10月30日上午,海洋石油工程(青岛)有限公司(以下简称中海油)200英尺自升式钻井船“海洋石油921/海洋石油922”命名暨交船仪式在中海油制造场地隆重举行。
文章链接:
http://www.cosl.com.cn/ens/News/Releases/2010-11-01/9889.shtmlCOSL 921 & 922 delivery on 30-Oct-2010
Time:2010-11-01
China Oilfield Services Limited (COSL) announces that two of its newly built 200-feet jack-up platforms, COSL921and 922, were successfully delivered at China Offshore Oil Engineering(Qingdao) Co. Ltd. (COOEC) on 30 October 2010.
COSL921 and 922 are jack-up drilling rigs of F&G’s L780 ModII design, two of four rigs contracted to COOEC. The operation criteria are of 200 feet water depth, 6,000m drilling depth, and -20°C temperature. With size of 57.2m long, 53.34m wide and 7.62m high they can support up to 100 crews. The helicopter desired for S-61 choppers is equipped as well. The rigs intended to operate drilling in China Bohai Bay are dual classed by ABS and CCS. The sister vessels, COSL923 and 924 are still under construction and suppose to be delivered in early next year.
海油工程(青岛)为油服新造的两条自升式钻井船在2010.10.30日交付。
这两条自升式钻井船命名为COSL 921 和 922,为美国F&G的L780 Mod II 型设计。海油工程一共将为油服造四条这样的系列船,另外两条COSL 923 和 924 预计在明年初交船。
该钻井船的设计指标为:最大水深200英尺约60多米,最大钻井深度6000米,适用温度在-20°以上。船型尺寸为,57.2x53.34x7.62米。可供100人居住,并配备登载S-61型直升机的直升机平台。COSL 921 和 922 入ABS和CCS双船级,将在中国渤海湾作业。
图片同样来源于油服官网链接。
