图片:
Project Admin 有个错误提示:
Error Opening OWSYS
The master database owsys could not be connected.
Check to see that the value of OWSYSSID is set correctly.
Make sure that connection to OWSYSSID can be made.
Make sure that both ORACLE and listener are running.
RUN orastat for more diagnosic information.
See the OpenWorks System Administraion Guide for details
orastat 信息如下:
liu6{ow03}% orastat
# Checking environmentals on host: liu6...
OWHOME is set to: /home2/OpenWorks
ORACLE_HOME is set to: /home2/oracle/OraHome1
ORACLE_SID is set to: owwsy
OWSYSSID is set to: owwsy
# Determining Landmark applications installed ...
GeoDataLoad: GeoDataLoad 2003.12.0.1 UPDATE PASSED
12102005@10:22:48 /home2/OpenWorks/GeoDataLoa
d Linux
SeisWorks: SeisWorks 2003.12.1 INSTALL PASSED
10102005@15:29:03 /home2/OpenWorks/SeisWorks Linux
SeisUtils: SeisUtils 2003.12.1 INSTALL PASSED
10102005@15:30:37 /home2/OpenWorks/SeisUtils Linux
StratWorks: StratWorks 2003.12.0.1 INSTALL PASSED
10102005@15:40:18 /home2/OpenWorks/StratWorks Linux
StratUtil: StratUtil 2003.12.0.1 INSTALL PASSED
10102005@15:39:52 /home2/OpenWorks/StratUtil Linux
PetroWorks: PetroWorks 2003.12.0.0 INSTALL PASSED
10102005@15:45:26 /home2/OpenWorks/PetroWorks Linux
SynTool: SynTool 2003.12 INSTALL PASSED
10102005@16:13:33 /home2/OpenWorks/SynTool Linux
# Checking background daemons ...
Dynamic PD is ENABLED
NetD is operational on host localhost for Dynamic PD
Dynamic PD Session is RUNNING: SessionID:
OPENWORKS_600_ow03@192.0.2.88:0_PD Value: liu6:27962
Dynamic Pointing Dispatcher operational. checkpd returns OK
root 6418 1 0 15:18 ? 00:00:00 /home2/OpenWorks/lam/bin/lmgrd -c /home2/OpenWorks/lam/lice
nse.dat
root 6435 6418 0 15:18 ? 00:00:00 licsrv -T liu6 7.2 3 -c /home2/OpenWorks/lam/license.dat --
lmgrd_start 4ad186e3
LAM SERVER (lmgrd) running OK
licsrv server running OK
# ORACLE sids/host accessable through listener are ...
Found /home2/oracle/OraHome1/network/admin/tnsnames.ora
INST1_HTTP liu6
OWWSY liu6
*** Cannot rsh to liu6 as ow03
*** Unable to check ORACLE daemons
NetD server running OK on liu6 for Project Management purposes
checkRSvD returns OK for liu6 for Project Management purposes
# Checking ORACLE daemons on liu6...
oracle 6539 1 0 15:19 ? 00:00:00 ora_pmon_owwsy
pmon running OK on liu6
oracle 6541 1 0 15:19 ? 00:00:00 ora_dbw0_owwsy
dbw0 running OK on liu6
oracle 6543 1 0 15:19 ? 00:00:00 ora_lgwr_owwsy
lgwr running OK on liu6
oracle 6547 1 0 15:19 ? 00:00:00 ora_smon_owwsy
smon running OK on liu6
oracle 6549 1 0 15:19 ? 00:00:00 ora_reco_owwsy
reco running OK on liu6
tnslsnr running OK on liu6
# Checking sqlplus/sql*net as ow03...
ERROR:
*** WARNING: Database cannot be accessed by ow03 ***
*** Make sure that ow03 is an External ORACLE User
[ 此贴被dqkingjun在2009-10-11 16:02重新编辑 ]
