  • 2162阅读
  • 9回复
【每日一词】之 solution gas drive--来自www.slb.com [复制链接]
离线tkj
3697
1932
251
只看楼主 倒序阅读 使用道具 0楼 发表于: 2011-06-09 | 石油求职招聘就上: 阿果石油英才网
 solution gas driver溶解气驱
 1.  n.  [Well Completions] ID: 2828
A type of reservoir-drive system in which the energy for the transport and production of reservoir fluids is derived from the gas dissolved in the fluid. As reservoir fluids enter the wellbore, changing pressure conditions cause the gas to break from solution to create a commingled flow of gas and liquid that aids production.
抱歉最近因为网站的原因和我个人的原因耽误给大家做活动了
人人为我,我为人人,加入阿果石油网。
离线tkj
3697
1932
251
只看该作者 1楼 发表于: 2011-06-11 | 石油求职招聘就上: 阿果石油英才网
怎么没人来呢
人人为我,我为人人,加入阿果石油网。
离线vicky68
498
472
15
只看该作者 2楼 发表于: 2011-06-13 | 石油求职招聘就上: 阿果石油英才网
是完井的词汇吧,学习了
离线wwwangwangb2
56
317
只看该作者 3楼 发表于: 2011-06-14 | 石油求职招聘就上: 阿果石油英才网
每日一词办的很好啊
离线liuzupeng
100
431
只看该作者 4楼 发表于: 2011-06-19 | 石油求职招聘就上: 阿果石油英才网
Solution gas drive
This mechanism (also known as depletion drive) depends on the associated gas of the oil. The virgin reservoir may be entirely liquid, but will be expected to have gaseous hydrocarbons in solution due to the pressure. As the reservoir depletes, the pressure falls below the bubble point, and the gas comes out of solution to form a gas cap at the top. This gas cap pushes down on the liquid helping to maintain pressure.
Gas cap drive
In reservoirs already having a gas cap (the virgin pressure is already below bubble point), the gas cap expands with the depletion of the reservoir, pushing down on the liquid sections applying extra pressure.
Aquifer (water) drive
Below the hydrocarbons may be a ground water aquifer. Water, as with all liquids, is compressible to a small degree. As the hydrocarbons are depleted, the reduction in pressure in the reservoir causes the water to expand slightly. Although this expansion is minute, if the aquifer is large enough, this will translate into a large increase in volume, which will push up on the hydrocarbons, maintaining pressure.
tkj 财富 +10 参与 2011-06-20
离线sk888888
5990
10855
只看该作者 5楼 发表于: 2011-07-10 | 石油求职招聘就上: 阿果石油英才网
很好,又学到一个新词
离线czq8
474
669
只看该作者 6楼 发表于: 2011-07-11 | 石油求职招聘就上: 阿果石油英才网
学到了很多新知识。solution-gas-drive primary oil溶解气驱一次采油量
solution-gas-drive reservoir溶解气驱油藏
solution gas drive溶解气驱;溶气驱;内部气驱
solution gas in place油层溶解气
solution gas drive pool溶解气驱油藏
Dissolved gas,Solution gas溶解气
solution bio-gas drive溶解生物气驱油
solution gas-oil ratio溶解气油比
solution gas-gas cap drive气顶综合驱动
外行可不知道什么是正确的。
tkj 财富 +5 版块管理 2011-07-24
190
3313
只看该作者 7楼 发表于: 2011-07-11 | 石油求职招聘就上: 阿果石油英才网
回 4楼(liuzupeng) 的帖子
赞一个。希望每日一次能有更多人参与。
809
489
39
只看该作者 8楼 发表于: 2012-02-26 | 石油求职招聘就上: 阿果石油英才网
Newspace added or accommondation created——新增可容空间
是指在沉积期间,由于海平面、构造沉降等参数的变化所形成的新的可容空间。它不但包括沉积前未被沉积物充填而残存的空间。
摘自《层序底层学》
离线woollloow
40
只看该作者 9楼 发表于: 2012-03-14 | 石油求职招聘就上: 阿果石油英才网
贵在坚持
