPANY
WELL. X66: Well
FLD . : Field
LOC . : LOCATION
CNTY. : COUNTY
STAT. : STATE
CTRY. : COUNTRY
SRVC. : SERVICE COMPANY
DATE. : DATE
API . : API NUMBER
~Curve Information Block
#MNEM.UNIT API CODE Curve Description
DEPT.M : Depth in Meters
AC .μs/ft : AC
DEN .g/cm3 : DEN
~A DEPTH AC DEN
980.000 -999.250 2.159
