各位果友好:我在网上找到“ResForm宏程序岩性抽稀”的宏程序,在ResForm加载后,运行宏,弹出这个界面
岩性道选择了,然后左右两边的顶深、底深和岩性应该指的是什么?我把岩性描述的整个井段输入,点“抽稀”按钮没反应,也没有出错提示。请问谁用过?或是懂程序的高手给指点一下,非常感谢!我把宏程序也附上了。
void buttonHelp_Click(object sender, EventArgs e)
string strReadme = "此程序实现岩性抽稀功能,将厚度小于指定数值的岩性合并为上一个岩性";
MessageBox.Show(strReadme);
void comboBoxLitho_SelectedIndexChanged(object sender, EventArgs e)
ComboBox comboBoxLitho = (ComboBox)sender;
GroupBox groupBox1 = (GroupBox)comboBoxLitho.Parent;
DataGridView dataGridViewShowLitho = (DataGridView)groupBox1.Controls["dataGridViewShowLitho"];
dataGridViewShowLitho.Rows.Clear();
SLithoTrace litho_Trace ;
string[] strRow =
new string[4];
if(comboBoxLitho.SelectedIndex > -1)
litho_Trace = comboBoxLitho.SelectedItem;
foreach(LithoLayer ss in litho_Trace )
strRow[0] = ss.Top;
strRow[1] = ss.Bottom;
strRow[2] = ss.Thickness;
strRow[3] = ss.Litho;
dataGridViewShowLitho.Rows.Add(strRow);
MessageBox.Show("岩性浏览完成!","信息提示",MessageBoxButtons.OK,MessageBoxIcon.Warning);
void buttonExecute_Click(object sender, EventArgs e)
Button buttonExecute = (Button)sender;
Form mainForm = (Form)buttonExecute.Parent;
GroupBox groupBox1 = (GroupBox)mainForm.Controls["groupBox1"];
ComboBox comboBoxLitho = (ComboBox)groupBox1.Controls["comboBoxLitho"];
DataGridView dataGridViewNewLitho = (DataGridView)mainForm.Controls["dataGridViewNewLitho"];
TextBox textBoxValue = (TextBox)mainForm.Controls["textBoxValue"];
dataGridViewNewLitho.Rows.Clear();
float thick_value = float.Parse(textBoxValue.Text);
float litho_Thickness;
string[] strRow = new string[3];
// int ;//标记连续岩性厚度大于或者等于thick_value
int flat_small = 0;
int flat_big = 0;
ArrayList list_Litho = new ArrayList();
list_Litho.Clear();
list_Litho.Add(ss);
LithoLayer ss;
for(int i = 0 ; i < list_Litho.Count ; i++)
ss = (LithoLayer)list_Litho
litho_Thickness = ss.Thickness;
if(thick_value <= litho_Thickness && flat_big == 1)
ss = (LithoLayer)list_Litho[i-1];
dataGridViewNewLitho.Rows.Add(strRow);
i--;
flat_big = 0;
continue;
if(thick_value > litho_Thickness && flat_small == 0)
if(flat_big == 1)
continue;
strRow[0] = ss.Top;
flat_small = 1;
if(thick_value <= litho_Thickness && flat_big == 0)
if(flat_small == 1)
strRow[2] = ss.Litho;
flat_small = 0;
continue;
strRow[0] = ss.Top;
flat_big = 1;
list_Litho.Clear();
DialogResult res = MessageBox.Show("是否创建新岩性道并加载抽稀后数据?\n点'是'创建并加载数据,点'否'取消加载;","信息提示",MessageBoxButtons.YesNo,MessageBoxIcon.Question);
if(res == DialogResult.Yes)
SLithoTrace[] AllLitho = this.Channels.GetLithoTraces();
SLithoTrace new_LithoTrace = this.Channels.AddTrace(WellTraceTypes.Litho,"NEW_litho"+AllLitho.Length.ToString());
new_LithoTrace.Title = litho_Trace.Title;
new_LithoTrace.ColorColumnWidth = 0;
int dgvRowCount = dataGridViewNewLitho.GetCellCount(DataGridViewElementStates.None) / 3;
float lithotop;
float lithoBottom;
string lithoname1;
for(int i = 0 ; i < (dgvRowCount - 1); i++)
lithotop = dataGridViewNewLitho[0,i].Value;
lithoBottom = dataGridViewNewLitho[1,i].Value;
lithoname1 = dataGridViewNewLitho[2,i].Value;
new_LithoTrace.Add(lithotop ,lithoBottom ).Litho = lithoname1 ;
MessageBox.Show("岩性加载完成!");
else if(res == DialogResult.No)
return;
void main()
System.Windows.Forms.Form mainForm;
System.Windows.Forms.GroupBox groupBox1;
System.Windows.Forms.ComboBox comboBoxLitho;
System.Windows.Forms.Label label1;
System.Windows.Forms.DataGridView dataGridViewShowLitho;
System.Windows.Forms.DataGridView dataGridViewNewLitho;
System.Windows.Forms.Button buttonExecute;
System.Windows.Forms.Button buttonCancel;
System.Windows.Forms.Button buttonHelp;
System.Windows.Forms.Label label2;
System.Windows.Forms.TextBox textBoxValue;
System.Windows.Forms.Label label3;
System.Windows.Forms.DataGridViewTextBoxColumn DepthTop;
System.Windows.Forms.DataGridViewTextBoxColumn DepthBottom;
System.Windows.Forms.DataGridViewTextBoxColumn LithoThickness;
System.Windows.Forms.DataGridViewTextBoxColumn Litho1;
System.Windows.Forms.DataGridViewTextBoxColumn TopDepth;
System.Windows.Forms.DataGridViewTextBoxColumn BottomDepth;
System.Windows.Forms.DataGridViewTextBoxColumn LithoName1;
mainForm = new System.Windows.Forms.Form();
groupBox1 = new System.Windows.Forms.GroupBox();
label1 = new System.Windows.Forms.Label();
comboBoxLitho = new System.Windows.Forms.ComboBox();
dataGridViewShowLitho = new System.Windows.Forms.DataGridView();
dataGridViewNewLitho = new System.Windows.Forms.DataGridView();
buttonExecute = new System.Windows.Forms.Button();
buttonCancel = new System.Windows.Forms.Button();
buttonHelp = new System.Windows.Forms.Button();
label2 = new System.Windows.Forms.Label();
textBoxValue = new System.Windows.Forms.TextBox();
label3 = new System.Windows.Forms.Label();
DepthTop = new System.Windows.Forms.DataGridViewTextBoxColumn();
DepthBottom = new System.Windows.Forms.DataGridViewTextBoxColumn();
LithoThickness = new System.Windows.Forms.DataGridViewTextBoxColumn();
Litho1 = new System.Windows.Forms.DataGridViewTextBoxColumn();
TopDepth = new System.Windows.Forms.DataGridViewTextBoxColumn();
BottomDepth = new System.Windows.Forms.DataGridViewTextBoxColumn();
LithoName1 = new System.Windows.Forms.DataGridViewTextBoxColumn();
// groupBox1
groupBox1.Controls.Add(dataGridViewShowLitho);
groupBox1.Controls.Add(comboBoxLitho);
groupBox1.Controls.Add(label1);
groupBox1.Location = new System.Drawing.Point(8, 6);
groupBox1.Name = "groupBox1";
groupBox1.Size = new System.Drawing.Size(248, 389);
groupBox1.TabIndex = 0;
groupBox1.TabStop = false;
groupBox1.Text = "选择岩性道";
// label1
label1.AutoSize = true;
label1.Location = new System.Drawing.Point(17, 23);
label1.Name = "label1";
label1.Size = new System.Drawing.Size(53, 12);
label1.TabIndex = 0;
label1.Text = "岩 性 道";
// comboBoxLitho
comboBoxLitho.FormattingEnabled = true;
comboBoxLitho.ItemHeight = 12;
comboBoxLitho.DropDownHeight = 60;
comboBoxLitho.Location = new System.Drawing.Point(87, 19);
comboBoxLitho.Name = "comboBoxLitho";
comboBoxLitho.Size = new System.Drawing.Size(140, 20);
comboBoxLitho.TabIndex = 1;
comboBoxLitho.SelectedIndexChanged += new EventHandler(this.comboBoxLitho_SelectedIndexChanged);
// dataGridViewShowLitho
dataGridViewShowLitho.ColumnHeadersHeightSizeMode = System.Windows.Forms.DataGridViewColumnHeadersHeightSizeMode.AutoSize;
dataGridViewShowLitho.Columns.AddRange(new System.Windows.Forms.DataGridViewColumn[] {
DepthTop,
DepthBottom,
LithoThickness,
Litho1});
dataGridViewShowLitho.Location = new System.Drawing.Point(6, 53);
dataGridViewShowLitho.Name = "dataGridViewShowLitho";
dataGridViewShowLitho.RowTemplate.Height = 23;
dataGridViewShowLitho.Size = new System.Drawing.Size(236, 330);
dataGridViewShowLitho.TabIndex = 2;
// dataGridViewNewLitho
dataGridViewNewLitho.ColumnHeadersHeightSizeMode = System.Windows.Forms.DataGridViewColumnHeadersHeightSizeMode.AutoSize;
dataGridViewNewLitho.Columns.AddRange(new System.Windows.Forms.DataGridViewColumn[] {
TopDepth,
BottomDepth,
LithoName1});
dataGridViewNewLitho.Location = new System.Drawing.Point(265, 64);
dataGridViewNewLitho.Name = "dataGridViewNewLitho";
dataGridViewNewLitho.RowTemplate.Height = 23;
dataGridViewNewLitho.Size = new System.Drawing.Size(242, 296);
dataGridViewNewLitho.TabIndex = 1;
// buttonExecute
buttonExecute.Location = new System.Drawing.Point(265, 371);
buttonExecute.Name = "buttonExecute";
buttonExecute.Size = new System.Drawing.Size(49, 23);
buttonExecute.TabIndex = 2;
buttonExecute.Text = "抽稀";
buttonExecute.UseVisualStyleBackColor = true;
buttonExecute.Click += new EventHandler(this.buttonExecute_Click);
// buttonCancel
buttonCancel.Location = new System.Drawing.Point(351, 371);
buttonCancel.Name = "buttonCancel";
buttonCancel.Size = new System.Drawing.Size(49, 23);
buttonCancel.TabIndex = 2;
buttonCancel.Text = "退出";
buttonCancel.UseVisualStyleBackColor = true;
buttonCancel.DialogResult = DialogResult.Cancel;
// buttonHelp
buttonHelp.Location = new System.Drawing.Point(437, 371);
buttonHelp.Name = "buttonHelp";
buttonHelp.Size = new System.Drawing.Size(49, 23);
buttonHelp.TabIndex = 2;
buttonHelp.Text = "帮助";
buttonHelp.UseVisualStyleBackColor = true;
buttonHelp.Click += new EventHandler(this.buttonHelp_Click);
// label2
label2.AutoSize = true;
label2.Location = new System.Drawing.Point(263, 39);
label2.Name = "label2";
label2.Size = new System.Drawing.Size(95, 12);
label2.TabIndex = 3;
label2.Text = "岩性厚度小于(m)";
// textBoxValue
textBoxValue.Location = new System.Drawing.Point(360, 35);
textBoxValue.Name = "textBoxValue";
textBoxValue.Size = new System.Drawing.Size(100, 21);
textBoxValue.TabIndex = 4;
textBoxValue.Text = "0.5";
// label3
label3.AutoSize = true;
label3.Location = new System.Drawing.Point(263, 15);
label3.Name = "label3";
label3.Size = new System.Drawing.Size(167, 12);
label3.TabIndex = 5;
label3.Text = "输入合并岩性厚度小于某值时:";
// DepthTop
DepthTop.HeaderText = "顶深";
DepthTop.Name = "DepthTop";
DepthTop.SortMode = System.Windows.Forms.DataGridViewColumnSortMode.NotSortable;
DepthTop.Width = 60;
// DepthBottom
DepthBottom.HeaderText = "底深";
DepthBottom.Name = "DepthBottom";
DepthBottom.SortMode = System.Windows.Forms.DataGridViewColumnSortMode.NotSortable;
DepthBottom.Width = 60;
LithoThickness.HeaderText = "厚度";
LithoThickness.Name = "DepthBottom";
LithoThickness.SortMode = System.Windows.Forms.DataGridViewColumnSortMode.NotSortable;
LithoThickness.Width = 60;
// Litho
Litho1.HeaderText = "岩性描述";
Litho1.Name = "Litho";
// TopDepth
TopDepth.HeaderText = "顶深";
TopDepth.Name = "TopDepth";
TopDepth.SortMode = System.Windows.Forms.DataGridViewColumnSortMode.NotSortable;
TopDepth.Width = 60;
// BottomDepth
BottomDepth.HeaderText = "底深";
BottomDepth.Name = "BottomDepth";
BottomDepth.SortMode = System.Windows.Forms.DataGridViewColumnSortMode.NotSortable;
BottomDepth.Width = 60;
// LithoName
LithoName1.HeaderText = "岩性描述";
LithoName1.Name = "LithoName";
// Form1
mainForm.AutoScaleDimensions = new System.Drawing.SizeF(6F, 12F);
mainForm.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font;
mainForm.ClientSize = new System.Drawing.Size(516, 407);
mainForm.Controls.Add(label3);
mainForm.Controls.Add(textBoxValue);
mainForm.Controls.Add(label2);
mainForm.Controls.Add(buttonHelp);
mainForm.Controls.Add(buttonCancel);
mainForm.Controls.Add(buttonExecute);
mainForm.Controls.Add(dataGridViewNewLitho);
mainForm.Controls.Add(groupBox1);
mainForm.FormBorderStyle = System.Windows.Forms.FormBorderStyle.FixedDialog;
mainForm.MaximizeBox = false;
mainForm.MinimizeBox = false;
mainForm.Name = "Form1";
mainForm.StartPosition = System.Windows.Forms.FormStartPosition.CenterScreen;
mainForm.Text = "岩性抽稀";
mainForm.Load += new EventHandler(this.mainForm_Load);
mainForm.ShowDialog();
void mainForm_Load(object sender, EventArgs e)
Form mainForm = (Form)sender;
comboBoxLitho.Items.Clear();
if(AllLitho.Length > 0 )
for(int i = 0 ; i < AllLitho.Length; i++)
comboBoxLitho.Items.Add(AllLitho);
comboBoxLitho.DisplayMember = "Name";
