case drain flow 泄漏(流动)
Case drain temperature 泄漏(流体的)温度
以下是例句
1、Viscosity was calculated as a second feature using a standard hydraulic fluid regression of case drain temperature.
2、Both the viscosity and fused feature isolate the effects of degradation to case drain flow.
3、During the test run, the internal leakage rates through the tested parts (case drain flow for the two pumps and leakage flow through the electro-hydraulic servo-valve (EHSV)) were monitored. There was no increase in internal leakage rates
