昨天晚上在工作站上完成工作后,shutdown机子,出现power down后,光标不停闪动,很长时间不能自动关掉电源,于是我直接按了主机上的电源开关,可今天再打开启动的时候,在starting rc.ow的时候,光标一直闪动,二十分钟都进不去,于是我敲回车,过了两个进程,在starting zzoracle.什么来着忘了,又出现同样问题,我也是敲回车,然后就进入了系统,在登陆的时候,说我以前的密码已经过期,必须要重新换一个新密码,我换了一个新秘密登录进去,可进去后发现的landmark软件中oracle数据库显示是红色的,我orastat了一下,以下是抱错信息:
dell690{lam2003}% orastat
# Checking environmentals on host: dell690...
OWHOME is set to: /data1/soft/OpenWorks
ORACLE_HOME is set to: /data1/soft/oracle8i/OraHome1
ORACLE_SID is set to: owhp6200
OWSYSSID is set to: owhp6200
# Determining Landmark applications installed ...
GeoDataLoad: GeoDataLoad 2003.12.0.1 UPDATE PASSED 07082006@15:59:24
/data1/soft/OpenWorks/GeoDataLoad Linux
SeisWorks: SeisWorks 2003.12.1 INSTALL PASSED 14082006@13:28:42 /app/Op
enWorks//SeisWorks Linux
SeisUtils: SeisUtils 2003.12.1 INSTALL PASSED 14082006@13:30:51 /app/Op
enWorks//SeisUtils Linux
StratWorks: StratWorks 2003.12.0.1 INSTALL PASSED 14082006@13:35:03 /app/Op
enWorks//StratWorks Linux
StratUtil: StratUtil 2003.12.0.1 INSTALL PASSED 14082006@13:34:44 /app/Op
enWorks//StratUtil Linux
PetroWorks: PetroWorks 2003.12.0.0 INSTALL PASSED 14082006@13:20:42 /app/Op
enWorks//PetroWorks Linux
SynTool: SynTool 2003.12 INSTALL PASSED 14082006@13:37:55 /app/OpenWorks/
/SynTool Linux
# Checking background daemons ...
Dynamic PD is ENABLED
NetD is operational on host localhost for Dynamic PD
Dynamic PD Session is RUNNING: SessionID:
OPENWORKS_600_lam2003@127.0.0.1:0_PD V
alue: dell690:28000
Dynamic Pointing Dispatcher operational. checkpd returns OK
root 3767 1 0 11:31 ? 00:00:00 /app/OpenWorks//lam/bin/lmgrd -c
/app/OpenWorks//lam/license.dat
root 3782 3767 0 11:31 ? 00:00:00 licsrv -T dell690 7.2 3 -c /app/
OpenWorks//lam/license.dat --lmgrd_start 49adf609
root 3971 1 0 11:49 ? 00:00:00 /app/gf/flexlm/bin/lmgrd -c /app
/gf/flexlm/licenses/license.dat
root 3975 3971 0 11:49 ? 00:00:00 lmgrd.slb -T dell690 9.5 3 -c /a
pp/gf/flexlm/licenses/license.dat --lmgrd_start 49adfa4a
root 3980 1 0 11:49 ? 00:00:00 /app/hrs8/lmgr/lmgrd -c /app/hrs
8/lmgr/license.dat
root 3982 3980 0 11:49 ? 00:00:00 Hamp-Russ -T dell690 9.0 3 -c /a
pp/hrs8/lmgr/license.dat --lmgrd_start 49adfa4a
LAM SERVER (lmgrd) running OK
licsrv server running OK
# ORACLE sids/host accessable through listener are ...
Found /data1/soft/oracle8i/OraHome1/network/admin/tnsnames.ora
OWHP6200.LOCALDOMAIN dell690
INST1_HTTP dell690
OWHP6200 dell690
OWHP6200_HP6200 dell690
*** Cannot rsh to dell690 as lam2003
*** Unable to check ORACLE daemons
NetD server running OK on dell690 for Project Management purposes
checkRSvD returns OK for dell690 for Project Management purposes
# Checking ORACLE daemons on dell690...
*** WARNING: The ORACLE daemon pmon is not running on dell690 ***
or
Manually verify that pmon is running on dell690
*** WARNING: The ORACLE daemon dbw0 is not running on dell690 ***
or
Manually verify that dbw0 is running on dell690
*** WARNING: The ORACLE daemon lgwr is not running on dell690 ***
or
Manually verify that lgwr is running on dell690
*** WARNING: The ORACLE daemon smon is not running on dell690 ***
or
Manually verify that smon is running on dell690
*** WARNING: The ORACLE daemon reco is not running on dell690 ***
or
Manually verify that reco is running on dell690
*** WARNING: The ORACLE daemon tnslsnr is not running on dell690 ***
or
Manually verify that tnslsnr is running on dell690
*** Verify the above ORACLE processes and re-run this utility to gain additional information ***
# Checking sqlplus/sql*net as lam2003...
ERROR:
*** WARNING: Database cannot be accessed by lam2003 ***
*** Make sure that lam2003 is an External ORACLE User
