OTC8449 Field Tests on VASPS Separation and Pumping System
OTC8452 Heave Compensated Landing System - A Novel Tool for Subsea Intervention
OTC8464 Description and Application of New Criteria for Casing Setting Design
OTC8465 Feasibility Study of a Dual Density Mud System for Deepwater Drilling Operations
OTC8470 Design of Subsea Multiple Pig Launcher for ETAP
OTC8510 Captain Field Electric Submersible Pump, Condition Monitoring and Completion Systems
OTC8511 Development of a Gas Handling Hydraulic Submersible Pump and Planning the Field Trail, Captain Field OTC8512 Process Equipment for Offshore Viscous Crude Handling: Captain Field
OTC8521 Hydrate Plug Dissociation Field Test
OTC8536 Overcoming the Challenges Associated With the Life Cycle Management of Multilateral Wells: Assessing Moves Towards the "Intelligent Well"
OTC8537 Development, Testing, and Field Case Histories of Multilateral Well Completion Systems
OTC8547 Multiphase Flow Meters and Application Trends
OTC8551 Applications of Multiphase Meters at the Gullfaks Field in the North Sea
OTC8560 Challenges in Sea-Bottom Seismic
OTC8569 Extended Reach Well Completion and Operational Considerations
OTC8570 Geologic Modeling and Visualization Facilitates the Transition From Exploration to Development
8510、8511两篇未应助 [ 此帖被hujg在2010-04-15 10:31重新编辑 ]
