  • 1116阅读
  • 1回复
电泵管柱中,discharge tubing 是什么意思 [复制链接]
离线zll5815
141
只看楼主 倒序阅读 使用道具 0楼 发表于: 2016-10-31 | 石油求职招聘就上: 阿果石油英才网
— 本帖被 tkj 从 油气开采 移动到本区(2016-11-08) —
The presence of free gas at the pump intake and in the discharge tubing makes the process of equipment selection much more complicated and voluminous.  As the fluid (liquid and gas mixture) flows through the pump stages from intake to the discharge and through the discharge tubing, the pressure fluid properties (such as volume, density, etc.) continue to change.  The presence of free gas in the discharge tubing may create significant “gas-lift” effects  would could considerably reduce the required discharge pressure.
离线dashing
2626
866
只看该作者 1楼 发表于: 2016-11-21 | 石油求职招聘就上: 阿果石油英才网
这个discharge tubing就是指从吸入口到油管出口(井口)这一段。
内容来自Android手机客户端
