  • 2997阅读
  • 17回复
[部分应助]求Elsevier、Wiley 数据库文献若干篇--PDF-20(15或10)果果/篇 [复制链接]
离线flusher
2580
218
51
只看楼主 倒序阅读 使用道具 0楼 发表于: 2010-02-01 | 石油求职招聘就上: 阿果石油英才网
1、Phase and tension behavior of water, carbon dioxide, and decane: Comparison of a lattice-gas model
and the Peng-Robinson equation
Fluid Phase Equilibria, Volume 14, 1983, Pages 203-208
J. M. Nitsche, G. F. Teletzke, L. E. Scriven, H. T. Davis.(已经应助)
2、Phase equilibria in systems containing hydrogen, carbon dioxide, water and hydrocarbons
Fluid Phase Equilibria, Volume 100, 15 September 1994, Pages 253-268
Gerd Brunner, Jens Teich, Ralf Dohrn.(已经应助)
3、The phase behavior of two mixtures of methane, carbon dioxide, hydrogen sulfide, and water
Fluid Phase Equilibria, Volume 19, Issues 1-2, 1985, Pages 21-32
Sam S. -S. Huang, A. -D. Leu, H. -J. Ng, Donald B. Robinson.(已经应助)
4、Thermophysical properties of gaseous carbon dioxide---water mixtures
Fluid Phase Equilibria, Volume 36, 2 October 1987, Pages 279-299
Mukund R. Patel, James C. Holste, Kenneth R. Hall, Philip T. Eubank.(已经应助)
5、A generalized correlation for the interaction coefficients of CO2—hydrocarbon binary mixtures
Fluid Phase Equilibria, Volume 93, 11 February 1994, Pages 141-166
Aris Kordas, Konstantinos Tsoutsouras, Sofia Stamataki, Dimitrios Tassios..(已经应助)
6、The water content of ethane, propane and their mixtures in equilibrium with liquid water or hydrates
Fluid Phase Equilibria, Volume 95, 8 April 1994, Pages 281-298.(已经应助)
Kyoo Y. Song, Riki Kobayashi
7、Solubility of Co2 in water and density of aqueous Co2 near the solvent critical temperature
Fluid Phase Equilibria, Volume 74, 15 July 1992, Pages 271-288
Rosa Crovetto, R. H. Wood.(已经应助)
8、Binary interaction parameters for nonpolar systems with cubic equations of state: a theoretical approach 1. CO2/hydrocarbons using SRK equation of state
Fluid Phase Equilibria, Volume 102, Issue 1, 28 November 1994, Pages 31-60
João A. P. Coutinho, Georgios M. Kontogeorgis, Erling H. Stenby(已经应助)
9、P—V—T data and virial coefficients for gaseous methane—water mixtures with correction for adsorption effects
Fluid Phase Equilibria, Volume 43, Issues 2-3, December 1988, Pages 263-294
L. Lane Joffrion, Philip T. Eubank.(已经应助)
10、A molecular thermodynamic model for adsorption equilibrium from supercritical fluids
The Journal of Supercritical Fluids, Volume 6, Issue 3, September 1993, Pages 143-154
G. Afrane, E. H. Chimowitz.(已经应助)
11、Solubility of solids in liquids: one-parameter solubility equation
Fluid Phase Equilibria, Volume 25, Issue 3, 1986, Pages 273-278
H. Buchowski, A. Khiat.(已经应助)
12、Mathias,P.M.,Naheiri,T. and Oh,E.M.,“A density correction for the Peng-Robinson equation of state”,
Fluid Phase Equilibria, Volume 47, Issue 1, July 1989, Pages 77-87..(已经应助)
13、John A. Jossi, Leonard I. Stiel, George Thodos.The viscosity of pure substances in the dense gaseous and liquid phases.
AIChE Journal,1962,8(1):59-63..(已经应助)
14、Starling,K.E. and Ellington,R.T.:“Viscosity Correlations for Nonpolar Dense Fluids”,
AICHE J, Volume 10, Issue 1, January 1964: 11-15.(已经应助)
15、Byung Ik Lee, Michael G. Kesler.A generalized thermodynamic correlation based on three-parameter corresponding states,
AIChE J.,Vol. 21, Iss. 3,  May 1975, Pages: 510-527,.(已经应助)
16、Span,R. and Wagner,W.“A new equation of state for CO2 covering the fluid region from the triple-point temperature to 1100K at pressure up to 800MPa”
Journal of Physical and Chemical Reference Data,Vol.25,1996,pp.1509-1596(    AIP )(ISSN, 0047-2689)     20果果该篇 .(未应助
17、Parsons ,A., McKenna,T.M. and Miadonye ,A.:“Viscosity Model for Petroleum Gases,”
Petroleum Science and Technology, Volume 25, Issue 5 May 2007 , pages 631 – 643.(已经应助)
[ 此帖被flusher在2010-02-06 15:46重新编辑 ]
Today, you do what others cannot do,
离线flusher
2580
218
51
只看该作者 1楼 发表于: 2010-02-01 | 石油求职招聘就上: 阿果石油英才网
18、Duan Z. An equation of state for the CH4-CO2-H2O system:II.mixtures from 50 to 1000 and 0 to 1000 bars.
Geochim. Cosmochim. Acta,1992,56:2619-2631. 15果果该篇.(已经应助)
19、Bamberger A. High pressure(vapor+liquid) equilibrium in binary mixtures of (CO2+H2O or acetic acid) at temperatures
from 313 to 353.J. Supercrical Fluids,2000,17,97-100.(已经应助)
20、Crovetto R. Evaluation of solubility data for the system CO2-H2O from 273 to the critical point of water.
J. Phys. Chem. Ref. Data,1991,20:575-589.   (已经应助)
离线flusher
2580
218
51
只看该作者 2楼 发表于: 2010-02-02 | 石油求职招聘就上: 阿果石油英才网
expecting
[ 此帖被flusher在2010-02-04 11:28重新编辑 ]
离线sunwxm
371
165
61
只看该作者 3楼 发表于: 2010-02-03 | 石油求职招聘就上: 阿果石油英才网
应助19
19、Bamberger A. High pressure(vapor+liquid) equilibrium in binary mixtures of (CO2+H2O or acetic acid) at temperatures from 313 to 353.J. Supercrical Fluids,2000,17,97-100.
此帖售价 10 财富,已有 0 人购买 [记录] [购买]
购买后,将显示帖子中所有出售内容。
若发现会员采用欺骗的方法获取财富,请立刻举报,我们会对会员处以2-N倍的罚金,严重者封掉ID!
此段为出售的内容,购买后显示
本主题包含附件,请 登录 后查看, 或者 注册 成为会员
coalbed methane
离线sunwxm
371
165
61
只看该作者 4楼 发表于: 2010-02-03 | 石油求职招聘就上: 阿果石油英才网
应助8
8、Binary interaction parameters for nonpolar systems with cubic equations of state: a theoretical approach 1. CO2/hydrocarbons using SRK equation of state Fluid Phase Equilibria, Volume 102, Issue 1, 28 November 1994, Pages 31-60
购买后,将显示帖子中所有出售内容。
此段为出售的内容,购买后显示
离线hujg
3576
2091
100
只看该作者 5楼 发表于: 2010-02-03 | 石油求职招聘就上: 阿果石油英才网
购买后,将显示帖子中所有出售内容。
此段为出售的内容,购买后显示
离线flusher
2580
218
51
只看该作者 6楼 发表于: 2010-02-03 | 石油求职招聘就上: 阿果石油英才网
expecting others!
离线笑韵
4043
11582
878
只看该作者 7楼 发表于: 2010-02-04 | 石油求职招聘就上: 阿果石油英才网
购买后,将显示帖子中所有出售内容。
此段为出售的内容,购买后显示
此段为出售的内容,购买后显示
此段为出售的内容,购买后显示
此段为出售的内容,购买后显示
此段为出售的内容,购买后显示
久违了的
离线笑韵
4043
11582
878
只看该作者 8楼 发表于: 2010-02-04 | 石油求职招聘就上: 阿果石油英才网
购买后,将显示帖子中所有出售内容。
此段为出售的内容,购买后显示
此段为出售的内容,购买后显示
此段为出售的内容,购买后显示
此段为出售的内容,购买后显示
此段为出售的内容,购买后显示
久违了的
离线笑韵
4043
11582
878
只看该作者 9楼 发表于: 2010-02-04 | 石油求职招聘就上: 阿果石油英才网
购买后,将显示帖子中所有出售内容。
此段为出售的内容,购买后显示
此段为出售的内容,购买后显示
此段为出售的内容,购买后显示
此段为出售的内容,购买后显示
久违了的
