Paradigm Geolog combines new tools for the analysis of geophysical data, excellent graphics performance and flexible modular structure, as well as user-friendly environment for creating industry standard petrophysical analysis, well data management and geological interpretation. Paradigm Geolog implements all of the automated procedure, starting with the boot and edit the log data, and up to the interpretation of GIS, reporting and documenting results in a shared environment that eliminates the need for separate applications for each task. modular structure of Paradigm Geolog provides the opportunity to work in a generic environment, which can be configured by novice users without sacrificing at the same depth and breadth needed for advanced users. Analysis of petrophysical uncertainties. New module - a functional block association, you can easily generate different scenarios using different parameter values, and facilitates future analysis by the Monte Carlo method. New types of data display make it easy to compare different scenarios. module Correlator . The improvements include the implementation of split trunk, taking into account the turning points. Now, the plates may include non-monotonically ordered data, and can display color attributes of the dividing lines and fill. When simulating an advanced interactive feature selection of objects for easier interpretation provides an initial selection of objects. Module Geosteer used to construct a section along the trajectories of horizontal wells, imported into the Paradigm Geolog from external applications.
If you need pls PM me, I'll change with IP4 license activator.
Thanks all
