  • 1142阅读
  • 6回复
[应助成功]JCPT+In Situ Upgrading of Llancanelo Heavy Oil Using In Situ Combustion and...+30果+PDF [复制链接]
离线kob0002
4515
276
51
只看楼主 倒序阅读 使用道具 0楼 发表于: 2010-06-22 | 石油求职招聘就上: 阿果石油英才网
— 本帖被 坐看云起 执行加亮操作(2010-06-23) —
Title In Situ Upgrading of Llancanelo Heavy Oil Using In Situ Combustion and a Downhole Catalyst Bed
Authors A. N. Cavallaro, G. R. Galliano, Repsol YPF; R. G. Moore, S. A. Mehta, M. G. Ursenbach, E. Zalewski, P. Pereira, University of Calgary
Journal Journal of Canadian Petroleum Technology
Volume Volume 47, Number 9
Date September  2008
Copyright 2008. Petroleum Society of Canada
Language English
Preview Abstract
There are vast heavy crude oil resources worldwide that are relatively uneconomical to produce and upgrade. However, there are novel processes available that can be employed in a downhole environment to upgrade these oils, resulting in significantly less sulphur content, and lowered densities and viscosities. A process that is especially favourable for downhole implementation is the use of in situ combustion to generate reactive upgrading gases, such as CO, and possibly H2, to drive oil over a near-wellbore heated bed of catalyst. Two laboratory combustion tube tests were completed to validate this concept. The first test used conventional in situ combustion tube packing and testing techniques, while the second test employed a heated catalyst bed in the downstream region of the combustion tube. A heavy crude oil from the Llancanelo field in Argentina was used for the testing. During the first test, this oil was found to be amenable to the in situ combustion process and exhibited stable combustion performance. Passing mobilized oil and combustion gases over the catalyst bed prior to production in the second test resulted in significant upgrading of the produced oil, including substantial decreases in oil density and viscosity. It is believed that the catalyst efficiently used CO, generated at the combustion front, via the water gas shift reaction to generate H2, which then reacted with the oil to effect upgrading. However, it was found that the presence of a large amount of coke on the post-test catalyst probably indicates the need for periodic regeneration. The presence of a heated production-end catalyst zone did not significantly affect the in situ combustion performance during the second test.
Introduction
Although there exists a large supply of heavy crude oil throughout the world, most of these reserves lie untapped for various reasons, chief among them being the poor economics of recovering heavy oils. While these economics are beginning to change as conventional oil production declines significantly, the cost-effective production and processing of heavy oils remains a much sought after prize. The authors have previously described how in situ combustion, in combination with a near-wellbore catalyst bed, could be used for significant downhole (in situ) upgrading of heavy crude oils(1, 2). This reference also discusses the potential advantages of in situ upgrading using in situ combustion and a fixed catalyst bed, as well as providing a literature review of the subject. Greaves and Xia(3) and Xia et al.(4) have recently been looking at other variations to the catalyzed in situ combustion process.
[ 此帖被kob0002在2010-06-22 21:27重新编辑 ]
离线fantasy2011
1490
只看该作者 1楼 发表于: 2010-06-22 | 石油求职招聘就上: 阿果石油英才网
顶一个 呵呵
离线坐看云起
11640
10643
1536
只看该作者 2楼 发表于: 2010-06-22 | 石油求职招聘就上: 阿果石油英才网
我在spe网站怎么没查到呢?你能给出检索页面吗?
获得果果的途径:
1.参与技术讨论
2.回答果友的问题或解答果友的疑难
3.在【文献求助】板块应助
4.提出有助于论坛建设和发展的意见或建议
5.分享有效资源(非重复资源)
6.参与论坛各项活动(包括节假日等的活动)
7.用人民币购买交易币之后兑换果果
8.被评为果园年度优秀会员有适当财富奖励
9.加入阿果石油网管理团队有适当财富薪酬
离线aagii545
801
300
只看该作者 3楼 发表于: 2010-06-22 | 石油求职招聘就上: 阿果石油英才网
我来应助
离线aagii545
801
300
只看该作者 4楼 发表于: 2010-06-22 | 石油求职招聘就上: 阿果石油英才网
文件大小:1.27M(必填)
存放位置:阿果(必填)
文件格式:PDF(必填)
[sell=30]   [/sell]
本主题包含附件,请 登录 后查看, 或者 注册 成为会员
离线kob0002
4515
276
51
只看该作者 5楼 发表于: 2010-06-22 | 石油求职招聘就上: 阿果石油英才网
非常感谢aagii545
离线aagii545
801
300
只看该作者 6楼 发表于: 2010-06-22 | 石油求职招聘就上: 阿果石油英才网
回 5楼(kob0002) 的帖子
不用客气,互相帮助嘛,呵呵
