最近调研了一下常用的测井曲线缩写~及其英文全称。和果友一起分享,有不足或者错误,烦请大家指正~~~~大家一起学习一起提高~~~
~Parameter Information Block
#MNEM.UNIT Value Description
~Curve Information Block
#MNEM.UNIT API Code Curve Description
DEPT .F :0 Index
KINT .MD :1 Intrinsic Permeability
PIGN .V/V :2 Effective Porosity, VISO, VPAR, and Bound Water Removed
SUWI .V/V :3 Non-Clay Water Intergranular Water Saturation for Undisturbed Zone
SXWI .V/V :4 Non-Clay Water Intergranular Water Saturation for the Flushed Zone
VCL .V/V :5 Volume of Clay Type Material Relative to Total Volume
~Ascii Data Section
DEPT .F :0 Index
FLAG . :1 General Indicator Flag
KINT .MD :2 Intrinsic Permeability
PHIT .V/V :3 Total Porosity_ includes all forms of porosity, including that occupied by bound fluids, and is independent of rock and fluid materials and of environmental effects
PIGE .V/V :4 Effective Porosity Less Irreducible Water
RWA .OHMM :5 Apparent Formation Water Resistivity
SUWI .V/V :6 Non-Clay Water Intergranular Water Saturation for Undisturbed Zone
VCL .V/V :7 Volume of Clay Type Material Relative to Total Volume
VCLC .V/V :8 Volume of Calcite Relative to Total Volume
VQUA .V/V :9 Volume of Quartz Relative to Total Volume
DEPT.F :
SP .MEGV : Spontaneous Potential
SN .OHMM : Short Normal Resistivity (16 inch spacing)
ILD .OHMM : Induction Deep Resistivity
CILD.MMHO : Calibrated Induction Deep Conductivity
~Curve Information Section
#MNEM.UNIT API CODE : Curve description
DEPT.F :
MCAL.IN : MLT (Microlog) Caliper
MNOR.OHMM : Micro Normal Resistivity
MINV.OHMM : Micro Inverse Resistivity
DEPT.F :
CALI.IN : Caliper
TTI .US/F : Transit Time Integrated
INTT.US/F : Interval Transit Time
DEPT.F 00 000 000 000:
BS .IN 00 000 000 000: BIT SIZE
CALI.IN 00 000 000 000: CALIPER
CS .F/M 00 000 000 000: CABLE SPEED
DRHO.G/CC 00 000 000 000: DENSITY CORRECTION
DT .US/F 00 000 000 000: DELTA TIME COMPRESSIVE
GR .GAPI 00 000 000 000: NATURAL GAMMA
ITT . 00 000 000 000: INTEGRATED TRAVEL TIME MARK
MINM. 00 000 000 000: MINUTE MARK FLAG
NPHI.DECP 00 000 000 000: NEUTRON POROSITY
PE . 00 000 000 000: PHOTO-ELECTRIC FACTOR
RHOB.G/CC 00 000 000 000: BULK DENSITY
SDT2.US/F 00 000 000 000: DELTA T (2 FOOT)
TENS.LBS 00 000 000 000: CABLE TENSION
AHVT.FT3 00 000 000 000: ANNULAR VOLUME TOTAL
BHVT.FT3 00 000 000 000: BOREHOLE VOLUME TOTAL
LLD .OHMM 00 000 000 000: LATEROLOG DEEP RESISTIVITY
LLS .OHMM 00 000 000 000: LATEROLOG SHALLOW RESISTIVITY
MSFL.OHMM 00 000 000 000: MSFL (FRXO)
SP .MV 00 000 000 000: SPONTANEOUS POTENTIAL
STRT .F 960.0 :START DEPTH
STOP .F 6697.0 :STOP DEPTH
STEP .F 0.5 :STEP
NULL . -999.25 :NULL VALUE
COMP . C & C Energia (Barbados) Suc. Colombia :COMPANY
WELL . :WELL
FLD . Mandarina :FIELD
LOC . 3* East Bogota :LOCATION
CNTY . Nabors 215 :COUNTY
STAT . Caqueta :STATE
CTRY . Colombia :COUNTRY
API . :API NUMBER
UWI . :UNIQUE WELL ID
DATE . 20-Aug-2008 :LOG DATE {DD-MMM-YYYY}
SRVC . Schlumberger :SERVICE COMPANY
LATI .DEG 1* 20' 40" N :LATITUDE
LONG .DEG 75* 54' 15.9" W :LONGITUDE
GDAT . :GeoDetic Datum
~PARAMETER INFORMATION
#MNEM.UNIT VALUE DESCRIPTION
RMFB .OHMM 0.77863 :Resistivity of Mud Filtrate - BHT
RMB .OHMM 0.91116 :Resistivity of Mud - BHT
MCST .DEGF 77.30000 :Mud Cake Sample Temperature
RMCS .OHMM 2.43000 :Resistivity of Mud Cake Sample
MFST .DEGF 78.50000 :Mud Filtrate Sample Temperature
RMFS .OHMM 1.39500 :Resistivity of Mud Filtrate Sample
MST .DEGF 77.90000 :Mud Sample Temperature
RMS .OHMM 1.64400 :Resistivity of Mud Sample
WITN . Germabn Arce :Witness's Name
ENGI . Daniel Meyer :Engineer's Name
LONG . 75* 54' 15.9 W :Longitude
LATI . 1* 20' 40 N :Latitude
FL2 . E 797 022.00 m :Field Location Line 2
FL1 . N 640 185.80 m :Field Location Line 1
FL . 3* East Bogota :Field Location
FN . Mandarina :Field Name
WN . Yataro-1 ST :Well Name
CN . C & C Energia (Barbados) Suc. Colombia :Company Name
RUN . 1 :RUN NUMBER
PDAT . GROUND LEVEL :Permanent Datum
EPD .F 911.000000 :Elevation of Permanent Datum above Mean Sea Level
LMF . DRILL FLOOR :Logging Measured From (Name of Logging Elevation Reference)
APD .F 17.000000 :Elevation of Depth Reference (LMF) above Permanent Datum
~CURVE INFORMATION
#MNEM.UNIT API CODE DESCRIPTION
DEPT .F :DEPTH (BOREHOLE) {F10.1}
TDEP ..1IN :HALS River Depth Index {F13.2}
TIME .MS :HALS River Time Index {F13.2}
BS .IN :Bit Size {F13.2}
BHRM .OHMM :Borehole Mud Resistivity {F13.2}
CLOS .F :Closure {F13.2}
CWEL .D/F :Curvature of the Well {F13.2}
ED .F :East Departure {F13.2}
ND .F :North Departure {F13.2}
TVDE .F :True Vertical Depth {F13.2}
VSEC .F :Vertical Section {F13.2}
AREA .FT2 :Area of Borehole {F13.2}
AFCD .FT2 :Area of Future Casing {F13.2}
ABS .FT2 :Area of Bit {F13.2}
DCAL .IN :Differential Caliper {F13.2}
FCD .IN :Future Casing Diameter {F13.2}
HDAR .IN :Hole Diameter from Area {F13.2}
IHV .F3 :Integrated Hole Volume {F13.2}
ICV .F3 :Integrated Cement Volume {F13.2}
HTEM .DEGF :HTC Temperature {F13.2}
GR .GAPI :Gamma-Ray {F13.2}
DF .LBF :Uncalibrated Downhole Force {F13.2}
SP .MV :SP Shifted {F13.2}
HCAL .IN :HRCC Cal. Caliper {F13.2}
HLLD .OHMM :HALS Laterolog Deep Resistivity {F13.2}
HLLS .OHMM :HALS Laterolog Shallow Resistivity {F13.2}
