请教一个问题,使用vista的地表一致性剩余静校正时,使用vista的例子,将原先的静校正视窗改成了沿着一个拾取的层位做,结果作业出错
“Flow File: C:\2D Land Straight Line\2D Land Straight Line\2DLandStraightLine-files\Flows\Flow G_Stkpower1.flw
Current Log File : C:\2D Land Straight Line\2D Land Straight Line\2DLandStraightLine-files\vistalogs\2DLandStraightLine.vl12
Flow Log File: C:\2D Land Straight Line\2D Land Straight Line\2DLandStraightLine-files\vistalogs\2DLandStraightLine.vf12
CHECK REPLACEMENT VARIABLE STRINGS
BUILD EXECUTION FLOW
CHECK EXECUTION PARAMETERS
*** Error Command: #5 - Stack Power Optimization (Residual Statics). [STATICS]
>> Time Horizon no Implemented at this Time
***** ERROR in Flow *****
** Flow Details **
5 Total Execution Commands.
ID# In-Traces Out-Traces Time
1 Input Data 0 0 Secs: 0.1
3 True Surface Normal Move-Out 0 0 Secs: 0
2 Muting - Interp, Offset[Trace] Dependent 0 0 Secs: 0
4 Automatic Gain Control(AGC) L1/L2 Norm Equalization 0 0 Secs: 0
5 Stack Power Optimization (Residual Statics). 0 0 Secs: 0
Total Time: Secs: 0.1
