A、常规流量换算:
1m3/min=1000L/min=35.32cfm
1L/min=0.001m3/min=0.03532cfm
1cfm=28.32L/min=0.02831m3/min
B、常规功率换算:
1KW=1.34104HP
1HP=0.7355KW
B、 常规压力单位换算:
1Kg=0.981bar=0.0981Mpa=98.1Kpa=14.22psi
1bar=1.02Kg=0.1 Mpa=100 Kpa=14.5psi
1 Mpa=10.2 Kg=10 bar=1000 Kpa=145 psi
1 psi=0.07031 Kg=0.06893 bar=6.893 Kpa
