  • 2029阅读
  • 6回复
绘制等值线的源代码(C) [复制链接]
离线坐看云起
11640
10643
1536
只看楼主 倒序阅读 使用道具 0楼 发表于: 2005-08-29 | 石油求职招聘就上: 阿果石油英才网
— 本帖被 笑韵 从 教程文档 移动到本区(2008-07-03) —
Well, Thanks to all you folks who replied, I now have a contour plotting
routine, that does its job fairly well. I've posted this code below. It
is not nearly runnable as other Unix programs go, but you could use it
if you need C code to start off with to do contour plotting.
It doesn't handle stuff like labelling etc. which is somewhat tricky.
Basically almost all of the respondents suggested dividing up the set of
discrete points into a set of triangles and then computing the intersection
of these rectangles with planes representing the contour levels. This way
we can process all the levels at once instead of the "crawler" type algorithms
which is what I had originally been trying to get to work.
To summarize their ideas: if P1=P[j],P2=P[i+1][j],P3=P[i+1][j+1]
and P4=P[j+1] are four points, compute an intermediate point using
an interpolation scheme (in the code below, I just use averaging, but
one could obviously use fancier schemes). If this point is P, then the
foll. four triangles are used to compute the intersections with
contour levels l_0, .. l_n: P1 P2 P, P2 P3 P, P3 P4 P, P4 P1 P.
The intersection computation is quite trivial. Once these line segments have been
computed you could smooth them in 2d (the code below doesn't).
(see Michael Aramini's earlier posting for a variation on this that uses
rectangles directly -- He also mentions that you could use the diagonal edges
between two vertices instead of computing another intermediate point, but this
method has problems).
-Sundar
-----Sample Code Follows----------
* If you want try using this, you probably would need to provide
* graph_set_point(), and graph_draw_line(), besides do things like
* initialize window systems and so on.
* Please see the code for a note about data format
/* Definitions */
struct _array {
   float *a_elements;
   int   a_rows;
   int   a_cols;
   float *a_filler;
#define ELTS(a)    (a->a_elements)
#define NOROWS(a)  (a->a_rows)
#define NOCOLS(a)  (a->a_cols)
#define NOELTS(a)  (NOROWS(a) * NOCOLS(a))
#define COLUMN_VECTOR(a)   (NOCOLS((a)) == 1)
#define ROW_VECTOR(a)      (NOROWS((a)) == 1)
typedef struct _array *array;
typedef struct _graph *graph;
typedef struct _graph_port *graph_port;
struct _graph_port {
  char *p_window;  /* window system dependent private */
  double p_xmin;  /* object space min x-coordinate */
  double p_xmax;  /* object space max x-coordinate */
  double p_ymin;  /* object space min y-coordinate */
  double p_ymax;  /* object space max y-coordinate */
  double p_xscale;  /* this is just x-max - x-min */
  double p_yscale;  /* this is just y-max - y-min */
  int p_xorigin;  /* image space x-origin co-ordinate */
  int p_yorigin;  /* image space y-origin */
  int p_width;   /* image space width */
  int p_height;   /* image space height */
  int p_realwidth;  /* image space width */
  int p_realheight;  /* image space height */
  int p_curx;   /* where current point is in image */
  int p_cury;   /* y-coordinate of above */
  int p_line_offset;  /* line offset for labels */
  int p_autoscale;  /* in auto scaling on? */
  int p_include_xzero;  /* include x zero axis */
  int p_include_yzero;  /* include y zero axis */
  int p_titlefont;
  int p_ticfont;
  int p_labelfont;
  int p_margin;
  int p_ticstyle;  /* styles of tics (large, small or none) */
struct _graph {
   int g_no;   /* number associated with this graph */
   int g_points;  /* total number of points in graph */
   array g_x;   /* graph x points */
   array g_y;   /* graph y points */
   array g_z;   /* graph z points */
   char *g_line_label;  /* graph line label */
   char *g_xlabel;   /* graph x axis label */
   char *g_ylabel;  /* graph y axis label */
   char *g_title;  /* graph title */
   int  g_color;  /* graph color or pattern */
   int  g_type;  /* type of graph */
* Contour Plotting algorithm!
* This routine does the level comparison.
* It takes three points, a level, and a color.
* It intersects the triangle with a plane at the given level,
* and draws the line segments that denote these intersections.
#define swap_val(x, y, temp)    {temp = x; x = y; y = x; }
static
graph_segment(gp, x1, y1, z1, x2, y2, z2, x3, y3, z3, level, color)
graph_port gp;
double x1, y1, z1, x2, y2, z2, x3, y3, z3, level;
int color;
   double x, y, factor, temp;
   if(z1 >= z2) {
swap_val(x1, x2, temp);
swap_val(y1, y2, temp);
swap_val(z1, z2, temp);
   if(z2 > z3) {
if(z3 < z1) {
           swap_val(x1, x3, temp);
    swap_val(y1, y3, temp);
    swap_val(z1, z3, temp);
       swap_val(x2, x3, temp);
swap_val(y2, y3, temp);
swap_val(z2, z3, temp);
   /* z1 <= z2 <= z3 */
   if(level < z1 || level > z3) {
return;
   if((level == z1) && (z1 == z2) && (z2 != z3)) {
/* draw a line from x1, y1 to x2, y2 */
graph_set_point(gp, x1, y1, color);
graph_lineto(gp, x2, y2, color);
return 1;
   if((level == z3) && (z3 == z2) && (z1 != z2)) {
/* draw a line from x2, y2 to x3, y3 */
graph_set_point(gp, x2, y2, color);
graph_lineto(gp, x3, y3, color);
return 1;
   if(level == z2) {
/* we know that z2 is definitely between z1 and z3
   draw a line from P2 to point on segment between P1 and P3
if(z3 == z1) return 0;
factor = (level - z1)/(z3-z1);
x = x1 + (x3-x1) * factor;
y = y1 + (y3-y1) * factor;
graph_lineto(gp, x, y, color);
return 1;
   if(level < z2) {
/* P2 and P3 are above, P1 below */
if(z2 == z1 || z3 == z1) return 0;
factor = (level - z1) / (z2 - z1);
x = x1 + (x2 - x1) * factor;
y = y1 + (y2 - y1) * factor;
graph_set_point(gp, x, y, color);
factor = (level - z1) / (z3 - z1);
x = x1 + (x3 - x1) * factor;
y = y1 + (y3 - y1) * factor;
return 1;
   } else {
/* P1 and P2 are below, P3 above */
if(z3 == z1 || z3 == z2) return 0;
factor = (level - z2) / (z3 - z2);
x = x2 + (x3 - x2) * factor;
y = y2 + (y3 - y2) * factor;
return 1;
   return 0;
/* This is the main function */
/* Data formats;
g->g_x -> contains N x values.
g->g_y -> contains N y values.
g->g_z -> contains N^2 z values, which are interpreted as a
          matrix of z values, as
  z[0][0], z[0][1] .... z[0][N],
  z[1][0], ... upto z[N][N].
   (horizontal sweep from X_min to X_max, inner loop
    going from Y_min to Y_max);
  This way we only store N^2+2N values instead of 3N^2 values.
graph_plot_contour(gp, g, color)
graph_port gp;
graph g;
int color;
   register int i, j;
   float *x, *y, *z;
   float minz, maxz;
   double xavg, yavg, zavg;
   double level, diff;
   double zij, zipj, zijp, zipjp;
   x = g->g_x->a_elements;
   y = g->g_y->a_elements;
   z = g->g_z->a_elements;
    * We find the min. and max values of the Z heights and divide that
    * by a number of levels that is pre-determined.
    * We should really do something more reasonable here, similar to the
    * stuff we do for figuring out tick marks on 2-d plots
   array_minmax(g->g_z, &minz, &maxz);
   diff = (maxz - minz)/10.0;
   for(i=0;i<NOROWS(g->g_x)-1;i++) {
xavg = (x + x[i+1]) / 2.0;
for(j=0;j<NOROWS(g->g_y)-1;j++) {
    yavg = (y[j] + y[j+1]) / 2.0;
    zij = z[(i*NOROWS(g->g_y))+j];
    zipj = z[((i+1)*NOROWS(g->g_y))+j];
    zijp = z[(i*NOROWS(g->g_y))+j+1];
    zipjp = z[((i+1)*NOROWS(g->g_y))+j+1];
    zavg = (zij + zipj + zijp + zipjp)/4.0;
    /* For each level */
    for(level = minz; level < maxz; level += diff) {
  /* Triangle i,j avg and i,j+1 */
  graph_segment(gp, x, y[j], zij, x, y[j+1], zijp,
        xavg, yavg, zavg, level, color);
  graph_segment(gp, x, y[j], zij, x[i+1], y[j], zipj,
  graph_segment(gp, x[i+1], y[j], zipj, x[i+1], y[j+1], zipjp,
  graph_segment(gp, x, y[j+1], zijp, x[i+1], y[j+1], zipjp,
[ 此贴被dwg123在2009-08-10 20:23重新编辑 ]
by 暗潮 财富 +2 - 2005-08-29
获得果果的途径:
1.参与技术讨论
2.回答果友的问题或解答果友的疑难
3.在【文献求助】板块应助
4.提出有助于论坛建设和发展的意见或建议
5.分享有效资源(非重复资源)
6.参与论坛各项活动(包括节假日等的活动)
7.用人民币购买交易币之后兑换果果
8.被评为果园年度优秀会员有适当财富奖励
9.加入阿果石油网管理团队有适当财富薪酬
离线gold
87
430
46
只看该作者 1楼 发表于: 2005-09-02 | 石油求职招聘就上: 阿果石油英才网
看不懂
石油论坛网盘:
http://my.mofile.com/agpr_sy
agpr_sy/123456789
http://agprsy.gbaopan.com
agprsy/agprsy
http://agpr.ys168.com/
agpr.net.1130
离线xzqfeng
446
279
13
只看该作者 2楼 发表于: 2006-04-04 | 石油求职招聘就上: 阿果石油英才网
thanks!
离线xiewild
432
只看该作者 3楼 发表于: 2006-04-26 | 石油求职招聘就上: 阿果石油英才网
vc下编译出错
离线syq_1979
21
325
只看该作者 4楼 发表于: 2006-10-26 | 石油求职招聘就上: 阿果石油英才网
看不懂啊
7215
9877
只看该作者 5楼 发表于: 2009-08-10 | 石油求职招聘就上: 阿果石油英才网
确实不如C++写的代码优美!
离线gindar
65
67
只看该作者 6楼 发表于: 2012-05-09 | 石油求职招聘就上: 阿果石油英才网
请问这个要怎么用啊?
