此客户为著名的美资石油开发公司,进入中国市场已经有10多年时间,目前正在开发南海的深海项目。
以下职位地点为北京,待遇等根据个人能力而定。有兴趣者可以直接将简历发送至
rachelw@lefei-international.com 本公司同时为其他客户招聘钻井,完井,地质,地球物理,油藏,压裂等工程师及高级管理人员,如果您有求职意向,也可以直接发送邮件或者通过MSN与我取得联系。
MSN:emeraldcalla@lefei-international.com职位一:
Job Title: Petroleum EngineerJob Description:
· To provide Production Engineering and technical support to the Subsurface group, Production Operations, Drilling & Completions and for all production and well completion and workover activities for the CFD 11, 12 and 2-1 fields
· Undertake study work and analysis of well pressure decline, rate transient behavior, material balance and quality check well and field data deposited in the OFM database in liaison with Reservoir Engineers
· Optimize the production and performance of the allocated well population by providing advice and guidance on any well parameter adjustments that are required based on detailed Autograph and Prosper modeling. Undertake field wide analysis and optimization studies using Integrated Production Management (IPM) and GAP software tools.
· Undertake production engineering studies and reviews to support ongoing facilities engineering and field expansion project work.
· To have good working knowledge of the economic drivers for CFD 11, 12 and 2-1 fields, and base field development and well intervention decisions on the best economic returns.
· Work with other team members in the organization to ensure the overall KMCPL/CNOOC objectives and goals are met or exceeded
· To ensure a safe working environment and KMCPL/CNOOC production requirements are fulfilled in a timely and accurate manner
Requirements
· Minimum 3 - 6 years experience in an oil operating company with at least 3 years in a production optimization role and experience in completing Production Engineering study and project work.
职位二:
Job Title: Production EngineerJob Description:
· Conduct analysis and input for well pressure decline, pressure transients, material balance and OFM database in liaison with Reservoir Engineers
· Optimize the production and performance of each well by providing advice and guidance on any well parameter adjustments that are required based on detailed Autograph and Prosper modeling
· Prepare and maintain well data files and well activity histories not only to support well modeling on Autograph and Prosper but also to identify any well workover, recompletion and stimulation requirements
· Maximize the ESP runlife of each well by providing advice and guidance on the operating parameter settings and any well parameter adjustments that become necessary
· Will recommend and implement activities to ensure cost effective and maximum amounts of oil are available
· Will work with other team members in the organization to ensure the overall KMCPL/CNOOC objectives and goals are met or exceeded
· Will have complete working knowledge of the economic drivers for CFD 11, 12 and 2-1 fields, and base his decisions on the best economics
职位三:
Job Title: Senior Development Geologist Job Description:
-Prepare geological summaries and inputs to the well drilling program for all wells on the CFD fields
-Liaise with operation geologist to ensure well placement during drilling is optimized
-Integrate new data in geological model and adjust forward plans to make maximum benefit of the new data
-Provide updated geological property maps and volumetric estimates to reservoir group
-Integrate new structural information from geophysics into geological model
-Provide drilling group with the latest information for well planning
-Prepare and present material on development geology to partner and management groups
-Work with petro-physicist to ensure log interpretations are correct and consistent
Requirements
-BS in Geology or higher
-5-10 or more years relevant experience in field development work, and field planning. Field development experience and understanding of Bohai Bay area preferred
-ability to work in small multi-disciplined team
