  • 2868阅读
  • 18回复
英语学术论文常用句型 [复制链接]
离线sihai
135
341
只看楼主 倒序阅读 使用道具 0楼 发表于: 2010-10-31 | 石油求职招聘就上: 阿果石油英才网
英语学术论文常用句型
Beginning
    1. In this paper, we focus on the need for
    2. This paper proceeds as follow.
    3. The structure of the paper is as follows.
    4. In this paper, we shall first briefly introduce fuzzy sets and related concepts
    5. To begin with we will provide a brief background on the
  Introduction
    1. This will be followed by a description of the fuzzy nature of the problem and a detailed presentation of how the required membership functions are defined.
    2. Details on xx and xx are discussed in later sections.
    3. In the next section, after a statement of the basic problem, various situations involving possibility knowledge are investigated: first, an entirely possibility model is proposed; then the cases of a fuzzy service time with stochastic arrivals and non fuzzy service rule is studied; lastly, fuzzy service rule are considered.
   Review
    1. This review is followed by an introduction.
    2. A brief summary of some of the relevant concepts in xxx and xxx is presented in Section 2.
    3. In the next section, a brief review of the .... is given.
    4. In the next section, a short review of ... is given with special regard to ...
    5. Section 2 reviews relevant research related to xx.
    6. Section 1.1 briefly surveys the motivation for a methodology of action, while 1.2 looks at the difficulties posed by the complexity of systems and outlines the need for development of possibility methods.
Body
    1. Section 1 defines the notion of robustness, and argues for its importance.
    2. Section 1 devoted to the basic aspects of the FLC decision making logic.
    3. Section 2 gives the background of the problem which includes xxx
    4. Section 2 discusses some problems with and approaches to, natural language understanding.
    5. Section 2 explains how flexibility which often ... can be expressed in terms of fuzzy time window
    6. Section 3 discusses the aspects of fuzzy set theory that are used in the ...
    7. Section 3 describes the system itself in a general way, including the ….. and also discusses how to evaluate system performance.
    8. Section 3 describes a new measure of xx.
    9. Section 3 demonstrates the use of fuzzy possibility theory in the analysis of xx.
    10. Section 3 is a fine description of fuzzy formulation of human decision.
    11. Section 3, is developed to the modeling and processing of fuzzy decision rules
    12. The main idea of the FLC is described in Section 3 while Section 4 describes the xx strategies.
    13. Section 3 and 4 show experimental studies for verifying the proposed model.
    14. Section 4 discusses a previous fuzzy set based approach to cost variance investigation.
    15. Section 4 gives a specific example of xxx.
    16. Section 4 is the experimental study to make a fuzzy model of memory process.
    17. Section 4 contains a discussion of the implication of the results of Section 2 and 3.
    18. Section 4 applies this fuzzy measure to the analysis of xx and illustrate its use on experimental data.
    19. Section 5 presents the primary results of the paper: a fuzzy set model ..
    20. Section 5 contains some conclusions plus some ideas for further work.
    21. Section 6 illustrates the model with an example.
    22. Various ways of justification and the reasons for their choice are discussed very briefly in Section 2.
    23. In Section 2 are presented the block diagram expression of a whole model of human DM system
    24. In Section 2 we shall list a collection of basic assumptions which a ... scheme must satisfy.
    25. In Section 2 of this paper, we present representation and uniqueness theorems for the fundamental measurement of fuzziness when the domain of discourse is order dense.
    26. In Section 3, we describe the preliminary results of an empirical study currently in progress to verify the measurement model and to construct membership functions.
    27. In Section 5 is analyzed the inference process through the two kinds of inference experiments...
This Section
    1. In this section, the characteristics and environment under which MRP is designed are described.
    2. We will provide in this section basic terminologies and notations which are necessary for the understanding of subsequent results.Next Section
    2. The next section describes the mathematics that goes into the computer implementation of such fuzzy logic statements.
    3. However, it is cumbersome for this purpose and in practical applications the formulae were rearranged and simplified as discussed in the next section.
    4. The three components will be described in the next two section, and an example of xx analysis of a computer information system will then illustrate their use.
    5. We can interpret the results of Experiments I and II as in the following sections.
    6. The next section summarizes the method in a from that is useful for arguments based on xx
Summary
    1. This paper concludes with a discussion of future research consideration in section 5.
    2. Section 5 summarizes the results of this investigation.
    3. Section 5 gives the conclusions and future directions of research.
    4. Section 7 provides a summary and a discussion of some extensions of the paper.
    5. Finally, conclusions and future work are summarized
    6. The basic questions posed above are then discussed and conclusions are drawn.
    7. Section 7 is the conclusion of the paper.
    Chapter 0. Abstract
    1. A basic problem in the design of xx is presented by the choice of a xx rate for the measurement of experimental variables.
    2. This paper examines a new measure of xx in xx based on fuzzy mathematics which overcomes the difficulties found in other xx measures.
    3. This paper describes a system for the analysis of the xx.
    4. The method involves the construction of xx from fuzzy relations.
    5. The procedure is useful in analyzing how groups reach a decision.
    6. The technique used is to employ a newly developed and versatile xx algorithm.
    7. The usefulness of xx is also considered.
    8. A brief methodology used in xx is discussed.
    9. The analysis is useful in xx and xx problem.
    10. A model is developed for a xx analysis using fuzzy matrices.
    11. Algorithms to combine these estimates and produce a xx are presented and justified.
    12. The use of the method is discussed and an example is given.
    13. Results of an experimental applications of this xx analysis procedure are given to illustrate the proposed technique.
    14. This paper analyses problems in
    15. This paper outlines the functions carried out by ...
    16. This paper includes an illustration of the ...
    17. This paper provides an overview and information useful for approaching
    18. Emphasis is placed on the construction of a criterion function by which the xx in achieving a hierarchical system of objectives are evaluated.
    19. The main emphasis is placed on the problem of xx
    20. Our proposed model is verified through experimental study.
    21. The experimental results reveal interesting examples of fuzzy phases of: xx, xx
    22. The compatibility of a project in terms of cost, and xx are likewise represented by linguistic variables.
    23. A didactic example is included to illustrate the computational procedure
Chapter 1. Introduction
    Time
    1. Over the course of the past 30 years, .. has emerged form intuitive
    2. Technological revolutions have recently hit the industrial world
    3. The advent of ... systems for has had a significant impact on the
    4. The development of ... is explored
    5. During the past decade, the theory of fuzzy sets has developed in a variety of directions
    6.The concept of xx was investigated quite intensively in recent years
    7. There has been a turning point in ... methodology in accordance with the advent of ...
    8. A major concern in ... today is to continue to improve...
    9. A xx is a latecomer in the part representation arena.
    10. At the time of this writing, there is still no standard way of xx
    11. Although a lot of effort is being spent on improving these weaknesses, the efficient and effective method has yet to be developed.
    12. The pioneer work can be traced to xx [1965].
    13. To date, none of the methods developed is perfect and all are far from ready to be used in commercial systems.
Objective / Goal / Purpose
    1. The purpose of the inference engine can be outlined as follows:
    2. The ultimate goal of the xx system is to allow the non experts to utilize the existing knowledge in the area of manual handling of loads, and to provide intelligent, computer aided instruction for xxx.
    3. The paper concerns the development of a xx
    4. The scope of this research lies in
    5. The main theme of the paper is the application of rule based decision making.
    6. These objectives are to be met with such thoroughness and confidence as to permit ...
    7. The objectives of the ... operations study are as follows:
    8. The primary purpose/consideration/objective of
    9. The ultimate goal of this concept is to provide
    10. The main objective of such a ... system is to
    11. The aim of this paper is to provide methods to construct such probability distribution.
    12. In order to achieve these objectives, an xx must meet the following requirements:
    13. In order to take advantage of their similarity
    14. more research is still required before final goal of ... can be completed
    15. In this trial, the objective is to generate...
    16. for the sake of concentrating on ... research issues
    17. A major goal of this report is to extend the utilization of a recently developed procedure for the xx.
    18. For an illustrative purpose, four well known OR problems are studied in presence of fuzzy data: xx.
    19. A major thrust of the paper is to discuss approaches and strategies for structuring ..methods
    20. This illustration points out the need to specify
    21. The ultimate goal is both descriptive and prescriptive.
    22. Chapter 2. Literature Review
    23. A wealth of information is to be found in the statistics literature, for example, regarding xx
    24. A considerable amount of research has been done .. during the last decade
    25. A great number of studies report on the treatment of uncertainties associated with xx.
    26. There is considerable amount of literature on planning
    27. However, these studies do not provide much attention to uncertainty in xx.
    28. Since then, the subject has been extensively explored and it is still under investigation as well in
    methodological aspects as in concrete applications.
    29. Many research studies have been carried out on this topic.
    30. Problem of xx draws recently more and more attention of system analysis.
    31. Attempts to resolve this dilemma have resulted in the development of
    32. Many complex processes unfortunately, do not yield to this design procedure and have, therefore, not yet been automated.
    33. Most of the methods developed so far are deterministic and /or probabilistic in nature.
    34. The central issue in all these studies is to
    35. The problem of xx has been studied by other investigators, however, these studies have been based upon classical statistical approaches.
    36. Applied ... techniques to
    37. Characterized the ... system as
    38. Developed an algorithm to
    39. Developed a system called ... which
    40. Uses an iterative algorithm to deduce
    41. Emphasized the need to
    42. Identifies six key issues surrounding high technology
    43. A comprehensive study of the... has been undertaken
    44. Much work has been reported recently in these filed
    45. Proposed/Presented/State that/Described/Illustrated/
    Indicated/Has shown / showed/Address/Highlights
    46. Point out that the problem of
    47. A study on ...was done / developed by []
    48. Previous work, such as [] and [], deal only with
    49. The approach taken by [] is
    50. The system developed by [] consists
    51. A paper relevant to this research was published by []
    52. []'s model requires consideration of...
    53. []' model draws attention to evolution in human development
    54. []'s model focuses on...
    55. Little research has been conducted in applying ... to
    56. The published information that is relevant to this research...
    57. This study further shows that
    58. Their work is based on the principle of
    59. More history of ... can be found in xx et al. [1979].
    60. Studies have been completed to established
    61. The ...studies indicated that
    62. Though application of xx in the filed of xx has proliferated in recent years, effort in analyzing xx, especially xx, is lacking.
    Problem / Issue / Question
    63. Unfortunately, real-world engineering problems such as manufacturing planning do not fit well with this narrowly defined model. They tend to span broad activities and require consideration of multiple aspects.
    64. Remedy / solve / alleviate these problems
    67. ... is a difficult problem, yet to be adequately resolved
    68. Two major problems have yet to be addressed
    69. An unanswered question
    70. This problem in essence involves using x to obtain a solution.
    71. An additional research issue to be tackled is ....
    72. Some important issues in developing a ... system are discussed
    73. The three prime issues can be summarized:
    74. The situation leads to the problem of how to determine the ...
    75. There have been many attempts to
    76. It is expected to be serious barrier to
    77. It offers a simple solution in a limited domain for a complex
spearshield 财富 +30 Rewards for sharing! 2010-11-13
离线jiejiehit
603
688
22
只看该作者 1楼 发表于: 2010-10-31 | 石油求职招聘就上: 阿果石油英才网
好资料啊,值的学习啊,谢谢分享
离线killshmdnm
358
259
只看该作者 2楼 发表于: 2010-10-31 | 石油求职招聘就上: 阿果石油英才网
好资料啊,一看头就大了
离线sundk
871
22775
109
只看该作者 3楼 发表于: 2010-10-31 | 石油求职招聘就上: 阿果石油英才网
很有用呀
离线limin18129
34
只看该作者 4楼 发表于: 2010-11-03 | 石油求职招聘就上: 阿果石油英才网
谢谢,good
离线qks80
33
39
只看该作者 5楼 发表于: 2010-11-03 | 石油求职招聘就上: 阿果石油英才网
好东西,收了,谢谢,没有整理word版的么?
离线qks80
33
39
只看该作者 6楼 发表于: 2010-11-03 | 石油求职招聘就上: 阿果石油英才网
后面的部分如:discussion,acknowledgements,et al.
离线aagii545
801
300
只看该作者 7楼 发表于: 2011-01-05 | 石油求职招聘就上: 阿果石油英才网
好好学习一下,以后写论文用得上
离线tylllr
124
218
只看该作者 8楼 发表于: 2011-01-05 | 石油求职招聘就上: 阿果石油英才网
好是好,不过怎没有中文翻译啊。。
离线chaokai2012
273
254
只看该作者 9楼 发表于: 2011-01-06 | 石油求职招聘就上: 阿果石油英才网
感谢分享
